<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Starting with LoPy]]></title><description><![CDATA[<p dir="auto">I received 2 LoPy and 2 expansion boards today.<br />
I followed the initial setup instructions and got my units connected to Visual studio code pretty easily.<br />
I ran through the examples of changing the LED colour and then LoPy to LoPy. I am not sure what happened, I can 'run' scripts but I can no longer upload them to the boards. I get this message:</p>
<p dir="auto">Upload failed.: Cannot read property 'split' of null.</p>
<p dir="auto">I also can't get the pycom upgrade tool to function at all.<br />
I have also tried putting a brand new (untouched) module in the expansion board and trying to run it through the initial firmware upgrade but it hangs at &quot;Getting board information&quot; the same as the other boards.</p>
<p dir="auto">Hopefully I have just made some sort of newbie mistake. Any guidance would be appreciated.</p>
]]></description><link>https://forum.pycom.io/topic/2427/starting-with-lopy</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 15:49:52 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2427.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 11 Jan 2018 06:55:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Starting with LoPy on Thu, 11 Jan 2018 06:55:16 GMT]]></title><description><![CDATA[<p dir="auto">I received 2 LoPy and 2 expansion boards today.<br />
]]></description><link>https://forum.pycom.io/post/14344</link><guid isPermaLink="true">https://forum.pycom.io/post/14344</guid><dc:creator><![CDATA[aimette]]></dc:creator><pubDate>Thu, 11 Jan 2018 06:55:16 GMT</pubDate></item><item><title><![CDATA[Reply to Starting with LoPy on Fri, 12 Jan 2018 01:48:53 GMT]]></title><description><![CDATA[<p dir="auto">Update:<br />
I have installed Atom - which works without issues. I have also installed ampy and that works no problems at all.<br />
I suspect the problem is in a driver/VS code. I am still unclear as to why when I installed VS code on a different computer I see the exact same errors.<br />
The pycom upgrade tool still isn't working properly for me on either computer.<br />
Is there a way to perform firmware upgrades without the updater? More specifically, changing the LoRa frequency range from 868MHz to 915MHz and visa versa?</p>
]]></description><link>https://forum.pycom.io/post/14378</link><guid isPermaLink="true">https://forum.pycom.io/post/14378</guid><dc:creator><![CDATA[aimette]]></dc:creator><pubDate>Fri, 12 Jan 2018 01:48:53 GMT</pubDate></item><item><title><![CDATA[Reply to Starting with LoPy on Fri, 12 Jan 2018 06:20:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2218">@aimette</a> You can set up your own firmware build environment from the repository at <a href="https://github.com/pycom/pycom-micropython-sigfox" target="_blank" rel="noopener noreferrer nofollow">https://github.com/pycom/pycom-micropython-sigfox</a>, which in addition to changing the frequency allows you to embed your Python code into the flash, if it solid.</p>
]]></description><link>https://forum.pycom.io/post/14385</link><guid isPermaLink="true">https://forum.pycom.io/post/14385</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 12 Jan 2018 06:20:56 GMT</pubDate></item></channel></rss>
