<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AWS MQTT - syntax error on test code]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am trying to test (and understand) the code for AWS MQTT from the documentation</p>
<p dir="auto"><a href="https://docs.pycom.io/chapter/tutorials/all/aws.html" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/chapter/tutorials/all/aws.html</a></p>
<p dir="auto">The problem is I get an syntax error on line 3 in <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a> ...</p>
<p dir="auto">Can you please confirm the following line has the correct syntax ?</p>
<p dir="auto">MQTT client class:</p>
]]></description><link>https://forum.pycom.io/topic/1616/aws-mqtt-syntax-error-on-test-code</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 01:18:47 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/1616.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Aug 2017 17:16:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AWS MQTT - syntax error on test code on Thu, 03 Aug 2017 17:16:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
]]></description><link>https://forum.pycom.io/post/10048</link><guid isPermaLink="true">https://forum.pycom.io/post/10048</guid><dc:creator><![CDATA[ClementN]]></dc:creator><pubDate>Thu, 03 Aug 2017 17:16:29 GMT</pubDate></item></channel></rss>
