    Pytrack GPS API
    Scheduled Pinned Locked Moved Enhancements
    pytrack
    51 Posts 13 Posters 17.0k Views 20 Watching
    • bmarkusB Offline
      bmarkus
      From the GPS only longitude and latitude is available via the API. For production use many other data is required, like
      • altitude
      • date/time
      • HDOP
      • speed
      • direction
      • number of satellites visible /used for fix
      Please add these to the API. Also, it would be good to make raw NMEA sentences available for user space with user filtering to select which sentences must be passed (callback?).
      S 1 Reply Last reply Reply Quote 2
        combaindeft
        Have you looked at the library?
        it's there, though you may have to hack your own code to get out everything you need :)
          andrethemac
          Take a look at this library, it does a lot of nmea parsing, but its quite memory hungry.
          [https://github.com/livius2/micropyGPS/blob/master/micropyGPS.py]
          best regards
          André
            combaindeft @andrethemac
            @andrethemac
            Sounds really interesting, though we'd have to re-write some of the code to run on a PyTrack & LoPy setup :D
            challange-accepted
            ALSO, has anyone else found some documentation of how other GPS vendors do the "Accuracy" calculation?
              andrethemac @combaindeft
              @combaindeft I ran the library on a pytrack / lopy combination, but gave up, to many out of memory errors.
              N C 2 Replies Last reply Reply Quote 0
              • N Offline
                Neuromystix @andrethemac
                Hello all,
                I received today one Pytrack board for testing, and found it very easy to get more data from NMEA sentences. Just need to parse the correct NMEA sentence for what you need. Original library parse $GNGLL, however for what i need (lat/long, gps time, altitude, fix validation) i just changed the lib to parse $GPGGA and get that values. If anyone need i can show my basic test code.
                Some time ago i tried the micropyGPS lib with an external ublox gps module, but also had that memory errors. I think they could be solved, however since i didn't need gps by that time, i never tried to fix anything.
                Best regards
                Researcher @ UALG, Portugal
                  crumble @Neuromystix
                  @neuromystix said in Pytrack GPS API:
                  Yes, please. I had sadly no time to work on my implementation. You run your code on a 4MB version, if you never had any memory problems, right? I can share my code as well, if it is ready. I used preallocated buffers to get around the memory problem, but my parsing of numbers is quite awefull.
                  For me it is hard to get one of the 4MB *Pys. The resellers in Germany seems to have only the old versions or the newer ones are sold out really fast.
                  • N Offline
                    Neuromystix @crumble
                    @crumble i followed the original lib from Pycom, just parse a different NMEA message. I've reading Quectel L76 GNSS protocol specification and i find they have only the following message types:
                    • xxRMC, where we can get UTC Time, validation, lat, long, speed, COG, date and other non important things;
                    • xxVTG, mostly for track course and speed data;
                    • xxGGA, where GPS fix data are. UTC time, lat, long, fix status, number of satellites, HDOP, altitude, height of geoid, DGPS info(if any) are all in this sentence;
                    • xxGSA, infos about satellites;
                    • xxGSV, more info about satellites;
                    • xxGLL, a basic sentence with geographic info like lat, long, UTC time, data validation and position mode.
                    So, depending on what things you need, you just have to parse the exact sentence. In my case, i changed the original library which parsed $GNGLL (few information) to a new function which parse $GPGGA (have more data!). The ideia was the same, reading sentences from i2c till a get a complete GNGLL sentence (searching for beggining and ending of that sentence >> nmea.find(b'GPGGA') and e_idx = gpgga.find(b'\r\n') >> It's a NMEA standard so it always start and end this way), then parse all the values i need. Today it has been working for nearly two hours, reading each second, and i don't get any errors.
                    For use it just call l76.coordinates1() which will return (lat, long, time(not formatted), altitude (M), valid fix (true ou false), number of satellites).
                    L76GNSS.py
                    N A M S 4 Replies Last reply Reply Quote 3
                    • N Offline
                      Neuromystix @Neuromystix
                      @crumble I added a function where i can get time and date. If you want, try it and check if you have any problem.
                      main.py
                      L76GNSS
                      Code:
                      ## Test code for read date/time from gps and update RTC
                      import math
                      import network
                      import os
                      import utime
                      from machine import RTC
                      from machine import SD
                      from machine import Timer
                      from L76GNSS import L76GNSS
                      from pytrack import Pytrack
                      import struct
                      # setup as a station
                      import gc
                      time.sleep(2)
                      gc.enable()
                      #Start GPS
                      py = Pytrack()
                      l76 = L76GNSS(py, timeout=600)
                      #start rtc
                      rtc = machine.RTC()
                      print('Aquiring GPS signal....')
