Small MQTT Example
  • HI all,
    I am trying to get a small MQTT example running on LoPy (via connecting to Wifi). It seems there is an issue with imports of WLAN or so, I am getting the error that WLAN is not defined. Does anyone know what could be wrong here?
    from mqtt import MQTTClient
    from network import WLAN
    def sub_cb(topic, msg):
    pycom.rgbled(0xff0000)
    pycom.rgbled(0x000000)
    pycom.heartbeat(True)
    wlan = WLAN(mode=WLAN.STA)
    wlan.connect("xxx", auth=(WLAN.WPA2, "xxx"), timeout=5000)
    while not wlan.isconnected():
    machine.idle()
    print("Connected to Wifi\n")
    client = MQTTClient("lopy", "io.adafruit.com",user="hansamann", password="xxx", port=1883)
    client.set_callback(sub_cb)
    client.connect()
    client.subscribe(topic="user/f/button")
  • @seb problems solved - the to_bytes method needs to be called with an additional 'little' parameter (little endian) and during each publish, the check_msg() method needs to be called.... works now.
  • I dont actually have any data going into MQTT I just ran the code you posted above to see if it was an error with parameters like you saw and I managed to subscribe without the error. Have you updated the firmware of the device since you received it as per: https://docs.pycom.io/chapter/gettingstarted/installation/firmwaretool.html ?
  • @seb Strange, I can connect and publish now but no subscription messages arrive.
    I seemd to have an issue with this line in subscribe (of the mqtt client):
    self.sock.write(qos.to_bytes(1))
    It seems to expect two variables, so I figured I can modify it to this:
    self.sock.write(qos.to_bytes(1, sys.byteorder))
    But it does not work - no bug or error, but my callback is not called (I hava a print in there, before I tried to flash the light... both did not work).
    Do I have recently ordered a LoPy and have LoPy1.0r - is that the issue? Is my device old?
  • @hansamann said in Small MQTT Example:
    machine.idle()
    client.connect()
    I just tried out accessing adafruit IO with your code and it worked fine for me. I got the mqtt library from here https://raw.githubusercontent.com/pycom/pycom-libraries/master/lib/mqtt/mqtt.py
    Just to note I changed my topic to be 'username/feeds/test' rather than '/f/' like you have.
  • thx, @misterlisty but I checked your code and most likely my mqtt.py is somehow broken. I've taken it from github, so I hope it is current.
    client = MQTTClient("wipy2", "io.adafruit.com",user="hansamann", password="xxx", port=1883)
    client.connect()
    client.subscribe(topic="hansamann/f/button")
    This creates an error on line 139 of mqtt.py (see below). Sorry I am quite new to python, I cannot see what is wrong. QOS is optional and defaults to 0, so why does it not work?
    TypeError: function missing 1 positional arguments
        def subscribe(self, topic, qos=0):
            assert self.cb is not None, "Subscribe callback is not set"
            pkt = bytearray(b"\x82\0\0\0")
            self.pid += 1
            struct.pack_into("!BH", pkt, 1, 2 + 2 + len(topic) + 1, self.pid)
            #print(hex(len(pkt)), hexlify(pkt, ":"))
            self.sock.write(pkt)
            self._send_str(topic)
            self.sock.write(qos.to_bytes(1)) #line 139
            while 1:
                op = self.wait_msg()
                if op == 0x90:
                    resp = self.sock.read(4)
                    #print(resp)
                    assert resp[1] == pkt[2] and resp[2] == pkt[3]
                    if resp[3] == 0x80:
                        raise MQTTException(resp[3])
                    return
  • 1_1510902349073_main.py 0_1510902349072_boot.py
    Happy to share my code and welcome any feedback.
    Features:
    Ability to re-connect if wifi disconnects.
    Disable mqtt if not connected to internet
    Ability to re-connect to alternate wifi if the primary one dies.
    Includes a watchdog to ensure its always connected
    You can send it PON/POFF command to toggle a pin out thru mqtt
    Constantly sends an ON/OFF msg to the mqtt broker
    Enjoy, happy to help the community..i'm learning also
    Maybe ill put it on github if anyone is interested, we can improve as a community...
  • @hansamann
    will be better to provide whole error message
    and please format code sourouding it with triple ```
