<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TTN &amp; LoRaWAN does not run smoothly]]></title><description><![CDATA[<p dir="auto">Hi all!<br />
I know, there are lots of similar topics. This should be more like a field report:</p>
<ul>
<li>
<p dir="auto">I still have some problems with the Nano Gateway. I can see the gateway traffic in the TTN console. TTN receives join requests every 15s, and sends 5s later a join accept back. But this runs for a indefinite period.</p>
</li>
<li>
<p dir="auto">Also, if the Nano Gateway is running, it stops working after a indefinite periode. Sometimes it simply freezes, sometimes it really crashes with a guru meditation error.</p>
</li>
<li>
<p dir="auto">The OTAA nodes need allways a indefinite periode to join. Seldom, but sometimes I have only 3-4 Not joined yet messages, but mostly, there are 100+</p>
</li>
<li>
<p dir="auto">If I use the lora.has_joined, lora.nvram_save and lora.nvram_restore methods, and set the Lopy repeatedly to deep sleep, most of the packets I send, get lost.</p>
</li>
</ul>
<p dir="auto">What are the experience of you others?</p>
<p dir="auto">Cheers,<br />
Thomas</p>
]]></description><link>https://forum.pycom.io/topic/1603/ttn-lorawan-does-not-run-smoothly</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 21:18:14 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/1603.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Aug 2017 10:39:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TTN &amp; LoRaWAN does not run smoothly on Wed, 02 Aug 2017 10:39:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi all!<br />
<ul>
<li>
</li>
<li>
</li>
<li>
</li>
<li>
</li>
</ul>
Thomas</p>
]]></description><link>https://forum.pycom.io/post/9967</link><guid isPermaLink="true">https://forum.pycom.io/post/9967</guid><dc:creator><![CDATA[Thosch42]]></dc:creator><pubDate>Wed, 02 Aug 2017 10:39:21 GMT</pubDate></item></channel></rss>
