    Camera image over MQTT
    low power
    27 Posts 9 Posters 18.3k Views 11 Watching
    • R Offline
      robmarkcole
      Hi all, I discovered that it's possible to send images over MQTT and have done this with a raspberry pi. Is there a way to connect a camera to a pycom board - or via a pi? I want to send images long range via lowra and have the camera sleeping most of the time. It's for a bird monitoring project.. Thanks in advance!
      J ahaw021A P 3 Replies Last reply Reply Quote 0
      • B Offline
        bucknall
        Hi @robmarkcole
        This is definitely possible over WiFi as there are working examples written in C for the ESP32, however I'm yet to see this ported to MicroPython so it might be a while before you're able to do it specifically in MicroPython.
        Here's a link to the example I'm referencing written in C;
        https://github.com/igrr/esp32-cam-demo
        Developer Evangelist - Pycom
          jmarcelino @robmarkcole
          @robmarkcole
          Regardless of camera support sending images over LoRa is unrealistic, it's a slow protocol and the duty cycle restrictions will make any transfer of more than a few bytes take forever.
          The FiPy - provided you have LTE-M network coverage - should be better suited for this
          • RobTuDelftR Offline
            RobTuDelft
            If the Pi is close, use Wi-Fi to connect to the Pi and send your pictures over WLAN. Instead of the Fipy you can also hook up a separate cellular module to a wipy/lopy.
            Another option is something like this https://www.generationrobots.com/media/3G-GPRS-GPS-Arduino-Shield-With-Audio-Video-Kit.pdf. You can connect the arduino via UART to the wipy/lopy.
            alt text
            Without data you're just another person with an opinion.
            Hackster | About me
            • R Offline
              robmarkcole @RobTuDelft
              @RobTuDelft Interesting, thanks! Would I have to transfer the whole image to the LoPy, or just use the LoPy as a Lowra router and transfer the image piecemeal? For my project, I do not require fast transfer of the image - if it took a couple of days to send the image I would be happy.
              4G is another option, but I am thinking about places where there is weak to non-existent mobile reception
              RobTuDelftR J 2 Replies Last reply Reply Quote 0
                RobTuDelft @robmarkcole
                @robmarkcole The payload of LoRa is only around 50 bytes so using LoRa to transfer your images is out of the question. It is simply not designed for this purpose. You could however store it locally on a sd card, if cellular/Wi-Fi is not an option. You can then send a notification when it's time to collect your data.
                Hackster | About me
                  @robmarkcole
                  The other problem with taking days to send an image is you have to keep the LoPy running - at full speed - all that time so you could rule out battery power.
                    jmarcelino
                    If you can work with a 500 meter range (maybe 1Km) WiFi Long Range mode - already in ESP-IDF 2 so should be coming soon to Python - could maybe do it.
                    • Support Long Range Rate mode along with bgn mode to support long range WiFi communication.`
                      https://github.com/espressif/esp-idf/releases
                    • R Offline
                      robmarkcole
                      Very interesting.. With my current technique the image is converted to a bytearray for transmission, so presumably could be transmitted in 50 byte chunks, with sufficient time. .? I suppose power could be supplied by a solar panel?
                      If none of these are feasible, then just transmitting 'significant effects' as detected by the camera /pi would be good enough e.g. bird present - bird absent @ midday
                      • R Offline
                        robmarkcole @jmarcelino
                        @jmarcelino 500 m would certainly bring some applications within range :-)
                          @robmarkcole
                          How big are the images. By quick calculation it would take about 2 hours to send about 32KB over LoRa (SF7 4/5 on a 1% duty cycle) and that's before any re-transmissions (you'd have to implement a protocol for this over raw LoRa point to point )
                          A large enough solar panel could power it but then you're adding even more complexity. It is an interesting mental exercise exploring all those options but at the end of the day you'd be trying to shoehorn functionality into a technology that is a wrong fit.
                          • R Offline
                            @jmarcelino If using a pi camera, images are ~ 2 Mb https://www.raspberrypi.org/documentation/usage/camera/raspicam/raspistill.md
                            Prob could get away with grayscale, lower resolution also
                              @robmarkcole
                              The other problem is you can't work with the image in RAM on the LoPy, there's just not enough of it. You'd need to dump it out to file in blocks first which makes compression difficult.
                              However the FiPy does have a lot more RAM (4 Megabytes) :-) (...or the OEM modules)
                              • ahaw021A Offline
                                ahaw021 @robmarkcole
                                @robmarkcole - why do you want to send images over LoRa and specifically why have you chosen MQTT as the Transport
                                The reason why I ask is that I have done a few projects where customers have asked for this but when we broke up the problem they were actually looking for something else
                                Andrei
                                • R Offline
                                  robmarkcole @ahaw021
                                  @ahaw021 hi Andrei, the use case is to send a single image once every 24 hours over long distance
                                  ahaw021A 1 Reply Last reply Reply Quote 0
                                  • ahaw021A Offline
                                    @robmarkcole
                                    I understand that it might be commercially sensitive etc
                                    My question comes from a problem approach
                                    So the question I specifically want to understand is why do you want to send the image - what is the purpose of having the image sent rather than jumping to a "solution" - I need to send the image
                                    For example:
                                    Project 1: Farmer wanted to analyse the health of his sheep (color of their wool)
                                    Approach 1: Send the Image over NB-IOT to Azure Image Processing
                                    Approach 2: What we ended up doing - local image processing and sending the results over LoRaWAN. We used a camera from JeVois to do all the processing locally and just send a small message with LoRaWAN - http://jevois.org/
                                    Project 2: Security at Remote Substations
                                    Approach 1: Try Stream over long range protocols such as LoRaWAN or Satellite links
                                    Approach 2: Use the local IP cameras with computer vision to identify when someone is in the substation - send an alert via LoRaWAN to security office and they could decide what to do (most of the time by the time the responders got on site the people entering the station left)
                                    You can use deltas to minimise the size of the data you are sending. In computer vision there is a concept of background subtraction which is one approach to minimise the ammount of data
                                    Yet another option is to use the JeVois to store the actual images (you can have up to 8GB of memory i believe) and only send notifications when the camera is full
                                    Andrei
                                    • R Offline
                                      @ahaw021 Hi Andrei, that is very interesting, I actually have one of those jevois cameras to try out. My project is monitoring of endangered birds, in particular capturing a daily image of a remote nest to check the number/status of eggs. The question is if this information could be analysed on the camera, or if a person would have to review the images.
                                      Is your work written up?
                                      ahaw021A 2 Replies Last reply Reply Quote 0
                                      • ahaw021A Offline
                                        @robmarkcole
                                        This is a fairly simple computer vision problem
                                        The work we have done is proprietary to the customer so we aren't able to share it
                                        What I would suggest you do
                                        A) Use the storage available locally to save an image
                                        B) send the counts
                                        C) run for two weeks and see how accurate it is
                                        Sample of a related problem
                                        https://www.youtube.com/watch?v=PHwCK9ItDbc
                                        Andrei :D
                                        • ahaw021A Offline
                                          @robmarkcole
                                          did you get anywhere with this
                                          I have a JeVois camera and can provide you a reference code for a laptop (not an embedded board as I am waiting on my Pycoms) and actually have some eggs that I can send sample code for
                                          I believe simple blob detection should be good enough for what you need as the eggs should be fairly easy to make out
                                          Let me know
                                          Andrei
                                          • R Offline
                                            @ahaw021 Hi Andrei, didn't make a start yet but its moving up my to-do list.
                                            Definitely confirming the image recognition algorithm is the first step and the more data the better. Perhaps you can post the image data on GitHub or Kaggle?
                                            Cheers
                                            • 1
                                            • 2
                                            • 1 / 2
