    Simple MQTT Tutorial
    34 Posts 13 Posters 30.4k Views 16 Watching
    • M Offline
      MrPy
      Hi All,
      Figured this code may help those relatively new to Pycom/Micropython/MQTT. It's a simple way to quickly get Mqtt publishing on your WiPy or LoPy board. I used the Hive Mq broker for demo purposes:
      http://www.hivemq.com/demos/websocket-client/
      1. Make sure the WiPy is connected over serial to Pymakr ( sometimes restarting Pymakr gets things going if it can't detect it).
      2. Download the UMQTT Library that is available here: https://pypi.python.org/pypi/micropython-umqtt.simple and open simply.py
      The library on the whole is pretty good, but there is a bug on line 57. Make sure to change:
      self.settimeout(self.timeout)
      To
      self.sock.settimeout(self.timeout)
      Go ahead and save the Library but rename it so umqtt instead of simple.py
      1. Open Pymakr to start building your main script. Create a new project (Mqtttest or whatever)
      from network import WLAN
      from umqtt import MQTTClient
      def settimeout(duration):
           pass
      wlan = WLAN(mode=WLAN.STA)
      wlan.antenna(WLAN.EXT_ANT)
      wlan.connect("yourwifinetwork", auth=(WLAN.WPA2, "wifipassword"), timeout=5000)
      while not wlan.isconnected():
           machine.idle()
      print("Connected to Wifi\n")
      client = MQTTClient("joe", "broker.hivemq.com", port=1883)
      client.settimeout = settimeout
      client.connect()
           print("Sending ON")
           client.publish("/lights", "ON")
           print("Sending OFF")
           client.publish("/lights", "OFF")
      After inputting your WIFI and broker details, go ahead and choose a publish topic of your choice, along with a message
      1. Almost ready to give it a try! Next connect to your WiPy over WIFI and FTP into the /lib folder. I use Fillezilla for this. Upload our renamed library umqtt to the /lib folder on the board.
      2. Make sure the WiPy is connected over serial to Pymakr ( again a restart may help this). Then hit the play button to upload your script to the board . You should see the Wifi connected printed in the console, and then the while loop commence.
      alt text
      Go back to http://www.hivemq.com/demos/websocket-client/ and subscribe to your topic, and you should see the messages start coming in on the broker.
      alt text
      Bit of a dummies guide but hope this helps some people!
      G 1 Reply Last reply Reply Quote 2
      • V Offline
        vruizvil
        The code works fine on my lopy (release 0.9.1.b1) to connect broker.hivemq.com, but it doesn't work to connect test.mosquitto.org. I have a mosquitto broker on local machine, but...... not working. Please, help about this issue. Thanks.
          thibault
          My try was successful with this on debian:
          https://pallavichaurasia94.wordpress.com/2014/10/14/mosquitto-in-debian/
          for install MQTT brockers.
          On the lopy i use this initialisation:
          def settimeout(duration): pass
          client = MQTTClient("joe", "192.168.4.2", port=1883)
          client.connect()
          that give me the possibility to publish fine on my brockers with the command:
          client.publish("hello/world", "My publication")
          I have make some try to basic read brocker's data from lopy, We need to define a function who have been called if message are find:
          def t3_publication(topic, msg):
              print (topic, ':', msg)
              pycom.rgbled(0xff00)
          and assign it:
          client.set_callback(t3_publication)
          now we can subscribe to the desired channel:
          client.subscribe("hello/world", qos=1)
          I put data to the MQTT brockers from another terminal (localhost from brocker's server) mosquitto_pub -d -t hello/world -m "Hello, MQTT. This is my first message.", and i launch the check of the brocker's message from lopy by:
          client.check_msg()
          That's print message in channel, and set led to green (who's been reset by the heartbeat).
          I hope that will help you.
          • M Offline
            MrPy
            Hmmm, do you have your Mosquito broker details to hand to i can test?
            I usually have a node-red instance running that connects to my broker so i can quickly test if the broker is up or down. A few of these public test brokers are not that stable so 9/10 it's the broker being down that causes my issues.
              thibault
              Sorry i don't speak very well english, so i hav'nt really understand what you says exactly. But i mean you want data about the different version
              I have use the pycom_update_0.9.3.b2 on the lopy. And for the mosquitto the version is 1.3.4-2. I'm begin in the IoT world, and maybe i have too few knowledge in it for understand you. If i have not answer that you wait, feel good about explain another way.
              • M Offline
                MrPy @thibault
                @thibault My apologies, I was replying to vruizil below.
                • V Offline
                  vruizvil
                  Well, thanks a lot for the comments.
                  After uppgrade recent firmware, the code works fine connecting mosquitto broker.
                  But, I can't connect two differents sockets with two differentes brokers at same time.
                  It needs run .disconnect() function to be abel to use the other one broker.
                  I don't know the reason....., well, I'am not a python expert.
