<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Powering the GPy and Pytrack from a Vehicle]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I'm considering using the Gpy and Pytrack in a vehicle monitoring application. This requires the modules to be powered from 10 to 30 volts. If possible I would like to use the pycom IP67 case. Are there any obvious solutions ?</p>
<p dir="auto">Cheers.</p>
<p dir="auto">Paddy</p>
]]></description><link>https://forum.pycom.io/topic/2937/powering-the-gpy-and-pytrack-from-a-vehicle</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 21:55:33 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2937.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Mar 2018 02:13:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Powering the GPy and Pytrack from a Vehicle on Fri, 30 Mar 2018 02:13:10 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
]]></description><link>https://forum.pycom.io/post/17848</link><guid isPermaLink="true">https://forum.pycom.io/post/17848</guid><dc:creator><![CDATA[Paddy]]></dc:creator><pubDate>Fri, 30 Mar 2018 02:13:10 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the GPy and Pytrack from a Vehicle on Fri, 30 Mar 2018 06:02:53 GMT]]></title><description><![CDATA[<p dir="auto">Do you want constant power in which case a really efficient regulator is probably best, or do you want low quiesent (standby/off) power in which case one that can be switched is probably better.</p>
]]></description><link>https://forum.pycom.io/post/17852</link><guid isPermaLink="true">https://forum.pycom.io/post/17852</guid><dc:creator><![CDATA[gregcope]]></dc:creator><pubDate>Fri, 30 Mar 2018 06:02:53 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the GPy and Pytrack from a Vehicle on Fri, 30 Mar 2018 06:49:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2554">@paddy</a> You need a regulator in between which reduces the incoming 10 to 30 volts down to 3.5 to 5.5 Volts which you then can feed into Vin. I personally like to use modules from Pololu. An appropriate step-down model would be  Pololu D24V10F5, supplying 5V/1A at an input range of 5.5 to 36V.</p>
]]></description><link>https://forum.pycom.io/post/17854</link><guid isPermaLink="true">https://forum.pycom.io/post/17854</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 30 Mar 2018 06:49:04 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the GPy and Pytrack from a Vehicle on Fri, 30 Mar 2018 07:06:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2554">@paddy</a><br />
Maybe I’m missing something but I just use a good quality USB phone car charger.</p>
<p dir="auto">Quality ones will handle 8-30V volts. This for example <a href="https://www.amazon.co.uk/Charger-RAVPower-Charging-Protection-Smartphones-Black/dp/B00Q2GFP4M?psc=1&amp;SubscriptionId=AKIAILSHYYTFIVPWUY6Q&amp;tag=duckduckgo-ipad-uk-21&amp;linkCode=xm2&amp;camp=2025&amp;creative=165953&amp;creativeASIN=B00Q2GFP4M" target="_blank" rel="noopener noreferrer nofollow">https://www.amazon.co.uk/Charger-RAVPower-Charging-Protection-Smartphones-Black/dp/B00Q2GFP4M?psc=1&amp;SubscriptionId=AKIAILSHYYTFIVPWUY6Q&amp;tag=duckduckgo-ipad-uk-21&amp;linkCode=xm2&amp;camp=2025&amp;creative=165953&amp;creativeASIN=B00Q2GFP4M</a></p>
<p dir="auto">Many modern cars have USB ports as well, just connect the Pytrack there.</p>
]]></description><link>https://forum.pycom.io/post/17858</link><guid isPermaLink="true">https://forum.pycom.io/post/17858</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Fri, 30 Mar 2018 07:06:44 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the GPy and Pytrack from a Vehicle on Fri, 30 Mar 2018 07:14:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a> Yes, I was thinking of that. But using an IP67 case implies an appropriate way of passing the cable. And that is more cumbersome with an USB cable. There are solutions for that, and by chance I have an IP67 USB plug  in my drawer, and there are IP67 cable inlets which you can split, so you pass through cables with a connector.<br />
And, by mentioning IP67 and the voltage range, I had the imagination of a more robust runtime environment, some cars, some trucks. So robust cables &amp; as few external connectors as possible is it.<br />
So many options .........</p>
]]></description><link>https://forum.pycom.io/post/17859</link><guid isPermaLink="true">https://forum.pycom.io/post/17859</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 30 Mar 2018 07:14:18 GMT</pubDate></item><item><title><![CDATA[Reply to Powering the GPy and Pytrack from a Vehicle on Thu, 06 Sep 2018 11:46:29 GMT]]></title><description><![CDATA[<p dir="auto">Could you use a battery and inductively charge the battery?</p>
]]></description><link>https://forum.pycom.io/post/22089</link><guid isPermaLink="true">https://forum.pycom.io/post/22089</guid><dc:creator><![CDATA[boff]]></dc:creator><pubDate>Thu, 06 Sep 2018 11:46:29 GMT</pubDate></item></channel></rss>
