Failed to connect (GetOverlappedResult)
  • Hello,
    I am having a strange issue with a new board we made.
    This board is using the Lopy and a USB to serial dongle with a CP2101.
    I am able to connect to the new board and get the REPL.
    This new board was even able to flash the Lopy to a new version 1.10.2.b1
    The editor I am using is Atom and the pymkr plug in.
    The issue I get is when I want to upload a project to the new board.
    Has anyone seen this before and how can I fix it?
    Thanks,
  • @ralph sorry I should have realized.
    Thank you,
  • @robd sorry for the confusion, should have clarified that 1.2.2 is the new Pymakr release for atom, not the firmware. VSC is indeed working fine, but this update should fix the upload feature in Atom on windows as well.
  • @ralph thanks, I couldn't find a new firmware version. 1.10.2.b1 was the latest.
    I had to down grade the firmware to 1.9.2.b2 due to LoRa issues. Since down grading the issues I was having went away. Currently I am using Visual Studio Code and it seems to be fine here for sync'ing.
    Thank you,
  • Hi @robd, this issue has been solved just today with release 1.2.2. Try it and let me know if it works!
