Round to the nearest float with the correct least significant decimal.
You have all been very naughty!
Look at the following Christmas bug Santa has brought…The problem concerns the builtin function
round()
In its current implementation, rounding is done to the nearest float that can be represented by the machine.
This is wrong, rounding should be done to the nearest float with the correct least significant decimal that can be represented by the machine.Consider the following little
main.py
script:f = 1011.640071 print('\n%f = float' % f) print('%f = float rounded to one decimal' % round(f, 1)) print('%6.1f = formatted rounded float\n' % round(f, 1)) delta = 0.000040 print('%f = float correctly rounded to least significant first decimal' % (round(f, 1) + delta)) print('%6.1f = formatted correctly rounded float\n' % (round(f, 1) + delta)) epsilon = abs(7./3 - 4./3 - 1) print('%f = 1000 × machine epsilon' % (1000 * epsilon)) print(epsilon) print()
Here is the output on a PyBoard:
MicroPython v1.9.2-87-gda8c4c26 on 2017-09-13; PYBv1.1 with STM32F405RG 1011.639952 = float 1011.599898 = float rounded to one decimal 1011.5 = formatted rounded float 1011.600017 = float correctly rounded to least significant first decimal 1011.6 = formatted correctly rounded float 0.000119 = 1000 × machine epsilon 1.192093e-07
Things are not any different on a Pycom LoPy ESP32:
MicroPython 2ac6da2 on 2017-12-18; LoPy with ESP32 1011.639952 = float 1011.599898 = float rounded to one decimal 1011.5 = formatted rounded float 1011.600017 = float correctly rounded to least significant first decimal 1011.6 = formatted correctly rounded float 0.000119 = 1000 × machine epsilon 1.192093e-07
Note that the difference between correct and erroneous rounding is about a 1000 times the machine epsilon, which makes sense.
For certain applications, such poor rounding can have very serious consequences down the line…
This finding may account for the multitude of other reports complaining about
round()
behaviour:- https://forum.micropython.org/viewtopic.php?t=802
- https://github.com/bbcmicrobit/micropython/issues/367
- https://github.com/micropython/micropython/issues/2616
- https://support.microbit.org/support/solutions/articles/19000026098-strange-rounding-error
I also reported this bug here:
