<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Crash: PCB must be deallocated outside this function]]></title><description><![CDATA[<p dir="auto">When I do FTP transfers sometimes (at irregular intervals) I get this crash.<br />
I have noticed other spontaneous reboots of the system (not using FTP) but could never catch the core dump and I never found errors in my logs neither although every piece of code is inside a try except finally. So I don't know whether they are related.</p>
<p dir="auto">This is the error I get with the FTP:<br />
assertion &quot;PCB must be deallocated outside this function&quot; failed: file &quot;/Users/danicampora/Code/Espressif/IDF/esp-idf-20180112/com<em><strong>ERROR</strong></em> A stack overflow in task Servers has been detected.<br />
abort() was called at PC 0x4008d1cc on core 1</p>
<p dir="auto">Backtrace: 0x4008d183:0x3ffd32d0 0x4008d1b4:0x3ffd32f0 0x4008d1cc:0x3ffd3310 0x4008a79d:0x3ffd3330 0x4008be38:0x3ffd3360 0x4008bdee:0x00000000</p>
<p dir="auto">The system is:<br />
(sysname='WiPy', nodename='WiPy', release='1.15.0.b1', version='v1.8.6-849-baa8c33 on 2018-01-29', machine='WiPy with ESP32')</p>
<p dir="auto">I can give you the entire core dump too.</p>
]]></description><link>https://forum.pycom.io/topic/2944/crash-pcb-must-be-deallocated-outside-this-function</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 02:17:51 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2944.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 30 Mar 2018 20:10:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Fri, 30 Mar 2018 21:08:48 GMT]]></title><description><![CDATA[<p dir="auto">When I do FTP transfers sometimes (at irregular intervals) I get this crash.<br />
]]></description><link>https://forum.pycom.io/post/17885</link><guid isPermaLink="true">https://forum.pycom.io/post/17885</guid><dc:creator><![CDATA[fsergeys]]></dc:creator><pubDate>Fri, 30 Mar 2018 21:08:48 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Fri, 30 Mar 2018 20:30:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2222">@fsergeys</a> said in <a href="/post/17885">Crash: PCB must be deallocated outside this function</a>:</p>
<blockquote>
<p dir="auto">'1.15.0.b1'</p>
</blockquote>
<p dir="auto">is there any particular reason that you use old firmware?<br />
current one is <code>1.17.3.b1</code><br />
update firmware and look if your problem persist.</p>
]]></description><link>https://forum.pycom.io/post/17886</link><guid isPermaLink="true">https://forum.pycom.io/post/17886</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Fri, 30 Mar 2018 20:30:58 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Fri, 30 Mar 2018 20:35:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/199">@livius</a> Euh, no. I haven't upgraded the firmware since januari when I first installed the devices. And I thought I used the latest version at that time. Need to check whether I missed something.</p>
]]></description><link>https://forum.pycom.io/post/17887</link><guid isPermaLink="true">https://forum.pycom.io/post/17887</guid><dc:creator><![CDATA[fsergeys]]></dc:creator><pubDate>Fri, 30 Mar 2018 20:35:37 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Sat, 31 Mar 2018 18:03:34 GMT]]></title><description><![CDATA[<p dir="auto">Crash persists after upgrade firmware<br />
(sysname='WiPy', nodename='WiPy', release='1.17.3.b1', version='v1.8.6-849-83e2f7f on 2018-03-19', machine='WiPy with ESP32')</p>
<p dir="auto">assertion &quot;PCB must be deallocated outside this function&quot; failed: file &quot;/Users/danicampora/Code/Espressif/IDF/esp-idf-20180112/component<em><strong>ERROR</strong></em> A stack overflow in task Servers has been detected.<br />
abort() was called at PC 0x4008d4a8 on core 1</p>
<p dir="auto">Backtrace: 0x4008d45f:0x3ffd3770 0x4008d490:0x3ffd3790 0x4008d4a8:0x3ffd37b0 0x4008aa41:0x3ffd37d0 0x4008c114:0x3ffd3800 0x4008c0ca:0x00000000</p>
]]></description><link>https://forum.pycom.io/post/17888</link><guid isPermaLink="true">https://forum.pycom.io/post/17888</guid><dc:creator><![CDATA[fsergeys]]></dc:creator><pubDate>Sat, 31 Mar 2018 18:03:34 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Tue, 10 Apr 2018 20:33:21 GMT]]></title><description><![CDATA[<p dir="auto">anyone?<br />
This crash more or less renders my pycom boards useless as any data I capture, I can't FTP to the server for analysis ...</p>
]]></description><link>https://forum.pycom.io/post/18284</link><guid isPermaLink="true">https://forum.pycom.io/post/18284</guid><dc:creator><![CDATA[fsergeys]]></dc:creator><pubDate>Tue, 10 Apr 2018 20:33:21 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Wed, 11 Apr 2018 10:58:12 GMT]]></title><description><![CDATA[<p dir="auto">the entire core dump:</p>
<pre><code>assertion &quot;PCB must be deallocated outside this function&quot; failed: file &quot;/Users/danicampora/Code/Espressif/IDF/esp-idf-20180112/component***ERROR*** A stack overflow in task Servers has been detected.
yEsAABMAAABsAQAA
XD/9P7A2/T9UP/0/
ADj9P/A+/T+EhQAAlE/8P5RP/D9cP/0/jE/8PxQAAAC0a/s/tGv7P1w//T8AAAAA
BQAAAFg3/T9TZXJ2ZXJzAAAAAAAAAAAAAQAAAFQ//T8AAAAAIAIGAAUAAAADAAAA
HNv7PwAAAACINA1AAAAAAAsAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
r1dAPwAAAAAUoQlAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==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QEX9P8BD/T84Rf0/
wEP9P9BE/T9dRF53vEr9PzBP/D9ARf0/KE/8PxkAAACcGcRGN59jRkBF/T8AAAAA
AAAAADxB/T9JRExFAPycOs7/DNl2/esAAAAAADhF/T8AAAAAIQAGAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABlBgg==
xDIIQMQ6FEAwCgYA/LIIgIBE/T8gAAAAAQAAAAAAAAC0kPw/HFH8P8RO/D/QkPw/
YET9PwAAAAAAAAAAAAAAAIBD/T8DAAAAIwAGAAoAAACARP0/IAAAAOBlDkAcZg5A
AAAAAL00CECAQ/0/SMAIQESf+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAoET9PwAAAAAAAAAA
AAAAALSQ/D8cUfw/xE78PwAAAADQRP0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
AQAAAAAAAAAEAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANxE/T8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA==
tEr9PzBJ/T+sSv0/
MEn9P0BK/T/XvBTfME/8P0hF/T+0Sv0/KE/8PxkAAAB+OF/bUzvHMrRK/T8AAAAA
AAAAALBG/T9JRExFAPGoFMgCeoTubVQAAQAAAKxK/T8AAAAAIwAGAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACSmiQ==
xDIIQMQ6FEAwCAYA/LIIgPBJ/T8gAAAAAQAAACAAAAC0kPw/IFH8P8RO/D/wkPw/
AQAAAAAAAAD///9/V5wIgBCO/T8DAAAAIwAGAAAAAADwSf0/IAAAAAAAAAAAAAAA
AAAAAL00CEAQjv0/SMAIQLSk+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAAEEr9PwAAAAABAAAA
AQAAAAQZ/D8gUfw/xE78PwAAAABASv0/AAAAAAAAAAAEGfw/AAAAAAAAAAAAAAAA
AQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAExK/T8AAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA=
pFL8P3CO/T+8l/0/
cI79P1CX/T8kfQQAHE/8P6xN/T+kUvw/FE/8PxQAAACQdvs/kHb7P6RS/D+Idvs/
BQAAAMBn/T9NaWNyb1B5AAAAAAAAAAAAAQAAALyX/T8AAAAAIQAGAAUAAAACAAAA
AAAAADxe/D8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAgAAAA==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cDX9P/A2/T+0hQAArFL8PxxP/D+kTf0/FE/8PwcAAAAYmf0/GJn9P6RN/T8Qmf0/
EgAAAFQp/T90aVQAdABIFKUtRdpzX/8A////f1A3/T8AAAAAIQAGABIAAAABAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAOqPMg==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YF/9P1Bg/T8AAAAACE/8PwhP/D8kTP0/AE/8Pw8AAADwVf0/8FX9PyRM/T/oVf0/
CgAAALxW/T9UbXIgU3ZjAKxqqR0Qd0cAAAAAALhg/T8AAAAAIQAGAAoAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALq1ig==
xDIIQJm+CEAwAAYAAAAAACBg/T8AAAAAAAAAAAAAAAAsUfw/JFH8PwkAAACZvgiA
AGD9PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAL00CEAAAAAASMAIQMS6+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAMS6+j8AAAAAAAAAAAAAAAAAAAAAUGD9PwAAAAAAAAAA
AAAAAAAAAABcYP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAA=
cCL9P+Ag/T9oIv0/
4CD9PwAi/T/ovDNo7Cf9P1Sz/T9wIv0/pE78PwEAAADoVP0/6FT9P3Ai/T/gVP0/
GAAAAGwe/T9pcGMwAHxt/lOMq1uH4/4AAAAAAGgi/T8AAAAAIQAGABgAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFvA9w==
xDIIQCSlCEAwDAYA/BwIgKAh/T+8VP0/AAAAAAhV/T8AAAAAvFT9PwAAAAAkpQiA
gCH9PwAAAAD/////HFH8PwAAAAAEGfw/FwAAAAAAAAAAAAAAAQAAAAAAAAAAAAAA
