<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LoRa repeater between node and gateway]]></title><description><![CDATA[<p dir="auto">I want to build a LoRa network in a big area where i won't have ether net / WiFi / 3G in every place where a gateway is needed to cover the whole area. How can i build something like a repeater from the nodes to the gateways?</p>
<p dir="auto">Just something that will stay between the node and the gateway, and will take the packets and transmit them again so it can reach the gateway.</p>
]]></description><link>https://forum.pycom.io/topic/1187/lora-repeater-between-node-and-gateway</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 05:28:06 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/1187.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 May 2017 02:05:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LoRa repeater between node and gateway on Thu, 11 May 2017 02:05:05 GMT]]></title><description><![CDATA[<p dir="auto">I want to build a LoRa network in a big area where i won't have ether net / WiFi / 3G in every place where a gateway is needed to cover the whole area. How can i build something like a repeater from the nodes to the gateways?</p>
]]></description><link>https://forum.pycom.io/post/7326</link><guid isPermaLink="true">https://forum.pycom.io/post/7326</guid><dc:creator><![CDATA[DongYin]]></dc:creator><pubDate>Thu, 11 May 2017 02:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to LoRa repeater between node and gateway on Thu, 01 Jun 2017 06:32:32 GMT]]></title><description><![CDATA[<p dir="auto">Hi DongYin,</p>
<p dir="auto">I saw your question browsing the forum. I'm in a similar situation and was curious if you have already tackled the problem/found a solution?</p>
]]></description><link>https://forum.pycom.io/post/7894</link><guid isPermaLink="true">https://forum.pycom.io/post/7894</guid><dc:creator><![CDATA[joena]]></dc:creator><pubDate>Thu, 01 Jun 2017 06:32:32 GMT</pubDate></item><item><title><![CDATA[Reply to LoRa repeater between node and gateway on Thu, 01 Jun 2017 07:47:23 GMT]]></title><description><![CDATA[<p dir="auto">Are you using single channel or an SX1301 based gateways?</p>
]]></description><link>https://forum.pycom.io/post/7898</link><guid isPermaLink="true">https://forum.pycom.io/post/7898</guid><dc:creator><![CDATA[bmarkus]]></dc:creator><pubDate>Thu, 01 Jun 2017 07:47:23 GMT</pubDate></item><item><title><![CDATA[Reply to LoRa repeater between node and gateway on Tue, 06 Jun 2017 17:21:18 GMT]]></title><description><![CDATA[<p dir="auto">Hi bmarkus,  i've not yet made any hardware solutions for this. Was hoping that someone already made a lora gateway repeater, if possible</p>
]]></description><link>https://forum.pycom.io/post/8105</link><guid isPermaLink="true">https://forum.pycom.io/post/8105</guid><dc:creator><![CDATA[joena]]></dc:creator><pubDate>Tue, 06 Jun 2017 17:21:18 GMT</pubDate></item></channel></rss>
