    New firmware release v1.13.0.b1 (Sigfox and LoRa coexistency on the LoPy4)
    firmware
    22 Posts 7 Posters 7.9k Views 7 Watching
      daniel
      This release is mainly about support for the LoPy4. The change log is as follows:
      • esp32: Add LoPy4 support with LoRa and Sigfox on the SX1276
      • esp32: Save the downlink ack flag as part of the LoRaWAN NVRAM parameters.
      • esp32: Only bootstrap the 32KHz RTC clock if enabled with an external crystal. Solves GPIO issues when using both P19 and P20.
      • esp32: Fix os.uname() crash on the FiPy.
      Cheers,
      Daniel
      • X Offline
        Xykon administrators
        UPDATE: During internal testing I discovered a bug where, when you try to update/register more than one Sigfox device for the first time using the restart button, the download seems to take forever when updating the second device. I will upload a bugfix for this as soon as possible.
        UPDATE2: I discovered another problem where registering a new SigFox device fails when using the Linux CLI based firmware update tool. This should now be fixed with a server-side upgrade. If you have been struggling to update your board using this tool, please try again.
        Hello everyone,
        With this firmware update also comes a new firmware update tool 1.1.6.b0
        With this version the installer for Windows and MacOS will consist of only two executables, one which provides the GUI version called pycom-fwtool and another CLI version called pycom-fwtool-cli which replaces the functionality of the previous bin/updater.py file
        It is highly recommended that MacOS users remove the old application completely before installing this new version (or re-installing it if you have it already installed it). This will make sure all the old frameworks are removed which should save a considerable amount of disk space.
        The installer also sees a few other improvements such as server outage detection (sorry if you've seen these earlier today as we moved the database to a new host) and a restart button.
        I've been able to generate .deb and .rpm packages for a Linux version but this needs a few more days of testing before it can be released, so the Linux version currently available just contains the updated python scripts on which the whole updater is built.
        As we changed both the updater and the server infrastructure in a major way today please be patient and report any issues you may encounter. We will try to fix any issues as quickly as possible. Thanks a lot for your understanding.
        Christian Ehlers
        D P X 3 Replies Last reply Reply Quote 2
          duffo64 @Xykon
          @xykon
          Hi and thanks for keeping up.
          One small request: I did not check if in windows and linux it's the same, but on macOS the firmware update utility version number is missing. Please, add it in future releases (I am getting old and Alzheimer strikes hard).
          /Claudio
            peekay123 @Xykon
              pymiom
              HI,
              I am trying the new code, but my FiPy is constantly rebooting with trace errors. I have tried to update/change the firmware on both Windows and Mac, but having the same issue once I have had sucess..
              Here's the output from the logs:
              https://www.dropbox.com/s/jf0udt2o5isbowk/trace.txt?dl=0
              I had to revert to using a USB CP2102 module as I couldn't get the tool to work with a PyTrack Module and the two PINs connected.
              Is there a way I can flash an older version of code just to rule out the device? Also, is there a way to "reset" the firmware updater software as it could have been that I selected the wrong board when updating.
              Thanks!
              • N Offline
                naveen
                I am not able to update using the GUI updater for MacOS. It always fails.
                I tried to update using pycom-fwtool-cli but I am getting following error message:
                Connecting.....
                Uploading stub...
                Exception: read failed: [Errno 6] Device not configured, on line 197
                Then I tried esptool.py read_mac and it says:
                A fatal error occurred: Failed to read target memory
                The FiPy's BLE and Wifi still works but now it stops sending message to SigFox (before it worked very well). I am not sure if it is related to the update failure.
                UPDATE: I also updated esptool to the latest version and run "esptool.py read_mac" but it stucks at "Uploading stub..." :
                esptool.py v2.2
                Connecting....
                Detecting chip type... ESP32
                Chip is ESP32D0WDQ6 (revision 1)
                Uploading stub...
                • X Offline
                  Xykon administrators @naveen
                  @naveen Do you use a Pytrack / Pysense or Expansion Board 2.0?
