<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[FiPy with LoRaWAN using AS923 channel plan]]></title><description><![CDATA[<p dir="auto">Been trying to get my FiPy hooked up with LoraWAN and struck an incompatiblity with AS923.</p>
<p dir="auto">The following code:</p>
<p dir="auto">import uos<br />
import utime<br />
from network import LoRa<br />
from machine import unique_id<br />
import ubinascii</p>
<p dir="auto">def mac2eui(mac):<br />
mac = mac[0:6] + 'fffe' + mac[6:]<br />
return hex(int(mac[0:2], 16) ^ 2)[2:] + mac[2:]</p>
<p dir="auto">print(uos.uname())<br />
unique_id = ubinascii.hexlify(unique_id()).decode()</p>
<p dir="auto">lora = LoRa(mode=LoRa.LORAWAN)<br />
dev_eui =  mac2eui(unique_id)<br />
print(&quot;\n&quot;,dev_eui)<br />
app_eui = binascii.unhexlify('70 B3 D5 7E F0 00 3B FD'.replace(' ',''))<br />
app_key = binascii.unhexlify('36 AB 76 25 FE 77 0B 68 81 68 3B 49 53 00 FF D6'.replace(' ',''))</p>
<p dir="auto">for channel in range(0, 16):<br />
lora.remove_channel(channel)</p>
<p dir="auto">lora.add_channel(0, frequency=923200000, dr_min=0, dr_max=5)<br />
lora.add_channel(1, frequency=923400000, dr_min=0, dr_max=5)</p>
<p dir="auto">lora.join(activation=LoRa.OTAA, auth=(app_eui, app_key), timeout=0)</p>
<p dir="auto">while not lora.has_joined():<br />
print(&quot;not joined yet...&quot;)<br />
utime.sleep(2.5)</p>
<p dir="auto">print(&quot;JOINED!!!!&quot;)</p>
<p dir="auto">gives the following output:</p>
<p dir="auto">(sysname='FiPy', nodename='FiPy', release='1.13.0.b1', version='v1.8.6-849-656704e on 2018-01-10', machine='FiPy with ESP32', lorawan='1.0.0', sigfox='1.0.1')</p>
<p dir="auto">32aea4fffe2a4bdc<br />
Traceback (most recent call last):<br />
File &quot;&lt;stdin&gt;&quot;, line 27, in &lt;module&gt;<br />
ValueError: invalid argument(s) value</p>
<blockquote></blockquote>
<p dir="auto">MicroPython v1.8.6-849-656704e on 2018-01-10; FiPy with ESP32<br />
Type &quot;help()&quot; for more information.</p>
<p dir="auto">The issue is that the add_channel() method does not allow for a dr_max &gt; 4. The AS923 however allows for the following data rates:</p>
<p dir="auto">0 LoRa: SF12 / 125 kHz 250<br />
1 LoRa: SF11 / 125 kHz 440<br />
2 LoRa: SF10 / 125 kHz 980<br />
3 LoRa: SF9 / 125 kHz 1760<br />
4 LoRa: SF8 / 125 kHz 3125<br />
5 LoRa: SF7 / 125 kHz 5470<br />
6 LoRa: SF7 / 250 kHz 11000<br />
7 FSK: 50 kbps 50000</p>
<p dir="auto">Am I missing something?</p>
]]></description><link>https://forum.pycom.io/topic/2423/fipy-with-lorawan-using-as923-channel-plan</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 04:52:25 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2423.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Jan 2018 21:40:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to FiPy with LoRaWAN using AS923 channel plan on Wed, 10 Jan 2018 21:42:10 GMT]]></title><description><![CDATA[<p dir="auto">Been trying to get my FiPy hooked up with LoraWAN and struck an incompatiblity with AS923.</p>
import utime<br />
]]></description><link>https://forum.pycom.io/post/14331</link><guid isPermaLink="true">https://forum.pycom.io/post/14331</guid><dc:creator><![CDATA[kompleteb]]></dc:creator><pubDate>Wed, 10 Jan 2018 21:42:10 GMT</pubDate></item><item><title><![CDATA[Reply to FiPy with LoRaWAN using AS923 channel plan on Wed, 10 Jan 2018 23:09:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2213">@kompleteb</a><br />
Our implementation pre-dates the first AS923 implementation so we don't have support for it yet - it assumes US915.</p>
<p dir="auto">Usually you can go around the issue by defining channels manually using add_channel and remove_channel, but for datarates to match you need to think:</p>
<p dir="auto">datarate on AS923 = LoPy datarate + 2</p>
<p dir="auto">So if you set datarate 0 it's actually AS923 datarate 2, up to datarate 3 which is 5 on AS923. It's not possible to use AS923 data rates 0 and 1.</p>
<p dir="auto">This is all changing as we're making progress on updating our LoRa stack implementation, taking in the missing regions and more. But for now it only works with you consider it relative to US915.</p>
]]></description><link>https://forum.pycom.io/post/14333</link><guid isPermaLink="true">https://forum.pycom.io/post/14333</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Wed, 10 Jan 2018 23:09:18 GMT</pubDate></item><item><title><![CDATA[Reply to FiPy with LoRaWAN using AS923 channel plan on Thu, 11 Jan 2018 19:18:54 GMT]]></title><description><![CDATA[<p dir="auto">So this should do it, acknowledging that no channel willever use AS923 data rate 0 or 1?</p>
<p dir="auto">for channel in range(0, 15):<br />
<p dir="auto">lora.add_channel(0, frequency=923200000, dr_min=0, dr_max=3)<br />
lora.add_channel(1, frequency=923400000, dr_min=0, dr_max=3)<br />
lora.add_channel(2, frequency=922200000, dr_min=0, dr_max=3)<br />
lora.add_channel(3, frequency=922400000, dr_min=0, dr_max=3)<br />
lora.add_channel(4, frequency=922600000, dr_min=0, dr_max=3)<br />
lora.add_channel(5, frequency=922800000, dr_min=0, dr_max=3)<br />
lora.add_channel(6, frequency=922000000, dr_min=0, dr_max=3)</p>
]]></description><link>https://forum.pycom.io/post/14339</link><guid isPermaLink="true">https://forum.pycom.io/post/14339</guid><dc:creator><![CDATA[kompleteb]]></dc:creator><pubDate>Thu, 11 Jan 2018 19:18:54 GMT</pubDate></item></channel></rss>