AAAAAL00CEAAAAAASMAIQHR8+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAAAAAAA4CH9PwBO/D8AAAAA
AAAAADoUAAAAAAAAFwAAAP////8AAAAAAE78P/BN/D+wVP0/AAAAAAEAAAAAAAAA
AAAAAAAi/T8AAAAAAAAAAPRKCEAAAAAAAAAAAAAAAADFEQiAYDz+P4xO/D+UTvw/
AAAAAAAAAAAMIv0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAA=
5Cf9PzAm/T/cJ/0/
MCb9P3An/T+C5WCEqHn7P3gi/T/kJ/0/pE78PwEAAABAVf0/QFX9P+Qn/T84Vf0/
GAAAAOAj/T9pcGMxAFARhkIVh7ddBdcAAQAAANwn/T8AAAAAIQAGABgAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHp28g==
xDIIQDIUCEAwCgYAJKUIgPAm/T8BAAAA/////yBR/D8BAAAABBn8PyADBgAyFAiA
0Cb9P+AA8D8BAAAAuBj8PwEAAAD+AAAAIwAGAAAAAADwJv0/AQAAAAAAAAAAAAAA
AAAAAL00CEABAAAASMAIQOSB+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAP//P7MAAAAAAAAAAAAAAAD8HAiAECf9PxRV/T8AAAAA
5Cf9PwEAAAD+AAAAIwAGAAAAAABQJ/0/BE78PwAAAAAAAAAAMxUAAAAAAAAgAwYA
/////wAAAAAETvw/8E38P2BV/T8AAAAAFFX9PwAAAAAAAAAAcCf9PwAAAAAAAAAA
9EoIQAEAAAAAAAAAAAAAAGESCICAff4/AQAAAAAAAAAAAAAAAAAAAHwn/T8AAAAA
oHn7P5D3/T9I+f0/
kPf9P+D4/T8AAAAAbBr+P+wn/T+gefs/pE78PwIAAABsefs/bHn7P6B5+z9kefs/
FwAAAEzp/T9idENvbnRyb2xsZXIAAAAAAAAAAEj5/T8AAAAAIQAGABcAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHv7Pw==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ZBr+P8AY/j9cGv4/
wBj+P/AZ/j97mq3yNCv+P6h5+z9kGv4/pE78PwMAAAB4/P0/ePz9P2Qa/j9w/P0/
FgAAAGAQ/j9oY2lIb3N0VAABTewI9GgAAAAAAFwa/j8AAAAAIQAGABYAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGxkFQ==
xDIIQCSlCEAwAAYADFgZgIAZ/j9M/P0/wBn+P5j8/T8AAAAAoPz9PwAAAAAkpQiA
YBn+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAABkAAAAAAAAAAAAAADSZCUBimQlA
AAAAAL00CEAAAAAASMAIQGR0+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAEyf/D8AIAAAACEAAAAAAAAAAAAAwBn+PwSf/D8AAAAA
AAAAAEYVAAD+AAAAAAAAAP/////AGf4/DJ/8PwAAAACY/P0/AAAAAGD9/T8AAAAA
AAAAAPAZ/j8AAAAAAAAAAAAAAAAAAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/Bn+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
LCv+P5Ap/j8kK/4/
kCn+P8Aq/j8gHf4/NDP+P2wa/j8sK/4/pE78PwQAAAA8Hf4/PB3+Pywr/j80Hf4/
FQAAACgh/j9oY2lINFQAAAAAAAAAAAAAAAAAACQr/j8AAAAAIQAGABUAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGkZQA==
xDIIQCSlCEAwAAYAiOEZgFAq/j8QHf4/kCr+P1wd/j8AAAAAZB3+PwAAAAAkpQiA
MCr+PwAAAAD/////HFH8PwAAAAAEGfw/AAAAAAAAAAAAAAAAAAAAADSZCUBimQlA
AAAAAL00CEAAAAAASMAIQDSF+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAA4AAAAMn/w/Drf7P/8AAAAAAAAAkCr+P1Si/D8AAAAA
AAAAAEYVAAD+AAAAAAAAAP////+QKv4/VKL8PwAAAABcHf4/AAAAAPQe/j8BAAAA
AAAAAMAq/j8AAAAAAAAAAAAAAAAAAAAADrf7P/8AAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzCr+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
LDP+P9BT/j9oVf4/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wA7+P/AP/j9M9/0/HE/9PzQz/j/4ffs/pE78PwYAAADse/s/7Hv7P/h9+z/ke/s/