                      #try to get gps date to config rtc
                      while (True):
                         gps_datetime = l76.get_datetime()
                         #case valid readings
                         if gps_datetime[3]:
                             day = int(gps_datetime[4][0] + gps_datetime[4][1] )
                             month = int(gps_datetime[4][2] + gps_datetime[4][3] )
                             year = int('20' + gps_datetime[4][4] + gps_datetime[4][5] )
                             hour = int(gps_datetime[2][0] + gps_datetime[2][1] )
                             minute = int(gps_datetime[2][2] + gps_datetime[2][3] )
                             second = int(gps_datetime[2][4] + gps_datetime[2][5] )
                             print("Current location: {}  {} ; Date: {}/{}/{} ; Time: {}:{}:{}".format(gps_datetime[0],gps_datetime[1], day, month, year, hour, minute, second))
                             rtc.init( (year, month, day, hour, minute, second, 0, 0))
                             break
                      print('RTC Set from GPS to UTC:', rtc.now())
                      chrono = Timer.Chrono()
                      chrono.start()
                      #sd = SD()
                      #os.mount(sd, '/sd')
                      #f = open('/sd/gps-record.txt', 'w')
                      while (True):
                         print("RTC time : {}".format(rtc.now()))
                         coord = l76.coordinates()
                         #f.write("{} - {}\n".format(coord, rtc.now()))
                         print("$GPGLL>> {} - Free Mem: {}".format(coord, gc.mem_free()))
                         coord1 = l76.coordinates1()
                         print("$GPGGA>> {} - Free Mem: {}".format(coord1, gc.mem_free()))
                         coord2 = l76.get_datetime()
                         print("$G_RMC>> {} - Free Mem: {}".format(coord2, gc.mem_free()))
                      The L76GNSS.py code:
                      import gc
                      import binascii
                      class L76GNSS:
                          GPS_I2CADDR = const(0x10)
                          def __init__(self, pytrack=None, sda='P22', scl='P21', timeout=None):
                              if pytrack is not None:
                                  self.i2c = pytrack.i2c
                                  from machine import I2C
                                  self.i2c = I2C(0, mode=I2C.MASTER, pins=(sda, scl))
                              self.chrono = Timer.Chrono()
                              self.timeout = timeout
                              self.timeout_status = True
                              self.reg = bytearray(1)
                              self.i2c.writeto(GPS_I2CADDR, self.reg)
                          def _read(self):
                              self.reg = self.i2c.readfrom(GPS_I2CADDR, 128)      #Changed from 64 to 128 - I2C L76 says it can read till 255 bytes
                              return self.reg
                          def _convert_coords(self, gngll_s):
                              lat = gngll_s[1]
                              lat_d = (float(lat) // 100) + ((float(lat) % 100) / 60)
                              lon = gngll_s[3]
                              lon_d = (float(lon) // 100) + ((float(lon) % 100) / 60)
                              if gngll_s[2] == 'S':
                                  lat_d *= -1
                              if gngll_s[4] == 'W':
                                  lon_d *= -1
                              return(lat_d, lon_d)
                          #diff indexes from original - Using GGA sentence
                          def _convert_coords1(self, gngga_s):
                              lat = gngga_s[2]
                              lon = gngga_s[4]
                              if gngga_s[3] == 'S':
                                  lat_d *= -1
                              if gngga_s[5] == 'W':
                                  lon_d *= -1
                          def _get_time(self, gngga_s):
                              gps_time = gngga_s[1]
                              return(gps_time)
                          def _get_altitude(self, gngga_s):
                              gps_altitude = gngga_s[9]
                              return(gps_altitude)
                          def _get_satellites(self, gngga_s):
                              num_satellites = gngga_s[7]
                              return(num_satellites)
                          def _fix_quality(self, gngga_s):
                              valid = gngga_s[6]
                              if valid == '1':
                                  return True
                                  return False
                          #Using RMC sentence
                          def _get_time_rmc(self, gnrmc_s):
                              gps_time = gnrmc_s[1]
                              return(gps_time)
                          def _data_valid_rmc(self, gnrmc_s):
                              valid = gnrmc_s[2]
                              if valid == 'A':
                                  return True
                                  return False
                          def _get_date_rmc(self, gnrmc_s):
                              gps_date = gnrmc_s[9]
                              return(gps_date)
                          def coordinates(self, debug=False):
                              lat_d, lon_d, debug_timeout = None, None, False
                              if self.timeout is not None:
                                  self.chrono.reset()
                                  self.chrono.start()
                              nmea = b''
                                  if self.timeout is not None and self.chrono.read() >= self.timeout:
                                      self.chrono.stop()
                                      chrono_timeout = self.chrono.read()
                                      self.chrono.reset()
                                      self.timeout_status = False
                                      debug_timeout = True
                                  if not self.timeout_status:
                                      gc.collect()
                                      break
                                  nmea += self._read().lstrip(b'\n\n').rstrip(b'\n\n')
                                  gngll_idx = nmea.find(b'GNGLL')
                                  if gngll_idx >= 0:
                                      gngll = nmea[gngll_idx:]
