guru meditation error (Lopy firmware version 1.8.0.b1)
  • H!, i've succesfully implemented both nanogateway and node functionality from [https://github.com/franckalbinet/iot-smr3128-ictp/blob/master/labs/lorawan-nano-gateway.md] on my two lopys (firmware 1.8.0.b1), but after some seconds/minutes , the nanogateway crashes and reset, giving a lot of messages related to guru meditation errors like the following. I've seen from other entries that it is not a new issue, but i could not find a fix to it. could anyone help me on this?. thanks
    Guru Meditation Error of type LoadProhibited occurred on core 0. Exception was unhandled.
    Register dump:
    PC : 0x4008799d PS : 0x00060033 A0 : 0x80088f37 A1 : 0x3ffe2990
    A2 : 0x3ffe29f0 A3 : 0x3ffe29c0 A4 : 0x00000020 A5 : 0x3ffc48b8
    A6 : 0x00001b7b A7 : 0x3ffe2f90 A8 : 0x3ff40000 A9 : 0x0000007d
    A10 : 0x00000002 A11 : 0x3ffe2da0 A12 : 0x8008b298 A13 : 0x3ffe2d90
    A14 : 0x3ffe2dc0 A15 : 0x00000020 SAR : 0x0000001c EXCCAUSE: 0x0000001c
    EXCVADDR: 0x00001b7f LBEG : 0x4000c2e0 LEND : 0x4000c2f6 LCOUNT : 0x00000000
    Backtrace: 0x4008799d:0x3ffe2990 0x40088f34:0x3ffe29c0 0x4008b295:0x3ffe29f0 0x4008b60a:0x3ffe2bc0 0x4008af15:0x3ffe2c00 0x4008b090:0x3ffe2c80 0x40081686:0x3ffe2ca0 0x4008799a:0x3ffe2d60 0x4008799a:0x3ffe2d90 0x4008b295:0x3ffe2dc0 0x4008b60a:0x3ffe2f90 0x4008af15:0x3ffe2fd0 0x4008b090:0x3ffe3050 0x40081686:0x3ffe3070 0x4008799a:0x3ffe3130 0x4008799a:0x3ffe3160 0x4008b295:0x3ffe3190 0x4008b60a:0x3ffe3360 0x4008af15:0x3ffe33a0 0x4008b090:0x3ffe3420 0x40081686:0x3ffe3440 0x4008799a:0x3ffe3500 0x4008799a:0x3ffe3530 0x4008b295:0x3ffe3560 0x4008b60a:0x3ffe3730 0x4008af15:0x3ffe3770 0x4008b090:0x3ffe37f0 0x40081686:0x3ffe3810 0x4008799a:0x3ffe38d0 0x4008799a:0x3ffe3900 0x4008b295:0x3ffe3930 0x4008b60a:0x3ffe3b00 0x4008af15:0x3ffe3b40 0x4008b090:0x3ffe3bc0 0x40081686:0x3ffe3be0 0x4008799a:0x3ffe3ca0 0x4008799a:0x3ffe3cd0 0x4008b295:0x3ffe3d00 0x4008b60a:0x3ffe3ed0 0x4008af15:0x3ffe3f10 0x4008b090:0x3ffe3f90 0x40081686:0x3ffe3fb0 0x4008799a:0x3ffe4070 0x4008799a:0x3ffe40a0 0x4008b295:0x3ffe40d0 0x4008b60a:0x3ffe42a0 0x4008af15:0x3ffe42e0 0x4008b090:0x3ffe4360 0x40081686:0x3ffe4380 0x4008799a:0x3ffe4440 0x400879┬Žets Jun 8 2016 00:22:57
    rst:0x9 (RTCWDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    mode:DIO, clock div:1
    load:0x3fff9010,len:12
    ho 0 tail 12 room 4
    load:0x3fff9020,len:388
    load:0x40078000,len:11584
    load:0x4009fb00,len:848
    entry 0x4009fc9c
  • This error refers to a old firmware version, have you updated to the latest firmware?
  • I am experiencing the same error with the "advantage" that the gateway actually works after the reboot!
    did you find the solution?