                  # Initialize MQTT Client
                  	print (topic, ';', msg)
                  UNIQUE_ID = machine.unique_id()
                  MQTT_BROKER = "192.168.2.220"
                  MQTT_PORT = 1883
                  mqtt_client = MQTTClient(UNIQUE_ID, MQTT_BROKER, port=MQTT_PORT)
                  mqtt_client.settimeout = settimeout
                  mqtt_client.set_callback(t3_publication)
                  mqtt_client.connect()
                  MQTT_BROKER_2 = "test.mosquitto.org"
                  #MQTT_PORT = 1883
                  mqtt_client2 = MQTTClient(UNIQUE_ID, MQTT_BROKER_2, port=MQTT_PORT)
                  mqtt_client2.settimeout = settimeout
                  mqtt_client2.set_callback(t3_publication)
                  mqtt_client2.connect()
                  • M Offline
                    MainSheet
                    Dummy question,
                    I have the code on my LoPy working :
                    from simple import MQTTClient
                    import  time
                    client = MQTTClient("MainSheet", "broker.hivemq.com", port=8000)
                    client.connect()
                        print("Sending ON")
                    output is this
                    connected with goofy, channel 1
                    Sending ON
                    Sending OFF
                    Sending ON
                    Sending OFF
                    Sending ON
                    Sending OFF
                    Sending ON
                    Sending OFF
                    Sending ON
                    Sending OFF
                    Connecting to http://www.hivemq.com/demos/websocket-client/? with Chrome
                    Host = broker.hivemq.com
                    ClientID = MainSheet
                    Port = 8000. ( I tried setting the port to 1883 but then I can't connect to hivemq. I also tried to set the code above to connect to port 8000, however, got an out of range error)
                    subscribed to /lights
                    however, the messages never get through to HiveMQ
                    Steve
                    V G 2 Replies Last reply Reply Quote 0
                    • V Offline
                      vruizvil @MainSheet
                      @MainSheet said in Simple MQTT Tutorial:
                      broker.hivemq.com
                      Try client.disconnect(), then client.connect(). Try on firefox, it works fine in my tests, and try another topic (without slash), ie.: "mylopytopic"
                      V 1 Reply Last reply Reply Quote 0
                      • V Offline
                        vruizvil @vruizvil
                        @vruizvil
                        For Windows, I use MQTTFX Client. Here the link
                        http://www.jensd.de/apps/mqttfx/
                          gertjanvanhethof Pybytes Beta @MainSheet
                          @MainSheet I'am not able to connect.
                          What do I wrong?
                          In my main.py I setup the wifi connection successfully.
                          I checked that by doing an http get call and I was able to get HTML data from a website. So internet connection is working.
                          I went to: http://www.hivemq.com/demos/websocket-client/
                          And created a connection with the following details:
                          Host: broker.hivemq.com
                          Port: 8000
                          ClientID: MyLoPy
                          I created a subscription and tested some messages. All works.
                          Then I typed the following commands on my LoPy:
                          MicroPython v1.8.6-40-gd10463e on 2016-11-25; LoPy with ESP32
                          client = MQTTClient("MyLoPy", "broker.hivemq.com", port=8000)
                          client.connect()
                          0xc b'10:12:00:04:4d:51:54:54:04:02:00:00'
                          File "umqtt.py", line 86, in connect
                          IndexError: bytes index out of range
                          • V Offline
                            vruizvil @gertjanvanhethof
                            @gertjanvanhethof Hi!, try with machine.reset(), then try your code one more time, you need only one client socket, when you try few times the code, I think the socket doesn't work fine. That is the way to solve the same problem in my tests, but I don't know the reason.
                              gertjanvanhethof Pybytes Beta @vruizvil
                              @vruizvil
                              My code is as following:
                              def connect():
                              if machine.reset_cause() != machine.SOFT_RESET:
                              client = MQTTClient("MyLoPy", "broker.mqttdashboard.com", port=8000)
                              client.connect()
                              print('Connected MQTT Broker.')
                              return client
                              def send(client):
                              print("Sending ON")
                              client.publish("/lopy", "ON")
                              client.publish("/lopy", "OFF")
                              I do a connect() and the result is as following:
                              client.connect()
                              Still going wrong. What could be the solution?
                                gertjanvanhethof Pybytes Beta @MrPy
                                @MrPy Are you sure those are you messages? I checked and somebody else was publishing these messages.
                                  gertjanvanhethof Pybytes Beta @gertjanvanhethof
                                  I found the error. The port is wrong.
                                  It should be: 1883.
                                  Then connect is working.
                                    gas @vruizvil
                                    @vruizvil Hi
                                    I started a mosquitto on my laptop (vm debian) and it is working with the code as it is i updated it a little to make it configurable via config param file (wifi and mqtt)
                                    what error you are getting ?
                                      gertjanvanhethof Pybytes Beta @gas
                                      @gas It's working now. The used port was wrong. Thxs for your help.
                                      • R Offline
                                        RSK
                                        MQTTClient is missing in the latest firmware, using the image release on 02/Dec/2016.
                                        Could someone confirm this.
                                        0_1481092220727_upload-95d4b814-1a49-47db-b229-f9092eb4c7e0
                                          sakis @RSK
                                          @RSK umqtt is not part of Pycom's firmware or standard micropython. It is an external Python library, so to be able to use it you need to upload it to your device.
                                          The easiest way to do that is using Pymakr. Another way is using plain FTP (https://docs.pycom.io/pycom_esp32/pycom_esp32/general.html#local-file-system-and-ftp-access).
                                          Please read step 2 again and try to follow the instructions. If you have any problems let us know.
                                          • R Offline
                                            RSK
                                            @sakis Thanks!
                                            I have downloaded umqtt.simple.py from https://github.com/micropython/micropython-lib and placed it in /flash/simple.py of the LoPy using FTP.
                                            And trying to connect from my LoPy application:
                                            0_1481109485470_upload-f0cd9d87-92ef-4d6a-8a64-b3240df41eb4
                                            With Hive settings:
                                            0_1481109531558_upload-397a9e59-4d48-495d-9538-b57cf969c284
                                            But connect fails with error "bytes index out of range":
                                            0_1481109598988_upload-974ac761-263f-4c25-8604-d9a97e83b289
                                            Please help to resolve.
                                            Thanks & Regards,
                                            Satish Kumar. R.
                                            • 1
                                            • 2
                                            • 1 / 2
