<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AS923]]></title><description><![CDATA[<p dir="auto">Is there support for AS923 in the latest LoPy firmware (1.7.3.b1)?</p>
<p dir="auto">As the data rates are defined differently how would the LoPy band plan be selected. I know you can define the channels manually and I have managed to get the OTAA join request out of the LoPy but I can't get qa successful join.</p>
<p dir="auto">Has anyone had any success with AS923?</p>
<p dir="auto">I'm using a multitech gateway, TTN backend and their latest packet forwarder ([v2.0.2] <a href="https://github.com/TheThingsNetwork/packet_forwarder/releases" target="_blank" rel="noopener noreferrer nofollow">https://github.com/TheThingsNetwork/packet_forwarder/releases</a>))</p>
]]></description><link>https://forum.pycom.io/topic/1363/as923</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 20:44:24 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/1363.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 16 Jun 2017 06:21:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AS923 on Fri, 16 Jun 2017 06:21:04 GMT]]></title><description><![CDATA[<p dir="auto">Is there support for AS923 in the latest LoPy firmware (1.7.3.b1)?</p>
]]></description><link>https://forum.pycom.io/post/8504</link><guid isPermaLink="true">https://forum.pycom.io/post/8504</guid><dc:creator><![CDATA[virtualguy]]></dc:creator><pubDate>Fri, 16 Jun 2017 06:21:04 GMT</pubDate></item><item><title><![CDATA[Reply to AS923 on Sat, 17 Jun 2017 20:16:01 GMT]]></title><description><![CDATA[<p dir="auto">Is this related to: <a href="https://forum.pycom.io/topic/884/ttn-join-accept-not-handled-properly/18">https://forum.pycom.io/topic/884/ttn-join-accept-not-handled-properly/18</a> ???</p>
]]></description><link>https://forum.pycom.io/post/8571</link><guid isPermaLink="true">https://forum.pycom.io/post/8571</guid><dc:creator><![CDATA[gertjanvanhethof]]></dc:creator><pubDate>Sat, 17 Jun 2017 20:16:01 GMT</pubDate></item><item><title><![CDATA[Reply to AS923 on Sun, 18 Jun 2017 22:35:51 GMT]]></title><description><![CDATA[<p dir="auto">Quite possible, it looks like the LoPy isn't pick up the RX even though I can see the message being queued on the gateway at the same Freq, SF, and BW as the uplink packet. I know the data rate specifications are different on AS923 so when you define a channel on the LoPy is will only allow DR 0-4 on a 915MHz build where as AS923 has 0-7 defined as it allows a much wider range of SF.</p>
<p dir="auto">To be honest it would actually be clearer from a developer's point of view to be able to define a channel based on SF and BW and therefore make the firmware build more flexible.</p>
<p dir="auto">As more and more band plans are defined by the LoRa Alliance I can see the LoPy is going to need to be able to be dynamically configurable, especially for countries in NZ where multiple band plans are available. A regional/geograhpical lock just doesn't work in that situation. perhaps that is a certification nightmare. The upstream code from Semtech has been substantially re-written to support AS923 and others for LoRaWAN 1.0.2, perhaps that code needs to be ported into the LoPy?</p>
]]></description><link>https://forum.pycom.io/post/8594</link><guid isPermaLink="true">https://forum.pycom.io/post/8594</guid><dc:creator><![CDATA[virtualguy]]></dc:creator><pubDate>Sun, 18 Jun 2017 22:35:51 GMT</pubDate></item><item><title><![CDATA[Reply to AS923 on Wed, 27 Dec 2017 21:33:57 GMT]]></title><description><![CDATA[<p dir="auto">I'm registering my interest in AS923 support.</p>
<p dir="auto">Many of the telcos in AU and NZ are implementing AS923 and will not support devices based on LoPy in its current state of affairs.</p>
<p dir="auto">We're going to have to ditch the LoPy and go with muRata or Multitech modules unless the firmware is updated to give more control. Is this on the cards?</p>
]]></description><link>https://forum.pycom.io/post/13900</link><guid isPermaLink="true">https://forum.pycom.io/post/13900</guid><dc:creator><![CDATA[megabyte]]></dc:creator><pubDate>Wed, 27 Dec 2017 21:33:57 GMT</pubDate></item></channel></rss>
