<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] TTN Gateway status not connected for LoRaWAN]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I have been trying to follow the instructions for LoraWAN Gateway as here:<br />
<a href="https://github.com/franckalbinet/iot-smr3128-ictp/blob/master/labs/lorawan-nano-gateway.md" target="_blank" rel="noopener noreferrer nofollow">https://github.com/franckalbinet/iot-smr3128-ictp/blob/master/labs/lorawan-nano-gateway.md</a></p>
<p dir="auto">I am not having much luck and not sure why. I am in Australia and I am using the meshed network, labelling it in my <a href="http://config.py" target="_blank" rel="noopener noreferrer nofollow">config.py</a> as <a href="http://router.thethings.meshed.com.au" target="_blank" rel="noopener noreferrer nofollow">router.thethings.meshed.com.au</a>. I am connecting via mobile hotspot (If anyone knows how to connect to eduroam that would also be very helpful) and it connects and even shows a connection on my phone. The REPL seems to indicate that I have connected to the LoraWAN nano gateway however nothing is happening on the things network gateway overview.</p>
<p dir="auto">I have googled through other people having the same problem at some stages but yet to decipher how they fixed their problem.</p>
<p dir="auto">This is what shows in REPL<br />
<img src="/assets/uploads/files/1510543993322-509ad407-17f8-4831-be28-49db9694494f-image.png" alt="0_1510543992418_509ad407-17f8-4831-be28-49db9694494f-image.png" class="img-responsive img-markdown" /></p>
<p dir="auto">I also had this come up at one stage:<br />
<img src="/assets/uploads/files/1510544071262-5756ae29-d5e5-4226-9019-dfc07d59cabd-image-resized.png" alt="0_1510544070096_5756ae29-d5e5-4226-9019-dfc07d59cabd-image.png" class="img-responsive img-markdown" /></p>
<p dir="auto">When I went out for lunch my hotspot disconnected and I returned to a lot of messages saying Failed to pull/push uplink/downlink packets to/from server 118.</p>
<p dir="auto">Cheers,</p>
<p dir="auto">Dylan</p>
]]></description><link>https://forum.pycom.io/topic/2136/solved-ttn-gateway-status-not-connected-for-lorawan</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 03:32:20 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2136.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 13 Nov 2017 03:37:22 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] TTN Gateway status not connected for LoRaWAN on Mon, 13 Nov 2017 07:41:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
]]></description><link>https://forum.pycom.io/post/12644</link><guid isPermaLink="true">https://forum.pycom.io/post/12644</guid><dc:creator><![CDATA[Dylan]]></dc:creator><pubDate>Mon, 13 Nov 2017 07:41:25 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] TTN Gateway status not connected for LoRaWAN on Mon, 13 Nov 2017 06:46:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1980">@dylan</a><br />
Why are you using the Meshed router? I’m not familiar with that option.</p>
<p dir="auto">The official TTN router for Australia is <code>router.au.thethings.network</code> have you tried it?</p>
]]></description><link>https://forum.pycom.io/post/12647</link><guid isPermaLink="true">https://forum.pycom.io/post/12647</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Mon, 13 Nov 2017 06:46:38 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] TTN Gateway status not connected for LoRaWAN on Mon, 13 Nov 2017 06:47:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a> I did see that around but it doesn't come up in the list of routers on The Thing Network Gateway setup, I saw somewhere that someone used the meshed network, made sense as the address ends in a .au. I'll try router.au.thethings.network and see what happens.</p>
<p dir="auto">Cheers</p>
]]></description><link>https://forum.pycom.io/post/12648</link><guid isPermaLink="true">https://forum.pycom.io/post/12648</guid><dc:creator><![CDATA[Dylan]]></dc:creator><pubDate>Mon, 13 Nov 2017 06:47:25 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] TTN Gateway status not connected for LoRaWAN on Mon, 13 Nov 2017 06:57:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1980">@dylan</a> Instant connection, I left my Gateway on The Things Network as the meshed router, but changed the server in my <a href="http://config.py" target="_blank" rel="noopener noreferrer nofollow">config.py</a> to router.au.thethings.network.<br />
Thank you :).</p>
]]></description><link>https://forum.pycom.io/post/12650</link><guid isPermaLink="true">https://forum.pycom.io/post/12650</guid><dc:creator><![CDATA[Dylan]]></dc:creator><pubDate>Mon, 13 Nov 2017 06:57:27 GMT</pubDate></item></channel></rss>