                                      e_idx = gngll.find(b'\r\n')
                                      if e_idx >= 0:
                                          try:
                                              gngll = gngll[:e_idx].decode('ascii')
                                              gngll_s = gngll.split(',')
                                              lat_d, lon_d = self._convert_coords(gngll_s)
                                          except Exception:
                                              pass
                                          finally:
                                              nmea = nmea[(gngll_idx + e_idx):]
                                              gc.collect()
                                              break
                                      gc.collect()
                                      if len(nmea) > 410: # i suppose it can be safely changed to 82, which is longest NMEA frame
                                          nmea = nmea[-5:] # $GNGL without last L
                                  time.sleep(0.1)
                              if debug and debug_timeout:
                                  print('GPS timed out after %f seconds' % (chrono_timeout))
                                  return(None, None)
                          #TEST functions
                          #Parser for GPGGA
                          def coordinates1(self, debug=False):
                              lat_d, lon_d, gps_time, valid, gps_altitude, num_satellites, debug_timeout = None, None, None, None, None, False, False
                                  self.chrono.reset()
                                  self.chrono.start()
                              nmea = b''
                                      self.chrono.stop()
                                      self.chrono.reset()
                                      gc.collect()
                                      break
                                  gpgga_idx = nmea.find(b'GPGGA')
                                  if gpgga_idx >= 0:
                                      gpgga = nmea[gpgga_idx:]
                                      gpgga_e_idx = gpgga.find(b'\r\n')
                                      if gpgga_e_idx >= 0:
                                          try:
                                              gpgga = gpgga[:gpgga_e_idx].decode('ascii')
                                              gpgga_s = gpgga.split(',')
                                              lat_d, lon_d = self._convert_coords1(gpgga_s)
                                              gps_time = self._get_time(gpgga_s)
                                              valid = self._fix_quality(gpgga_s)
                                              gps_altitude = self._get_altitude(gpgga_s)
                                              num_satellites = self._get_satellites(gpgga_s)
                                          except Exception:
                                              pass
                                          finally:
                                              nmea = nmea[(gpgga_idx + gpgga_e_idx):]
                                              gc.collect()
                                              break
                                      gc.collect()
                                  time.sleep(0.1)
                                  return(None, None, None, None, False, None)
                                  return(lat_d, lon_d, gps_time, gps_altitude, valid, num_satellites)
                          #parser for UTC time and date >> Reads GPRMC
                          def get_datetime(self, debug=False):
                              lat_d, lon_d, gps_time, valid, gps_date, rmc_idx, debug_timeout = None, None, None, None, None, -1, False
                                  self.chrono.reset()
                                  self.chrono.start()
                              nmea = b''
                                      self.chrono.stop()
                                      self.chrono.reset()
                                      gc.collect()
                                      break
                                  #Since or spg or glonass could give date see which one is present -SEE page 10 GNSS protocol
                                  #GPS only       - GPRMC         GPGGA
                                  #Glonass only   - GNRMC         GPGGA
                                  #GPS+GLON       - GNRMC         GPGGA
                                  #No station     - GPRMC         GPGGA
                                  gprmc_idx = nmea.find(b'GPRMC')
                                  gnrmc_idx = nmea.find(b'GNRMC')
                                  if gprmc_idx >= 0:
                                      rmc_idx = gprmc_idx
                                  if gnrmc_idx >= 0:
                                      rmc_idx = gnrmc_idx
                                  if rmc_idx >= 0:
                                      rmc = nmea[rmc_idx:]
                                      rmc_e_idx = rmc.find(b'\r\n')
                                      if rmc_e_idx >= 0:
                                          try:
                                              rmc = rmc[:rmc_e_idx].decode('ascii')
                                              rmc_s = rmc.split(',')
                                              lat_d, lon_d = self._convert_coords1(rmc_s[1:])
                                              gps_time = self._get_time_rmc(rmc_s)
                                              valid = self._data_valid_rmc(rmc_s)
                                              gps_date = self._get_date_rmc(rmc_s)
                                          except Exception:
                                              pass
                                          finally:
                                              nmea = nmea[(rmc_idx + rmc_e_idx):]
                                              gc.collect()
                                              break
                                      gc.collect()
                                      if len(nmea) > 512: # i suppose it can be safely changed to 82, which is longest NMEA frame --CHANGED to 512
                                  time.sleep(0.1)
                                  return(None, None, None, False, None)
                                  return(lat_d, lon_d, gps_time, valid, gps_date)
                      G S 2 Replies Last reply Reply Quote 4
                        @andrethemac Yeah, ran into that issue aswell.
