lora.stats() returns all zeros
  • I have a LoPy device joined to a Multitech Condiut Gateway. I'm able to send messages to the gateway.
    lora.stats() returns all zeros:
    >>> lora.stats()
    (rx_timestamp=0, rssi=0, snr=0.0, sfrx=0, sftx=0, tx_trials=0)
    >>> lora.has_joined()
    True
    >>> os.uname()
    (sysname='LoPy', nodename='LoPy', release='1.9.2.b2', version='v1.8.6-796-g489fafa0 on 2017-10-15', machine='LoPy with ESP32', lorawan='1.0.0')
    Statistics from the gateway
       "code" : 200,
       "result" : {
          "stats_loraNodes" : [
                "class" : "A",
                "devEui" : "70-b3-d5-49-96-4f-7b-0d",
                "dropped" : 0,
                "joined" : "2017-10-30 13:01:36",
                "nodeAddr" : "00:00:00:02",
                "pkts1st" : 28,
                "pkts2nd" : 0,
                "pktsDown" : 28,
                "pktsUp" : 5454,
                "rssiAvg" : -84,
                "rssiMax" : -18,
                "rssiMin" : -120,
                "seqNum" : 50,
                "snrAvg" : 5.2000000000000002,
                "snrMax" : 11.5,
                "snrMin" : -8.5
       "status" : "success"
    Do I need to do something to get statistics from the LoRa radio?
    Thank you.
  • @iosman123 said in lora.stats() returns all zeros:
    For flash erase, you too have to connecte G23 to GND and pusg reset.
    Erasing flash and reload should always work, as long as the device is not physically damaged. . . Thanks
    thanks my issue has been fixed.
  • For flash erase, you too have to connecte G23 to GND and pusg reset.
    Erasing flash and reload should always work, as long as the device is not physically damaged. Thanks
  • @jmarcelino Ah....thank you. I was only transmitting.
  • @agallo
    You need to receive a packet - using lora.recv(...), also called a downlink - first in order to get stats
