<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED]LoPy Bricked, RED LED]]></title><description><![CDATA[<p dir="auto">I had my expansion board working with both until yesterday. I tried with 2 LoPy and the result is the same, however when I put my WiPy it is working fine. I also have an expansion board v1.0 and the result is the same.</p>
<p dir="auto">I tried to update one of the LoPy's firmware and it is now booting with the LED permanently red. Even in safe boot after being ORANGE it stays RED.<br />
I have been able to connect to my other LoPy with minicom via Linux (and now it is working again via widnows) but the other one seems bricked.<br />
Any idea of what to do ?</p>
<p dir="auto">Thank you in advance,</p>
<p dir="auto">Benjamin</p>
]]></description><link>https://forum.pycom.io/topic/1343/solved-lopy-bricked-red-led</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 10:56:31 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/1343.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Jun 2017 04:26:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED]LoPy Bricked, RED LED on Tue, 13 Jun 2017 10:48:08 GMT]]></title><description><![CDATA[<p dir="auto">I had my expansion board working with both until yesterday. I tried with 2 LoPy and the result is the same, however when I put my WiPy it is working fine. I also have an expansion board v1.0 and the result is the same.</p>
]]></description><link>https://forum.pycom.io/post/8367</link><guid isPermaLink="true">https://forum.pycom.io/post/8367</guid><dc:creator><![CDATA[bnjroos]]></dc:creator><pubDate>Tue, 13 Jun 2017 10:48:08 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]LoPy Bricked, RED LED on Tue, 13 Jun 2017 04:53:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1288">@bnjroos</a> try to erase the flash of the &quot;bricked&quot; LoPy with the <a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow">esptool.py</a> form the esp-idf repository <a href="https://github.com/espressif/esptool/tree/96698a3da9acc6e357741663830f97524b688ade" target="_blank" rel="noopener noreferrer nofollow">https://github.com/espressif/esptool/tree/96698a3da9acc6e357741663830f97524b688ade</a><br />
Use<br />
<code>python3 esptool.py -.port com_port --baud 230400 --chip esp32 erase_flash</code><br />
and then update the device again.</p>
]]></description><link>https://forum.pycom.io/post/8368</link><guid isPermaLink="true">https://forum.pycom.io/post/8368</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Tue, 13 Jun 2017 04:53:47 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]LoPy Bricked, RED LED on Tue, 13 Jun 2017 10:47:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> said in <a href="/post/8368">LoPy Bricked, RED LED</a>:</p>
<blockquote>
<p dir="auto">python3 <a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow">esptool.py</a> -.port com_port --baud 230400 --chip esp32 erase_flash</p>
</blockquote>
<p dir="auto">It worked like a charm, thank you a lot !</p>
]]></description><link>https://forum.pycom.io/post/8373</link><guid isPermaLink="true">https://forum.pycom.io/post/8373</guid><dc:creator><![CDATA[bnjroos]]></dc:creator><pubDate>Tue, 13 Jun 2017 10:47:52 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]LoPy Bricked, RED LED on Tue, 04 Jul 2017 11:54:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> Issue appeared again and previous trick did not work this time unfortunately :(</p>
<p dir="auto">And it worked again after several tries.</p>
]]></description><link>https://forum.pycom.io/post/9103</link><guid isPermaLink="true">https://forum.pycom.io/post/9103</guid><dc:creator><![CDATA[bnjroos]]></dc:creator><pubDate>Tue, 04 Jul 2017 11:54:16 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED]LoPy Bricked, RED LED on Thu, 16 Nov 2017 19:26:49 GMT]]></title><description><![CDATA[<p dir="auto">For anybody else that might have this problem, before trying to erase the flash you need to have a wire connected between G23 and GND and reset the board.</p>
]]></description><link>https://forum.pycom.io/post/12826</link><guid isPermaLink="true">https://forum.pycom.io/post/12826</guid><dc:creator><![CDATA[tudro]]></dc:creator><pubDate>Thu, 16 Nov 2017 19:26:49 GMT</pubDate></item></channel></rss>
