    LoPy pinout (work in progress)
    37 Posts 9 Posters 21.2k Views 10 Watching
    • X Offline
      Xykon administrators
      I've been trying to figure out the physical pinout of the LoPy as I couldn't wait for this to be officially released.
      Here is how far I got. If anyone has any info on the remaining pins please share. I've got a busy weekend ahead so not sure when I'll get back to this.
      The good news is that the JTAG pins are available on the header so finding the remaining pins shouldn't be as difficult.
      alt text
      You can find the Excel file here
      Christian Ehlers
        LoneTech
        I can map them out using the GPIO registers (low level access can be useful sometimes).
        import machine, esp32  # esp32.py from github
        def findpin(name):
            pin=machine.Pin(name)
            irq=pin.irq(trigger=pin.IRQ_RISING,
                        handler=lambda p: None)
            candidates=[i for i in range(40)
                        if esp32.GPIO.pin[i].int_type]
            pin.irq(trigger=0).disable()
            return name, candidates
        For some reason, running it in a loop doesn't work properly, but here's the result:
        ('P0', [3])
        ('P1', [1])
        ('P2', [0])
        ('P3', [4])
        ('P4', [15])
        ('P5', [5])
        ('P6', [27])
        ('P7', [19])
        ('P8', [2])
        ('P9', [12])
        ('P10', [13])
        ('P11', [22])
        ('P12', [21])
        ('P13', [5])
        ('P14', [4])
        # 15 and 16 caused hangs
        ('P17', [3])  # maybe 35?
        ('P18', [2])  # maybe 34?
        ('P19', [0])  # 32?
        ('P20', [1])  # 33?
        ('P21', [26])
        ('P22', [25])
        ('P23', [14])
        I suspect the low numbers for P13-P20 is a firmware bug related to GPIO>32.
        The quick reference indicates that LoRa is connected on P5-P7 (using SPI) and the RGB LED is on P2.
        The expansion board connects P0=RX0, P1=TX0, P4=SD-CMD, P8=SD-DAT0, P9=LED, P10=button, P16=Vbat, P19=CTS, P20=RTS, P23=SD-CLK.
        I kind of hope that JTAG port is disabled, or it might do funny things when the button gets pressed.
        Perhaps my next step is finding the LoRa SPI pinout.
        Also, considering the WiPy 1.0 had ADC pins on G5, G4 and G3 (P13, P14 and P16) we can expect those are RTC pins on the LoRa. That would be GPIO 0,2,4,12-15,25-27,32-39.
        Tracking down the LoRa SPI:
        >>> GPIO.func_out_sel_cfg[5].func
        63
        >>> GPIO.func_out_sel_cfg[27].func
        65
        >>> GPIO.func_out_sel_cfg[19].func
        256
        >>> GPIO.func_in_sel_cfg[64].gpio
        19
        Output 63 is VSPICLK_out_mux. Output 65 is VSPID_out. 256 is GPIO, but just means that pin isn't used for output. Input 64 is VSPIQ_in. Looks like the VSPI is used to talk to the LoRa radio.
        Some careful probing suggests that P15 is GPIO 32+6=38, and P16 is GPIO 39. I don't know why they cause so much trouble; merely calling Pin('P15') causes a crash, but Pin.module.P15 exists. Some operations on it don't work. Similar probing shows P13=37, P14=36, P15=38, P16=39, P17=35, P18=34, P19=32, P20=33.
        Here's a little surprise: GPIO 34 and up don't have output capability, according to the technical reference manual. That's P13 to P18 on the LoPy. Initial experiments seem to support this; I'm not getting them to output anything. This is because they have dedicated analog input functions, apparently. Perhaps this is why they are blank in your table?
        X 1 Reply Last reply Reply Quote 1
        • X Offline
          Xykon administrators @LoneTech
          @LoneTech said in LoPy pinout (work in progress):
          Sorry took me a while to see your latest update. I will update my image with your findings tomorrow.
          I first started using the blink example from esp-idf to find the JTAG pins using a logic analyser to see which pin would change states. I then used openocd-esp32 to write to GPIO_OUT_REG and GPIO_OUT1_REG to try and identify the rest of the pins.
          Since P13-18 are input pins (a fact that I missed in the reference manual) it makes sense that I couldn't identify them.
          Christian Ehlers
          • M Offline
            mfgeorge
            Hello all,
            I have found the i2c pins for bus 0 (currently the only one that does not throw an OSError during instantiation).
            P9 - SDA Bus 0
            P10- SCL Bus 0
            Again this is presumably for i2c bus 0. ie i2c_object = I2C(0, I2C.MASTER)
            Method for finding these pins:
            These pins were found by looping a "while True: i2c.scan()" in the REPL prompt and scoping around for a clock signal. After the clock signal was found I continued the i2c.scan() and plugged in an i2c sensors SCL to the P10, and checked to either side with the sensors SDA pin and found the address for the sensor was reported back while SDA was connected on P9.
