L01 wakeup reason missing GPIO pin
On L01 OEM after wake up with interrupt pin (eq. P18 or P15) , machine.wake_reason() is getting OK the reason (PIN_WAKE) but with EMPTY LIST !!! If you have more than 1 pin that is configured to wake up, you don't know which pin wake up the machine from deepsleep.
in main.py I call
print(">>>>>> Reset reason", machine.reset_cause()) print(">>>>>> Wakeup reason", machine.wake_reason())
and output is:
>>>>>> Reset reason 3 >>>>>> Wakeup reason (1, [])
Any fix on this issue?
