    Strategy for LoRaWAN with deepsleep 2
    deepsleepjoinwake up
    34 Posts 9 Posters 13.0k Views 12 Watching
    • _ Offline
      _peter
      Re: Strategy for LoRaWAN with deepsleep It is important that lopy when it wakes up from deepsleep has the opportunity to "remember" to join. Does anyone have any suggestion?
      L papasmurphP 2 Replies Last reply Reply Quote 0
        livius @_peter
        @_peter
        what do you mean remember to join?
        If you join in main.py it once again is executed and joined.
        You can save state to sd card - or not recommended way wrate state to flash.
        But you must programm what to remember
        _ 1 Reply Last reply Reply Quote 0
        • _ Offline
          _peter
          • _ Offline
            _peter @livius
            @livius
            I do not have an sd card in my project and i need the lopy when it wakes up after the deepsleep send the payload without re-join
              Camot
              I have asked myself the same quations.
              @_peter An easy solution I think would be ABP with disabled frame counter check.
              @livius With OTAA everytime a devices comes out of deepsleep,TTN performs a join-procedure with the network, during which a dynamic DevAddr is assigned and security keys are negotiated with the device. I think it is not hard to imagine that a wake up every 5 minutes for example with a new join procedure is not the way the network is designed. If some more devices do that, the gateway would come to the sending limitations.
              With ABP, which is not the preferred way, a frame counter check wil be performed. A device just woken up from deepsleep, starts with 0. The network will not accept the connection.
              Therefore, the ability to store and reload the DevAddr and keys for OTAA or the frame counter for ABP would be required. A product that requires you to disable security features of the network is not best of the art.
              _ 2 Replies Last reply Reply Quote 1
              • _ Offline
                _peter @Camot
                @Camot That's exactly what I meant. Normally who uses the lopy in lorawan should use these escamotage? I do not think it's possible to use it in the right way. Or miss me something?
                  Thosch42 @_peter
                  @_peter While I was planning a board with the OEM LoPy, I run into the same problem. Currently I think about a small I2C NVRAM to save DevAddr and keys. I think there's no other way. Possibly something similar could be implemented in a future release of the Expansionboard.
                  Cheers,
                  Thomas
                  • _ Offline
                    _peter @Thosch42
                    @Thosch42 What you think seems to me very clever. This means, however, that it is not possible to have full functionality with the supplied hardware now. In your opinion, what can be the best compromise at this time?
                      livius @_peter
                      @_peter said in Strategy for LoRaWAN with deepsleep 2:
                      but you have internal flash where you can write files same as into SD card.
                        Thosch42 @livius
                        @livius Yes, that's right. But it depends a little bit on how often the keys change. I need to reed the datasheets and specs. It would be not very clever to stress the internal flash and kill the module slowly.
                        Cheers,
                        Thomas
                          livius @Thosch42
                          @Thosch42 said in Strategy for LoRaWAN with deepsleep 2:
                          Yes, as i say before it is not recommended way - but you must test how offten you need to write.
                          But why not SD card? It is really cheap and small :)
                            jmarcelino @livius
                            SD cards tend to consume a godawful amount of power so they're not a good pairing for generally very power efficient LoRa stuff :-)
                            I wouldn't worry too much about flash wear, by the time you've killed the flash by writing sequence numbers a new Py with proper deepsleep (and more importantly RTC NVRAM preservation) will be out :)
                              livius @jmarcelino
                              @jmarcelino
                              one fet for control power of SD card start it read value and deinit and "close fet" :) same for write :)
                              I think the same as you here:
                              • papasmurphP Offline
                                papasmurph @_peter
                                @_peter My experience: I tried testing for whether it had already joined, but that flag doesn't seem to be set until you attempt and succeed to join, indicating it's always "unjoined" (?) after a deep sleep, so it wouldn't have helped to save state. The service I connect to doesn't mind though.
                                • E Offline
                                  Eric24 @papasmurph
                                  @papasmurph It seems that the issue is not so much about whether it's possible to re-join, but the additional "on time" and radio power budget required to do so. Ideally, a LoRaWAN device should join very infrequently, sleep most of the time, and minimize its "on time" and radio usage (i.e. no re-joining) as much as possible. And that's not only a battery-life issue, but can also become a duty-cycle or simply system capacity issue at scale.
                                  Ultimately, I think storing the information needed to wake-up and transmit without re-joining is a necessity (especially for battery-powered devices). How that information is stored is another matter (the RTC NVRAM would be ideal, as soon as it's supported). But the question your comment brings up is what to do about the "joined" flag? If it's always necessary to re-join after deep sleep, that would be a significant issue. Has anyone else been able to "force" a joined state after deep sleep?
                                    jmarcelino @Eric24
                                    @Eric24
                                    That's not possible yet because you have to tell the LoRa stack: "here reuse these keys I stored somewhere to connect" and that's not possible yet. Of course all the source code is out there so if anyone wants to have a go don't let me stop you. That's a functionality me and I'm sure many others will need for larger deployments so, even if Pycom doesn't get around to doing it, it'll come at some point.
                                    The other problem - but that's more an issue with LoRa and similar protocols - is it's not possible to know if the keys generated for an OTAA session are still valid without actually getting a response from the network, something you get for "free" with a fresh join. So always doing a join is safer. It's a balancing act.
                                    E 2 Replies Last reply Reply Quote 0
                                    • E Offline
                                      Eric24 @jmarcelino
                                      @jmarcelino Right--ability to set keys will be needed. Regarding not knowing if they keys are valid, just thinking out loud...if you have some knowledge (or control) of the server behavior, you could know how long until the keys expire; let's say they last for 24 hours; given that, maybe the device (using the RTC) transmits without re-join for up to 23 hours (or so) and then re-joins on the next interval. Any flaw in that logic? Of course my objective here is to maximize battery life, and for a device that reports every 5 minutes, all that re-joining will add up.
                                        jmarcelino @Eric24
                                        @Eric24 ]
                                        If you have some control of the network some good advice I've heard - but not implemented personally yet - is to forget OTAA, run ADP with frame counters relaxed and implement your own authentication system using for example a crypto chip like the ATECC508A
                                        • E Offline
                                          Eric24 @jmarcelino
                                          @jmarcelino Hmmm. I suppose so, if you have control of the network (although some would argue that this would be less secure). But I was also thinking about public networks where you don't have control, but could have specific knowledge of key lifetimes. Of course there's no technical problem with re-joining on every transmission, but it's definitely not optimal. It makes me wonder if a lot of LoRaWAN implementations are actually doing just that, because it's easier to implement?
                                          papasmurphP 1 Reply Last reply Reply Quote 0
                                            papasmurph @Eric24
                                            Anyone knows what approach thingamagogs like this use? I guess ABP and pre-generated random keys, but I didn't find any details: http://ecubelabs.com/integrated-waste-management/ultrasonic-fill-level-sensor/
                                            • 1
                                            • 2
                                            • 1 / 2