            Hope this helps and happy hacking everyone!
            B 1 Reply Last reply Reply Quote 2
            • X Offline
              Thanks... it looks like you've done the same thing I did tonight. Currently doing some tests with a simple 24LC64 eeprom.
              Christian Ehlers
              • M Offline
                mfgeorge
                No Problem...
                Another live update. For UART Bus 1 (ie. uart = UART(1,baudrate=9600)) the pins are:
                P3 - UART TX Bus 1
                P4 - UART RX Bus 1
                • X Offline
                  Xykon administrators @mfgeorge
                  @mfgeorge Updated image with additional information provided.
                  Christian Ehlers
                  • X Offline
                    It's late and I might be wrong but I think UART1 should be P3 RX1 and P4 TX1.
                    Christian Ehlers
                    • M Offline
                      mfgeorge @Xykon
                      @Xykon Hmmm.... I can double check what I did tomorrow. But also remember that Tx on peripheral device goes to Rx on master, and vice-versa for the other combo. They need to criss-cross so that one is transmitting to another's receiving pin. A little confusing, I know.
                      • X Offline
                        I connected an FTDI breakout board to UART1 and wired TX on the FTDI to P3 and RX to P4. I disconnected it for the night will check again tomorrow.
                        Christian Ehlers
                          livius
                          i suppose that this should be compatibile with wipy yes or no?
                          0_1478245297369_upload-ad022864-8780-4ba4-a410-d07f94b4ac90
                            littlebat @livius
                            @livius said in LoPy pinout (work in progress):
                            That is for wipy 1.0 not wipy 2.0
                            • X Offline
                              Xykon administrators @littlebat
                              @littlebat said in LoPy pinout (work in progress):
                              No as they use different chips (cc3200 in the WiPy1 and ESP32 in the LoPy / WiPy2).
                              For example WiPy1 doesn't have JTAG on the expansion header while the LoPy does.
                              Christian Ehlers
                              • X Offline
                                I've uploaded the Excel file I used to make the image in case anyone wants to make modifications.
                                Christian Ehlers
                                  LoneTech
                                  You may want to take a look at the ESP32 technical reference manual. Section 4.10 IO_mux and 4.11 RTC_mux list the dedicated alternate functions for each pin, but more importantly, section 4.9 GPIO matrix lists all the functions that can be mapped anywhere, which includes those UART and I2C functions (there are over a hundred each direction). In short, unless the software does something silly, there's no particular pin for RX1/TX1 et cetera (micropython should use the GPIO matrix). UART 0 only has them because the bootloader ROM selects those pins, though I'm not certain if it does it via the IO mux or GPIO matrix.
                                  • X Offline
                                    Yes I'm aware of that... I was just putting in the defaults for SPI0, I2C0 and UART0/1 as the examples in the quick reference do not specify any custom pins.
                                    Christian Ehlers
                                      LoneTech @Xykon
                                      I see. It's the default arguments of the micropython port we're looking for then. The chosen pins don't match the IO mux. A comment in https://docs.pycom.io/lopy/lopy/quickref.html#pins-and-gpio seems to be the documentation we get.
                                      UART 1 pins are most likely chosen to match the WiPy 1.0 (CC3200) layout documented in https://docs.pycom.io/wipy/wipy/quickref.html but the I2C looks different. Hopefully we can clean the documentation up once the project opens up a bit.
                                      • M Offline
                                        mfgeorge @Xykon
                                        @Xykon OK, so I again verified my results.
                                        Connecting a slaves RX pin to P3 and the slaves TX pin to P4 yielded results. I tried it the other way, and nothing.
                                        So again, I stand behind what I stated before.
                                        Slaves RX ---> LoPy Tx - P3
                                        Slaves Tx ---> LoPy Rx - P4
                                        The criss-cross is confusing I know, but this is the standard way of wiring UART and naming the pins. The slave I am using is well labeled, and I have tested the same exact wiring scheme named above using other microcontrollers. I am now pretty positive of those two pins.
                                        • X Offline
                                          @mfgeorge It looks like the DFRobot FTDI breakout board I was using to test UART1 has RXI and TXD inverted. I compared it to the Sparkfun FTDI breakout I was using for UART0 and it has the RXI and TXD the other way around.
                                          Lesson learned: Never trust the silkscreen on cheap breakout boards. I will update the graphic tomorrow.
                                          Christian Ehlers
                                            pighixxx
                                            Hi all,
                                            Today i released the official LoPy pinout:
                                            alt text
                                            Download the PDF here
                                            Have a noce day!
                                            L 1 Reply Last reply Reply Quote 4
                                            • 1
                                            • 2
                                            • 1 / 2