                  The most important thing is to make sure that no other program is using the serial port when you try the firmware upgrade. Unfortunately I don't have a way of checking this in the app.
                  For Pytrack / Pysense: Please make sure you have the latest firmware loaded.
                  For Expansion Board2: Please make sure you press the reset button before every use of the firmware update or esp-tool. Can you please post the output you see on the serial port when pressing the reset button with the firmware jumper wire attached?
                  Christian Ehlers
                  • N Offline
                    naveen
                    @Xykon I do not use any expansion board. I use usb serial adapter with breadboard (in fact, I made one using mkr1000). I have updated last firmware twice (few days ago) using this setup successfully. All wires are connected correctly and I always hit reset button before upgrade. Nothing is connected to FiPy except TX/RX, VIN/GND (with GND and G23 connected using jumper). Also, when I run "screen" command on MacOs and hit reset button it says "Waiting for download...", so I think serial connection is working. I guess for some reason it is not able to read memory. I am not able to erase firmware using esptool, too. Otherwise everything is working with the existing firmware (the last one). I also tried to do safe boot by connecting P12 to 3v3 with all possible ways but the firmware stays same. And the main thing is SigFox stopped sending messages, before I was able to send 21 messages so far and I believe Sigfox coverage is pretty good where I live (near Tokyo).
                    • N Offline
                      naveen
                      I tried with another USB cable which I used before and it worked! But the other problem is still there, fipy is not sending message to sigfox anymore. Why?
                        daniel
                        @naveen please go to the Sigfox back-end portal, click on your device (the FiPy in question) and, find the option to "Disengage the sequence number" and click on it. The try sending messages again. The failed update might have messed up the NVM of the device causing a a corruption of the sequence numbers.
                        • X Offline
                          Xykon administrators @Xykon
                          A bugfix for this is now available as a beta release for [LINK NO LONGER AVAILABLE]
                          Christian Ehlers
                          • N Offline
                            naveen @daniel
                            @daniel As you suggested, I clicked on the "Disengage the sequence number" option for the registered FiPy device in the SigFox backend but the FiPy still does not send message.
                            How can I know if the SigFox chip is okay and working? Is there any way to debug whether the messages are being sent?
                              daniel
                              Hello Naveen,
                              The only way to know if the device is transmitting is with a Spectrum Analyzer, but I don't think you could have damaged the radio. Please read the Sigfox ID and PAC from the device and tell me what you get:
                              from network import Sigfox
                              import binascii
                              sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ3)
                              print(binascii.hexlify(sigfox.id()))
                              print(binascii.hexlify(sigfox.pac()))
                              Cheers,
                              Daniel
                              • N Offline
                                naveen @daniel
                                '@daniel I got this output:
                                  daniel
                                  @naveen seems correct. Are you able to revert the firmware back to the previous release? As far as we can test Sigfox is still working OK with this version, but maybe in your case there's a problem. It would be great if you can revert to the 1.12.0.b1 release and test again. Thanks.
                                  Cheers,
                                  Daniel
                                    pymiom
                                    @daniel do you have any ideas about the reboots of the fipy? I still have yet to downgrade, but need the Sigfox functionally and concerned it may not be in the version I downgrade to.
                                    Cheers!
                                      daniel
                                      @pymiom 1.12.0.b1 also has Sigfox. Have you tried a different USB cable? There are a lot of weird issues which are caused by faulty cables...
                                      • N Offline
                                        naveen
                                        @denial How can I revert back to 1.12.0.b1 ? I guess the updater always installs the latest one.
                                          livius @naveen
                                          @naveen
                                          https://forum.pycom.io/post/3190
                                          • N Offline
                                            naveen @livius
                                            Thanks @livius, just downgraded to 1.12.0.b1 using the same link you provided. @daniel it is still same, no message is going to sigfox backend.
                                            Can be it antenna issue?
                                            • 1
                                            • 2
                                            • 1 / 2