                        why we are re-doing the gps library that comes from pycom :)
                        and selectively adding more and more features ... so we won't run out of memory
                          andrethemac @Neuromystix
                          @neuromystix I used to search the nmea messages with _read looking for xxGGA until a fix was found. Only then I use the l76.coordinates to find the exact position.
                          a bit of a work around.
                          The new library you posted works as a charm, no more memory errors.
                          The Quectel is a bit "slow" but with a timeout of 180 (3 minutes), I manage to get a fix (almost) every time the wipy/lopy comes awake (after deep sleep). Not so good for the battery, 3 minutes on +- 70 mA vs 390 uA in deep sleep with the pytrack. The 390 uA are probably from the accelerator, I use the accelerator to wake up the unit when it gets more than 2g for over a second.
                          • N Offline
                            @andrethemac i followed the original lib which use gc to clean memory. But haven't tried any other options.
                            Same problem here with the starting time. Sometimes i just unplug the cable from my computer and plug it to a powerbank and have to wait 5 minutes for it to get fix. For my project this will not be a problem but for a battery operated device it's not a good thing...
                              gregcope @Neuromystix
                              @neuromystix Works like a champ - it would be good if this was added to the main lib. I added HDOP (GPGGA) as that is a good indication of accuracy.
                              • M Offline
                                mwtidd @Neuromystix
                                @neuromystix your work has been awesome. Thank you so much for your efforts. In running some test logs earlier today, I found that I got a series of fixes logged that were "invalid". Upon reviewing you code the protocol documents, I have one update to propose
                                    valid = gngga_s[6]
                                    if valid == '0':
                                        return False
                                        return True
                                Your initial fix quality function only returned true if gngga_s[6] was 1, however it seems that values such as 2 or 3 may be valid as well.
                                Per v2.2 of the protocol spec:
                                Value Description
                                0 Fix not available or invalid
                                1 GPS SPS Mode, fix valid
                                2 Differential GPS, SPS Mode, fix valid
                                3 GPS PPS Mode, fix valid
                                Once again, thanks for your efforts. Just wanted to share my findings.
                                • N Offline
                                  Neuromystix @mwtidd
                                  @mwtidd When i wrote it i was reading the "Quectel l76 Series GNSS protocol Specification V3.3" which says (@page 12):
                                  Fix Status
                                  "0"=Invalid
                                  "1"=GNSS fix
                                  "2"=DGPS fix
                                  "6"=Estimated (dead reckoning) mode
                                  That's why i only used "1". But even with that, we can use the value "2" for the DGPS fix. I haven´t checked if i had some fixes "2" ou another values. If it worked for you, nice ;)
                                  Best regards
                                  Nelson Pinto
                                    stefan85e @bmarkus
                                    @bmarkus said in Pytrack GPS API:
                                    • number of satellites visible /used for fix - Is this possible yet?!
                                    • N Offline
                                      Neuromystix @stefan85e
                                      @stefan85e If you need the number of satellites used to fix, it's already parsed in l76.coordinates1(). The "Satellites in view" i haven't done it, but it's easy to implement, just parse any $__GSV sentence, the third field is "Satellites in view".
                                        stefan85e @Neuromystix
                                        l76.coordinates1()
                                        Sorry did not udnerstand that :)
                                          andrethemac
                                          Hi all. I've taken the original librarya and @Neuromystix addtions and made my own library. It parses aml the sentences from the L76 gps and returns them as a dict. you can get the coordinates parsed, the time, ...
                                          https://github.com/andrethemac/L76GLNSV4
                                          I've noticed one (strange?) thing. the RMC (required minimum data to get a fix) message only pass once (just after starting the gps) and does not reappear. Any idea's ?
                                          best regards
                                            L76GNSS.py
                                            So what did you do to get the nimber of satellites? We are trying this and we cant get it to work.
                                            • 1
                                            • 2
                                            • 3
                                            • 1 / 3
