<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[PyMakr with other editors]]></title><description><![CDATA[<p dir="auto">I have tried installing Atom and PyMakr under Windows 10 and I get the Node_Module_Version error:<br />
<img src="/assets/uploads/files/1520818780197-8916179f-12e7-4965-87c7-37225b911c67-image.png" alt="0_1520818779490_8916179f-12e7-4965-87c7-37225b911c67-image.png" class="img-responsive img-markdown" /><br />
I saw that PyMakr was designed to run with several different editors. I also see that there are quite a few posts on my issue, but no resolution. Is there another editor I can use with PyMakr? For instance I use Notepad++. But I will try anything that will work, as I am dead in the water right now.</p>
]]></description><link>https://forum.pycom.io/topic/2819/pymakr-with-other-editors</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 03:57:36 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2819.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 12 Mar 2018 01:46:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to PyMakr with other editors on Mon, 12 Mar 2018 01:46:26 GMT]]></title><description><![CDATA[<p dir="auto">I have tried installing Atom and PyMakr under Windows 10 and I get the Node_Module_Version error:<br />
]]></description><link>https://forum.pycom.io/post/16945</link><guid isPermaLink="true">https://forum.pycom.io/post/16945</guid><dc:creator><![CDATA[w0run]]></dc:creator><pubDate>Mon, 12 Mar 2018 01:46:26 GMT</pubDate></item><item><title><![CDATA[Reply to PyMakr with other editors on Mon, 12 Mar 2018 06:13:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/194">@w0run</a> You do not need PyMakr at all. You can use any combination of Editor, ftp client and terminal emulator you want. PyMakr tries to bundle that all in a package, which constantly causes trouble, partly because the version of dependencies always change, partly because it hides any issues that may arise. If you use separate tools, that may look a little bit rough, but you know at any time what happens.<br />
if you use for instance FileZilla or FireFTP as ftp client, you can configure these to call the editor once you double-click on a file. Notepad++ has a ftp plug-in, but that does not match to the ftp server of the xxPy devices.</p>
]]></description><link>https://forum.pycom.io/post/16948</link><guid isPermaLink="true">https://forum.pycom.io/post/16948</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Mon, 12 Mar 2018 06:13:40 GMT</pubDate></item><item><title><![CDATA[Reply to PyMakr with other editors on Mon, 12 Mar 2018 09:37:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/194">@w0run</a> try Visual Studio Code (<a href="https://code.visualstudio.com/" target="_blank" rel="noopener noreferrer nofollow">https://code.visualstudio.com/</a>) with the PyMakr plugin. Works very well.</p>
]]></description><link>https://forum.pycom.io/post/16953</link><guid isPermaLink="true">https://forum.pycom.io/post/16953</guid><dc:creator><![CDATA[nathanh]]></dc:creator><pubDate>Mon, 12 Mar 2018 09:37:49 GMT</pubDate></item></channel></rss>
