<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] RF switch questions]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
<p dir="auto">I'm trying to figure out how to work with the external antenna. There's the RF switch which can be triggered with a <code>WiFi(antenna=WLAN.EXT_ANT)</code> but I'm trying to figure out what is happening since I switch back and forth between the Pycom firmware and ESP32 IDF firmware running C/C++.</p>
<p dir="auto">Looking at the reference design I cannot quite figure out which pin is set to high/low to activate the switch. Looking at a  <a href="http://www.pighixxx.com/test/portfolio-items/wipy/#prettyPhoto%5Bgallery1434%5D/0/" target="_blank" rel="noopener noreferrer nofollow">Pighixxx scematic</a> it should be the GPIO16 on the chip.</p>
<p dir="auto">Could someone shed some light?</p>
<p dir="auto">Thanks,<br />
Martijn</p>
]]></description><link>https://forum.pycom.io/topic/1749/solved-rf-switch-questions</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 21:05:57 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/1749.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 30 Aug 2017 14:54:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] RF switch questions on Wed, 30 Aug 2017 18:52:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi there,</p>
Martijn</p>
]]></description><link>https://forum.pycom.io/post/10722</link><guid isPermaLink="true">https://forum.pycom.io/post/10722</guid><dc:creator><![CDATA[Smeedy]]></dc:creator><pubDate>Wed, 30 Aug 2017 18:52:14 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] RF switch questions on Wed, 30 Aug 2017 15:31:21 GMT]]></title><description><![CDATA[<p dir="auto">Correct, it is GPIO16</p>
<p dir="auto">Source: <a href="https://github.com/pycom/pycom-micropython-sigfox/blob/dd8a99215d768ce6ba1a0cdbf53ae576dac44338/esp32/main.c#L109" target="_blank" rel="noopener noreferrer nofollow">https://github.com/pycom/pycom-micropython-sigfox/blob/dd8a99215d768ce6ba1a0cdbf53ae576dac44338/esp32/main.c#L109</a></p>
]]></description><link>https://forum.pycom.io/post/10723</link><guid isPermaLink="true">https://forum.pycom.io/post/10723</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Wed, 30 Aug 2017 15:31:21 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] RF switch questions on Wed, 30 Aug 2017 15:56:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a> Yes. Perfect. Thanks for the pointer.</p>
]]></description><link>https://forum.pycom.io/post/10725</link><guid isPermaLink="true">https://forum.pycom.io/post/10725</guid><dc:creator><![CDATA[Smeedy]]></dc:creator><pubDate>Wed, 30 Aug 2017 15:56:43 GMT</pubDate></item></channel></rss>
