<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] issues w&#x2F; serial connection:  Atom + LoPy]]></title><description><![CDATA[<p dir="auto">Edit:  solved via Safeboot, thanks <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1881">@Seb</a>.</p>
<p dir="auto">Hello,<br />
I successfully updated the LoPy1 to the latest pycom firmware, and I installed the pymakr plugin for Atom on Windows 7 machine.  But when I try to connect to the LoPy via Atom's serial connection tool, I don't get the same results as the Getting Started Guide.  Here's what I see.  I'm not getting the &gt;&gt;&gt; in the console, and I can't type anything in.  Here's a screen shot of what I see.</p>
<p dir="auto"><a href="https://s18.postimg.org/5ya30gjhl/pycom_error_connection.jpg" target="_blank" rel="noopener noreferrer nofollow">https://s18.postimg.org/5ya30gjhl/pycom_error_connection.jpg</a></p>
<p dir="auto"><img src="https://s18.postimg.org/5ya30gjhl/pycom_error_connection.jpg" alt="alt text" class="img-responsive img-markdown" /></p>
<p dir="auto"><a href="https://s18.postimg.org/o135rvpop/pycom_error_settings_wrong.jpg" target="_blank" rel="noopener noreferrer nofollow">https://s18.postimg.org/o135rvpop/pycom_error_settings_wrong.jpg</a></p>
<p dir="auto"><img src="https://s18.postimg.org/o135rvpop/pycom_error_settings_wrong.jpg" alt="alt text" class="img-responsive img-markdown" /></p>
]]></description><link>https://forum.pycom.io/topic/2586/solved-issues-w-serial-connection-atom-lopy</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 16:33:00 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2586.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Feb 2018 20:58:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] issues w&#x2F; serial connection:  Atom + LoPy on Tue, 06 Feb 2018 20:31:13 GMT]]></title><description><![CDATA[<p dir="auto">Edit:  solved via Safeboot, thanks <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1881">@Seb</a>.</p>
]]></description><link>https://forum.pycom.io/post/15404</link><guid isPermaLink="true">https://forum.pycom.io/post/15404</guid><dc:creator><![CDATA[pynew]]></dc:creator><pubDate>Tue, 06 Feb 2018 20:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] issues w&#x2F; serial connection:  Atom + LoPy on Tue, 06 Feb 2018 09:15:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Do you have any code running on the device? If so, this could prevent the REPL prompt from appearing. Try clicking into the terminal window and pressing Ctrl+C. This should kill whatever script is running unless it is blocked.</p>
<p dir="auto">If Ctrl+C does not work, you could try doing a &quot;safe boot&quot; of your device to see if this fixes the issue. When P12 (bottom left most pin) is attached the 3.3v an the device is rebooted, you will see the on-board LED blink orange. When you see this, it mean the board will no longer run <code>boot.py</code> and <code>main.py</code> and go straight to the interactive REPL prompt.</p>
]]></description><link>https://forum.pycom.io/post/15441</link><guid isPermaLink="true">https://forum.pycom.io/post/15441</guid><dc:creator><![CDATA[seb]]></dc:creator><pubDate>Tue, 06 Feb 2018 09:15:39 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] issues w&#x2F; serial connection:  Atom + LoPy on Tue, 06 Feb 2018 20:31:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1881">@seb</a> Yup, that solved it</p>
]]></description><link>https://forum.pycom.io/post/15467</link><guid isPermaLink="true">https://forum.pycom.io/post/15467</guid><dc:creator><![CDATA[pynew]]></dc:creator><pubDate>Tue, 06 Feb 2018 20:31:27 GMT</pubDate></item></channel></rss>
