<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[mqtt problem]]></title><description><![CDATA[<p dir="auto">I updated the fipy to 1.13.0.b1 version and does not recognize the mqtt module :(<br />
someone knows how can i make ?? or what is the correct name of the module<br />
i tried mqtt, MQTT, mqtt.simple, mqtt.robust in this way<br />
import mqtt<br />
import mqtt.simple etc</p>
]]></description><link>https://forum.pycom.io/topic/2452/mqtt-problem</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Nov 2026 20:06:44 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2452.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 14 Jan 2018 06:43:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to mqtt problem on Sun, 14 Jan 2018 07:37:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/livius" aria-label="Profile: livius">@<bdi>livius</bdi></a> thanks man i solved it<br />
i create a folder in my project called lib then copy the raw code from the github.<br />
thanks</p>
]]></description><link>https://forum.pycom.io/post/14478</link><guid isPermaLink="true">https://forum.pycom.io/post/14478</guid><dc:creator><![CDATA[yeffrimic]]></dc:creator><pubDate>Sun, 14 Jan 2018 07:37:16 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt problem on Sun, 14 Jan 2018 07:25:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/livius" aria-label="Profile: livius">@<bdi>livius</bdi></a> thanks thats the way to import libraries then ?<br />
another problem LOL I still trying to get this done too<br />
<img src="/assets/uploads/files/1515914714901-9ae44e81-18af-4611-9d7d-d90bec2fcf02-image.png" alt="0_1515914714171_9ae44e81-18af-4611-9d7d-d90bec2fcf02-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/14477</link><guid isPermaLink="true">https://forum.pycom.io/post/14477</guid><dc:creator><![CDATA[yeffrimic]]></dc:creator><pubDate>Sun, 14 Jan 2018 07:25:35 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt problem on Sun, 14 Jan 2018 07:14:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yeffrimic" aria-label="Profile: yeffrimic">@<bdi>yeffrimic</bdi></a><br />
you must put first library into <code>/flash/lib</code> folder<br />
<a href="https://github.com/pycom/pycom-libraries/tree/master/lib/mqtt" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/pycom/pycom-libraries/tree/master/lib/mqtt</a></p>
]]></description><link>https://forum.pycom.io/post/14476</link><guid isPermaLink="true">https://forum.pycom.io/post/14476</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Sun, 14 Jan 2018 07:14:26 GMT</pubDate></item><item><title><![CDATA[Reply to mqtt problem on Sun, 14 Jan 2018 07:13:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yeffrimic" aria-label="Profile: yeffrimic">@<bdi>yeffrimic</bdi></a> this is the problem<br />
<img src="/assets/uploads/files/1515913969771-9b57b03b-f47a-4313-b2b4-48e281f71190-image.png" alt="0_1515913969619_9b57b03b-f47a-4313-b2b4-48e281f71190-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.pycom.io/post/14474</link><guid isPermaLink="true">https://forum.pycom.io/post/14474</guid><dc:creator><![CDATA[yeffrimic]]></dc:creator><pubDate>Sun, 14 Jan 2018 07:13:06 GMT</pubDate></item></channel></rss>
