Can bus between two pyboards
  • Hi dear friends , I try to communicate two pyboards with CAN bus protocol with micropython but I don`t know where is my problem .
    This is the code to send
    import pyb
    from pyb import CAN,LED
    from pyb import Pin
    #inicializaciones
    led=LED(1)
    control=pyb.Pin(pyb.Pin.cpu.B9,pyb.Pin.OUT_PP)
    control.off()#habilita el pin del trans
    can1=CAN(1,CAN.NORMAL,extframe=False,prescaler=18,sjw=1,bs1=8,bs2=3)
    can1.setfilter(1,CAN.LIST16,0,[0x700,0x701,0x702,0x703],rtr=[0,1,0,0])
    data=b'\x01\x50'
       print('enviando...')
       can1.send(data,id=0x702,timeout=0,rtr=False)
       time.sleep(2)
       print('enviado')
       time.sleep(2)
       control.on()
    and this is the code to receive
    #inicializaciones
    led=LED(1)
       print('Entrando al ciclo')
        if can.any(0):
           a=can1.recv(0)
           print(a)
    The problem is that the second pyboard never receive nothing , I use a transiver MCP2562 . any suggestion?
  • administrators
    I suggest you check out https://forum.micropython.org for support regarding the Pyboard hardware.
  • @erick said in Can bus between two pyboards:
    You are on the wrong forum
    this is forum for pycom boards like wipy, lopy, gypy, fipy
