deepsleep maximum time
  • @seb thank you for the reply.
    can you please tell me why 3 byte value.
  • Hi,
    Q1) The deepsleep time is set as a 3 byte value in seconds, so therefore the maximum sleep time is 2^(8*3) seconds = 16,777,216 seconds = 27.7 weeks
    Q2) In regards to waking on pin P17 please see the docs here: https://docs.pycom.io/chapter/datasheets/boards/deepsleep/api.html
    You can do this like so:
    ds.enable_pullups('P17')
    ds.enable_wake_on_fall('P17')
    ds.go_to_sleep(100) #Sleep for 100s
    When the deep sleep shield goes to sleep, the LoPy will be completely unpowered, when it wakes up (either via a change on P17 or after 100s in the example above) the LoPy will begin code execution just as if you had pressed the reset button on the module.
    I hope this answers your questions
