<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powering the LoPy with 2 AA batteries?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I wan't to power the LoPy with 2 AA (or AAA) batteries.. I was wondering if it might be possible to power it directly on the 3V3 pin ? (<strong>Pycom note: DO NOT POWER THE LoPY from the 3.3V pin, that pin is only output</strong>) The ESP32 should work down to 2.3V as far as I understand, how about the rest of the hardware? Disclaimer; I'm not an electronics expert, so please bear with me if this is a completely stupid question. :)</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.pycom.io/topic/2088/powering-the-lopy-with-2-aa-batteries</link><generator>RSS for Node</generator><lastBuildDate>Wed, 14 Oct 2026 22:45:41 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2088.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Nov 2017 09:20:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 10:44:23 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
]]></description><link>https://forum.pycom.io/post/12398</link><guid isPermaLink="true">https://forum.pycom.io/post/12398</guid><dc:creator><![CDATA[mahe]]></dc:creator><pubDate>Fri, 19 Jan 2018 10:44:23 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Mon, 06 Nov 2017 10:29:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1811">@mahe</a><br />
First 3V3 pin is output only, do not use it for powering board.<br />
Instead of use 5V pin, it have feature to baypass regulator if voltage is small (if less then 3.4 V and have voltage drop &lt;60mV)<br />
and i wonder if 3V will be enought then.</p>
]]></description><link>https://forum.pycom.io/post/12401</link><guid isPermaLink="true">https://forum.pycom.io/post/12401</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Mon, 06 Nov 2017 10:29:27 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Mon, 06 Nov 2017 11:20:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1811">@mahe</a> You can run the LOPY from the Vin pin reliably down to 3V. But AA batteries are not good. Two AA would supply between 3.2 down to 2 V, and at the current the LoPy daws the voltage would almost all the time below 3V. If you want to do that, you should place an buck converter in between, like the Pololu S7v8F3 Step-Up/Step Down converter, which provides 3.3V output for an input range of 2.7-11.8V, which give you a lot of freedom for supplying.  So you could also use 3 or 4 AA's, 3 or 4 NiMH batteries,  or a single Li-Battery or LiIon rechargaeble battery.</p>
]]></description><link>https://forum.pycom.io/post/12402</link><guid isPermaLink="true">https://forum.pycom.io/post/12402</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Mon, 06 Nov 2017 11:20:03 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Mon, 06 Nov 2017 12:13:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> Thanks! Just to be clear: when you say the Vin pin, it's the 5V on the pin out? <a href="https://docs.pycom.io/chapter/datasheets/downloads/lopy-pinout.pdf" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/chapter/datasheets/downloads/lopy-pinout.pdf</a> . How about just connecting 3 AA batteries directly to this, avoiding the converter?</p>
]]></description><link>https://forum.pycom.io/post/12405</link><guid isPermaLink="true">https://forum.pycom.io/post/12405</guid><dc:creator><![CDATA[mahe]]></dc:creator><pubDate>Mon, 06 Nov 2017 12:13:51 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 29 Dec 2017 20:41:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1811">@mahe</a> Yes, that's the 5V Pin. It has an suitable range of &lt;3V - 5.5 V. And yes. you can use 3 AA's there (or a single LiIon cell, or 4 NiMh batteries), as long as the input voltage does not exceed 5.5V. I would add a large capacitor (like 4700µF) close to the input to ensure a high current availability for short power drain peaks, especially when the batteries are low.</p>
]]></description><link>https://forum.pycom.io/post/12406</link><guid isPermaLink="true">https://forum.pycom.io/post/12406</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 29 Dec 2017 20:41:58 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 10:13:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1811">@mahe</a> <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a>  Hi Guys, I want to run a LoPy off AA batteries too so I followed your advice Robert and implemented a Pololu S7v8F3 converter. I got it working this morning and it seems to work very nicely. My voltmeter says it's 6.6v on the output of my 4 cell AA battery holder but it's 3.3v on the output from the converter. I wired that output into GND and 3V3 on the LoPy and it started working straight away. Very nice, thanks for the info.<br />
Cheers<br />
Jason.</p>
]]></description><link>https://forum.pycom.io/post/14744</link><guid isPermaLink="true">https://forum.pycom.io/post/14744</guid><dc:creator><![CDATA[JasonTimmins]]></dc:creator><pubDate>Fri, 19 Jan 2018 10:13:12 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 10:23:45 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, that said, things are getting pretty hot! The batteries are warm and the converter is too hot to touch. Is that normal? My device would cook if I closed the lid... and who knows how long the batteries will last.</p>
]]></description><link>https://forum.pycom.io/post/14746</link><guid isPermaLink="true">https://forum.pycom.io/post/14746</guid><dc:creator><![CDATA[JasonTimmins]]></dc:creator><pubDate>Fri, 19 Jan 2018 10:23:45 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 10:43:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1585">@jasontimmins</a> NEVER connect teh power supply to the 3v3 V Pin of LoPy.- That is an OUTPUT, not an input. Always supply through Vin. Even if it tells 3.4 .. 5.5V, it works well at 3.3V.</p>
]]></description><link>https://forum.pycom.io/post/14747</link><guid isPermaLink="true">https://forum.pycom.io/post/14747</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 19 Jan 2018 10:43:32 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 10:36:30 GMT]]></title><description><![CDATA[<p dir="auto">Oh, well, my four AA batteries were flattened in ~30 minutes... that's hardly my glittering dream of ultra low power remote sensing! &lt;mutter&gt;</p>
]]></description><link>https://forum.pycom.io/post/14748</link><guid isPermaLink="true">https://forum.pycom.io/post/14748</guid><dc:creator><![CDATA[JasonTimmins]]></dc:creator><pubDate>Fri, 19 Jan 2018 10:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 10:41:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1585">@jasontimmins</a> There is simething wrong. The capacity of a AA battery is about 2500 mAh. The supply current of LoPy is like 200 mA, so it should last about 10 hours. BUT, primary batteries have a lousy high current behavior. Better use NiMh rechargable batteries.<br />
And again: The high current could have been caused by the wrong wiring of the LoPy. The Vin to 3.3V regulator on the LoPy could have been killed, at which point it consumes a lot of current.</p>
]]></description><link>https://forum.pycom.io/post/14749</link><guid isPermaLink="true">https://forum.pycom.io/post/14749</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 19 Jan 2018 10:41:18 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 10:56:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> OK, great advice. I'll try it again. [Can you smell burning? ;-)]</p>
]]></description><link>https://forum.pycom.io/post/14751</link><guid isPermaLink="true">https://forum.pycom.io/post/14751</guid><dc:creator><![CDATA[JasonTimmins]]></dc:creator><pubDate>Fri, 19 Jan 2018 10:56:08 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the LoPy with 2 AA batteries? on Fri, 19 Jan 2018 14:31:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> Things are much better now it's wired correctly! :-) The batteries and the converter have been at room temperature for the last few hours and my LoPy and sensor are working fine. Thanks again for your help Robert.</p>
]]></description><link>https://forum.pycom.io/post/14763</link><guid isPermaLink="true">https://forum.pycom.io/post/14763</guid><dc:creator><![CDATA[JasonTimmins]]></dc:creator><pubDate>Fri, 19 Jan 2018 14:31:17 GMT</pubDate></item></channel></rss>
