<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PySense not recognised as DFU device]]></title><description><![CDATA[<p dir="auto">Very similar problem to that previously discussed on the PyTrack<br />
Re: <a href="/topic/1817/pytrack-not-recognised-as-dfu-device">PyTrack not recognised as DFU device</a><br />
The thread for the PyTrack did not seem to find a resolution.</p>
<p dir="auto">I am using a RasPi3 and trying to upgrade the firmware on my PySense to pysense_0.0.8.dfu.<br />
On initially connecting the PySense to the RasPi I ran<br />
<strong>dmesg | grep ttyUSB</strong><br />
and it picked up the PySense</p>
<p dir="auto">I then followed the instructions on the Pycom website. Reconnecting the PySense with the button pressed; wait for 1 second, then release and then ran<br />
<strong>dfu-util -D pysense_0.0.8.dfu</strong></p>
<p dir="auto">this returned</p>
<p dir="auto">dfu-util 0.8</p>
<p dir="auto">Match vendor ID from file: 04d8<br />
Match product ID from file: f011<br />
dfu-util: Cannot open DFU device 04d8:f011<br />
dfu-util: No DFU capable USB device available</p>
<p dir="auto">the previous thread had some discussion about drivers.  I am supposed to install something to allow me to upgrade the firmware?</p>
]]></description><link>https://forum.pycom.io/topic/2405/pysense-not-recognised-as-dfu-device</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 05:31:02 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2405.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Jan 2018 01:19:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PySense not recognised as DFU device on Tue, 09 Jan 2018 01:19:57 GMT]]></title><description><![CDATA[<p dir="auto">Very similar problem to that previously discussed on the PyTrack<br />
]]></description><link>https://forum.pycom.io/post/14239</link><guid isPermaLink="true">https://forum.pycom.io/post/14239</guid><dc:creator><![CDATA[philwilkinson]]></dc:creator><pubDate>Tue, 09 Jan 2018 01:19:57 GMT</pubDate></item><item><title><![CDATA[Reply to PySense not recognised as DFU device on Tue, 09 Jan 2018 04:15:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1904">@philwilkinson</a><br />
Sounds like a permissions problem, you probably need to run dfu-util with sudo.</p>
<p dir="auto">sudo dfu-util -D pysense_0.0.8.dfu</p>
<p dir="auto">should work after you enter your password.</p>
]]></description><link>https://forum.pycom.io/post/14245</link><guid isPermaLink="true">https://forum.pycom.io/post/14245</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Tue, 09 Jan 2018 04:15:53 GMT</pubDate></item><item><title><![CDATA[Reply to PySense not recognised as DFU device on Tue, 09 Jan 2018 04:37:30 GMT]]></title><description><![CDATA[<p dir="auto">Oh yes, that would be a good idea...!<br />
Sorry about that. Rather basic error. Apologies but thanks <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a>  for responsing.<br />
Phil</p>
]]></description><link>https://forum.pycom.io/post/14247</link><guid isPermaLink="true">https://forum.pycom.io/post/14247</guid><dc:creator><![CDATA[philwilkinson]]></dc:creator><pubDate>Tue, 09 Jan 2018 04:37:30 GMT</pubDate></item><item><title><![CDATA[Reply to PySense not recognised as DFU device on Mon, 22 Jan 2018 22:22:52 GMT]]></title><description><![CDATA[<p dir="auto">I'm having the same problem but for me using sudo doesn't help.</p>
]]></description><link>https://forum.pycom.io/post/14881</link><guid isPermaLink="true">https://forum.pycom.io/post/14881</guid><dc:creator><![CDATA[regines]]></dc:creator><pubDate>Mon, 22 Jan 2018 22:22:52 GMT</pubDate></item><item><title><![CDATA[Reply to PySense not recognised as DFU device on Mon, 22 Jan 2018 22:30:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2272">@regines</a><br />
