<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bricked device.]]></title><description><![CDATA[<p dir="auto">I've had a number of problems with the 4 SyPy boards I have, especially with updating the firmware. One in particular has persisted in refusing to update using the bash script. I tried updating with a Windows machine and it appeared to work but now the device has a permanent red LED.<br />
I tried using the Windows update again, and again it appeared to work, but I still have the red LED.<br />
Is this completely bricked now?</p>
]]></description><link>https://forum.pycom.io/topic/2090/bricked-device</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 23:06:06 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2090.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Nov 2017 11:35:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bricked device. on Mon, 06 Nov 2017 13:48:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robert-hh" aria-label="Profile: robert-hh">@<bdi>robert-hh</bdi></a> I had to connect G23 with GND as per the update process. The update failed 3 more times with the bash script but the last one using windows seems to have worked.<br />
Someone needs to work on the bash script!<br />
Many thanks for the help.</p>
]]></description><link>https://forum.pycom.io/post/12408</link><guid isPermaLink="true">https://forum.pycom.io/post/12408</guid><dc:creator><![CDATA[alidaf]]></dc:creator><pubDate>Mon, 06 Nov 2017 13:48:34 GMT</pubDate></item><item><title><![CDATA[Reply to Bricked device. on Mon, 06 Nov 2017 13:26:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robert-hh" aria-label="Profile: robert-hh">@<bdi>robert-hh</bdi></a> I get an error: A fatal error occurred: Failed to connect to Espressif device: Timed out waiting for packet header. The LED is now yellow.</p>
]]></description><link>https://forum.pycom.io/post/12407</link><guid isPermaLink="true">https://forum.pycom.io/post/12407</guid><dc:creator><![CDATA[alidaf]]></dc:creator><pubDate>Mon, 06 Nov 2017 13:26:57 GMT</pubDate></item><item><title><![CDATA[Reply to Bricked device. on Mon, 06 Nov 2017 11:43:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alidaf" aria-label="Profile: alidaf">@<bdi>alidaf</bdi></a> If the device shows a red LED then it still works, but just the firmware configuration is messed up. Try to erase the flash completely and re-load the device. Erasing is done with <a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a>, V2.01. Prepare the device like you would to uploading: connect G23 to GND and push reset. The command is:</p>
<p dir="auto">python <a href="http://esptool.py" target="_blank" rel="noopener noreferrer nofollow ugc">esptool.py</a> -p &lt;your_com_port&gt; -b 460800 erase_flash</p>
<p dir="auto">After that, you should be able to re-flash the device.</p>
]]></description><link>https://forum.pycom.io/post/12404</link><guid isPermaLink="true">https://forum.pycom.io/post/12404</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Mon, 06 Nov 2017 11:43:19 GMT</pubDate></item></channel></rss>
