<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ImportError: cannot import name Bluetooth **SOLVED**]]></title><description><![CDATA[<p dir="auto">I am trying  to run some of the Bluetooth examples given in the documentation but am getting the error message: ImportError: cannot import name Bluetooth. I have updated to the latest WiPy 2.0 firmware and can run other code including a web server example, so I am reasonably confident the WiPy is working. I have also tried importing the Bluetooth class using the REPL but get the same result:</p>
<pre><code>&gt;&gt;&gt; from network import Bluetooth
Traceback (most recent call last):
  File &quot;&lt;stdin&gt;&quot;, line 1, in &lt;module&gt;
</code></pre>
<p dir="auto">Any help would be greatly appreciated.</p>
]]></description><link>https://forum.pycom.io/topic/1183/importerror-cannot-import-name-bluetooth-solved</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Jul 2026 22:27:47 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/1183.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 May 2017 15:06:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ImportError: cannot import name Bluetooth **SOLVED** on Tue, 09 May 2017 18:29:18 GMT]]></title><description><![CDATA[<p dir="auto">I am trying  to run some of the Bluetooth examples given in the documentation but am getting the error message: ImportError: cannot import name Bluetooth. I have updated to the latest WiPy 2.0 firmware and can run other code including a web server example, so I am reasonably confident the WiPy is working. I have also tried importing the Bluetooth class using the REPL but get the same result:</p>
</code></pre>
]]></description><link>https://forum.pycom.io/post/7277</link><guid isPermaLink="true">https://forum.pycom.io/post/7277</guid><dc:creator><![CDATA[tenspot]]></dc:creator><pubDate>Tue, 09 May 2017 18:29:18 GMT</pubDate></item><item><title><![CDATA[Reply to ImportError: cannot import name Bluetooth **SOLVED** on Tue, 09 May 2017 15:42:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/553">@tenspot</a>,</p>
<p dir="auto">Could you please go to the REPL and run:</p>
<pre><code>import os
os.uname()
</code></pre>
<p dir="auto">I know you have already updated, but this will just double check that the firmware is on the latest version!</p>
]]></description><link>https://forum.pycom.io/post/7278</link><guid isPermaLink="true">https://forum.pycom.io/post/7278</guid><dc:creator><![CDATA[bucknall]]></dc:creator><pubDate>Tue, 09 May 2017 15:42:47 GMT</pubDate></item><item><title><![CDATA[Reply to ImportError: cannot import name Bluetooth **SOLVED** on Tue, 09 May 2017 16:07:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">The response is:</p>
<p dir="auto">(sysname='WiPy', nodename='WiPy', release='0.9.7.b1', version='v1.8.6-234-g765f2bc on 2016-12 02', machine='WiPy with ESP32')</p>
]]></description><link>https://forum.pycom.io/post/7281</link><guid isPermaLink="true">https://forum.pycom.io/post/7281</guid><dc:creator><![CDATA[tenspot]]></dc:creator><pubDate>Tue, 09 May 2017 16:07:47 GMT</pubDate></item><item><title><![CDATA[Reply to ImportError: cannot import name Bluetooth **SOLVED** on Tue, 09 May 2017 16:11:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/553">@tenspot</a> Looks like your firmware update wasn't successful! This likely explains the Bluetooth issues!</p>
<p dir="auto">Could you try to update the firmware again please? :)</p>
<p dir="auto">You're looking to see release='1.6.3.b1',</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.pycom.io/post/7282</link><guid isPermaLink="true">https://forum.pycom.io/post/7282</guid><dc:creator><![CDATA[bucknall]]></dc:creator><pubDate>Tue, 09 May 2017 16:11:42 GMT</pubDate></item><item><title><![CDATA[Reply to ImportError: cannot import name Bluetooth **SOLVED** on Tue, 09 May 2017 16:28:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/823">@bucknall</a> Hi, I have updated the firmware again but nothing has changed it is still showing as release='0.9.7.b1'. the update process seems to complete o.k. However, the firmware update program welcome screen say &quot;This wizard will help you upgrade your Pycom board firmware to version 0.9.7.b1.&quot; so am I using an old version of this program?</p>
]]></description><link>https://forum.pycom.io/post/7284</link><guid isPermaLink="true">https://forum.pycom.io/post/7284</guid><dc:creator><![CDATA[tenspot]]></dc:creator><pubDate>Tue, 09 May 2017 16:28:08 GMT</pubDate></item><item><title><![CDATA[Reply to ImportError: cannot import name Bluetooth **SOLVED** on Tue, 09 May 2017 16:46:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/823">@bucknall</a> Hi, I have re-installed the firmware update program and run this to update the firmware to the latest version and I can now import the Bluetooth class.</p>
<p dir="auto">Thanks for your help.</p>
]]></description><link>https://forum.pycom.io/post/7285</link><guid isPermaLink="true">https://forum.pycom.io/post/7285</guid><dc:creator><![CDATA[tenspot]]></dc:creator><pubDate>Tue, 09 May 2017 16:46:19 GMT</pubDate></item><item><title><![CDATA[Reply to ImportError: cannot import name Bluetooth **SOLVED** on Tue, 09 May 2017 17:32:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/553">@tenspot</a> No problem! :) It was likely that you had a very old version of the firmware tool installed!</p>
]]></description><link>https://forum.pycom.io/post/7287</link><guid isPermaLink="true">https://forum.pycom.io/post/7287</guid><dc:creator><![CDATA[bucknall]]></dc:creator><pubDate>Tue, 09 May 2017 17:32:53 GMT</pubDate></item></channel></rss>