Are also seeing “dfu-util: Cannot open DFU device 04d8:f011”?</p>
]]></description><link>https://forum.pycom.io/post/14882</link><guid isPermaLink="true">https://forum.pycom.io/post/14882</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Mon, 22 Jan 2018 22:30:16 GMT</pubDate></item><item><title><![CDATA[Reply to PySense not recognised as DFU device on Wed, 24 Jan 2018 17:25:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a> No, this line doesn't show up here. I only get the first two plus the fourth line.</p>
]]></description><link>https://forum.pycom.io/post/14937</link><guid isPermaLink="true">https://forum.pycom.io/post/14937</guid><dc:creator><![CDATA[regines]]></dc:creator><pubDate>Wed, 24 Jan 2018 17:25:44 GMT</pubDate></item><item><title><![CDATA[Reply to PySense not recognised as DFU device on Thu, 25 Jan 2018 22:23:34 GMT]]></title><description><![CDATA[<p dir="auto">Just received Pysense 1718001136 from Digikey today and connected LoPy 1711004932.<br />
Identical problem with dfu-util not recognizing the Pysense.<br />
Installed on Windows10 the driver using Zadig and selected libusbK as the driver.  Successful.<br />
opened Cmd window and ran dfu-util -D pysense_0.0.8.dfu<br />
the identical 5 line response as above.</p>
<p dir="auto">F:\Development\LoPy&gt;dfu-util-static.exe -D pysense_0.0.8.dfu<br />
dfu-util 0.8</p>
<p dir="auto">Copyright 2005-2009 Weston Schmidt, Harald Welte and OpenMoko Inc.<br />
Copyright 2010-2014 Tormod Volden and Stefan Schmidt<br />
This program is Free Software and has ABSOLUTELY NO WARRANTY<br />
Please report bugs to <a href="mailto:dfu-util@lists.gnumonks.org" target="_blank" rel="noopener noreferrer nofollow">dfu-util@lists.gnumonks.org</a></p>
<p dir="auto">I loaded Atom 1.23.3 x64 and it won't connect with 192.168.4.1 - Connection error: Error: Login timed out</p>
<p dir="auto">I was able to connect to LoPy through the Pysense USB using Tera-Term on Com11 and run micropython.</p>
<p dir="auto">Jun  8 2016 00:22:57<br />
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)<br />
ets Jun  8 2016 00:22:57<br />
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)<br />
configsip: 0, SPIWP:0x00<br />
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00<br />
mode:QIO, clock div:2<br />
load:0x3fff9010,len:8<br />
load:0x3fff9018,len:812<br />
ho 0 tail 12 room 4<br />
load:0x40078000,len:3692<br />
load:0x4009f000,len:944<br />
entry 0x4009f1f0<br />
rtc v134 Oct 20 2016 12:36:18<br />
XTAL 40M<br />
I (818) phy: phy_version: 246, Nov 18 2016, 17:30:07, 0, 0</p>
<p dir="auto">tcpip_task_hdlxxx : 3ffe800c, prio:18,stack:2048<br />
frc2_timer_task_hdl:3ffe9a24, prio:22, stack:2048<br />
I (1514) wifi: pp_task_hdl : 3ffec27c, prio:23, stack:8192<br />
mode : softAP(24:0a:c4:02:5b:bd)<br />
dhcp server start:(ip: 192.168.4.1, mask: 255.255.255.0, gw: 192.168.4.1)<br />
MicroPython v1.8.6-237-g9d21f17 on 2016-12-15; LoPy with ESP32</p>
<p dir="auto">I noticed that the Zadig driver indicates the USB-ID is 04D8 F012   - Not the F011 that dfu is looking for.</p>
<p dir="auto">What next?</p>
]]></description><link>https://forum.pycom.io/post/14982</link><guid isPermaLink="true">https://forum.pycom.io/post/14982</guid><dc:creator><![CDATA[Tombee]]></dc:creator><pubDate>Thu, 25 Jan 2018 22:23:34 GMT</pubDate></item><item><title><![CDATA[Reply to PySense not recognised as DFU device on Sun, 10 Jan 2021 14:20:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a> Thank, with sudo It works !!</p>
]]></description><link>https://forum.pycom.io/post/36410</link><guid isPermaLink="true">https://forum.pycom.io/post/36410</guid><dc:creator><![CDATA[Ali Bakir]]></dc:creator><pubDate>Sun, 10 Jan 2021 14:20:40 GMT</pubDate></item></channel></rss>