EwAAAFwE/j9CdGNfdGFzawAAAAAAAAAAAAAAAFgQ/j8AAAAAIQAGABMAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAH/7Pw==
xDIIQCSlCEAwDgYAoNcXgIAP/j/Ae/s/wA/+Pwx8+z8AAAAAFHz7PwAAAAAkpQiA
YA/+PwAAAAD/////HFH8PwAAAAAEGfw/AQAAACAAAAACAAAA2Ff+PzSZCUBimQlA
/////700CEAAAAAASMAIQGRq+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAANhX/j8THwAA/gAAACACBgAAAAAAwA/+Pwyd/D8AAAAA
AAAAAEcVAAAAAAAAAAAAAP/////AD/4/DJ38PwAAAABQeEI/AAAAACx8+z8AAAAA
AAAAAPAP/j8AAAAAAAAAAAFJAgAYV/4/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA/A/+PwAAAAAAAAAAAAAAAAAAAAAAAAAA
FE/9P5Cr/T9Irf0/
kKv9P+Cs/T+d64YXoFH7PwB++z8UT/0/pE78PwUAAAAgm/0/IJv9PxRP/T8Ym/0/
FAAAAEyh/T9ldmVudFRhc2sAzX2635cAAAAAAEit/T8AAAAAIQAGABQAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANjSNg==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mFH7PwBQ+z+QUfs/
AFD7PzBR+z+lpaWlcNb9PxxP/T+YUfs/pE78PwQAAAAIR/s/CEf7P5hR+z8AR/s/
FQAAAJRH+z9wbVQApaWlpaWlpaWlpaUA////f5BR+z8AAAAAIQAGABUAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADMzAw==
xDIIQCSlCEAwDAYAyT0SgMBQ+z/cRvs/AFH7PyhH+z8AAAAAMEf7PwAAAAAkpQiA
oFD7PwEAAAD/////IFH8PwEAAAAEGfw/IwAGAAAAAAAzMzMDMHb8PzSZCUBimQlA
/////700CEABAAAASMAIQKSr+D8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAADoAwC9NAhAAQAAAEjACEAAAAAAAFH7PzB2/D90iUE/
AAAAADWFAAAwdvw/dIlBP/////8AAAAAAAAAAAAAAAAoR/s/AAAAADBH+z8AAAAA
AAAAADBR+z8AAAAAAAAAAAYAAAADAAAAAAAAAAAAAABsd/w/MHb8PywBAAAAAAAg
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPFH7PwAAAAAAAAAAAAAAAAAAAAAAAAAA
aNb9P3Bo/j9QbP4/
cGj+P/Br/j9DhQAAzBz9P6BR+z9o1v0/pE78PxQAAAAUYPw/FGD8P2jW/T8MYPw/
BQAAAFRY/j9NUFRocmVhZAAkSAMBBgcAAQAAAFBs/j8AAAAAIQAGAAUAAAAAAAAA
AAAAAIxr/j8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAtf9Pw==
xDIIQCSlCEAwBgYAmNENgDBp/j/oX/w/AAAAADRg/D8AAAAAAAAAAAAAAAAkpQiA
EGn+PwEAAAD/////IFH8PwEAAAAEGfw/BQAAAB4AAABwaf4/Q4UAAOBlDkAcZg5A
AAAAAL00CEABAAAASMAIQGTG+z8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAC9NAhAAQAAAEjACEBI1Q2AcGn+P+Rf/D8BAAAA
AAAAAEOFAAAAAAAAAAAAAP////8AAAAAAAAAAAAAAAA0YPw/AAAAAAAAAAABAAAA
7UEOgJBp/j8CAAAA5F/8PwAAAAABAAAAAIAAAP//AIDdRA+AsGn+PwEAAAC07JQ/
AQAAAAEAAADA////AQAAAHQOD4DQaf4/zEEOQAEAAAAAAAAAAQAAAAAAAACCCAAA
3A4PgABq/j9ENkA/AQAAANwOD4AAav4/nEpBPwEAAAAAAAAAtOyUPwAAAADQAAAA
aMIPgCBq/j8BAAAAAAAAAAAAAAC07JQ/AQAAAO4KAABnRQ+AQGr+PwgAAABhv5U/
rOyUP7jslD/r////AQAAAHQOD4Dgav4/gF78P4Be/D9Aa/4/AAAAAGdFD4BAav4/
QGv+PwoAAADU7JQ/AAAAANDslD8AAAAABQAAAAAAAAClpaWlpaWlpXQOD4Dgav4/
gF78P4Be/D/2tA+ASGv+PwoAAAAFAAAA1OyUPwAAAAAAAAAAkOyUP9TslD/Q7JQ/
CQAAAOhUlT8BAAAAAAAAAKzslD8AAAAAMP///2K/lT9+sg+AIGv+P9AilT8CAAAA
Ar+VPwAAAAAAAAAAAAAAAAAAAADoVJU/AAAAAAAAAACQ7JQ/NAAAAAoAAADgav4/
zNANgEBr/j8AAAAA0FSVPwAAAADoVJU/aGv+P8Br/j8AAAAA0Gv+P9BUlT8AAAAA
AAAAAAAAAADM0A2AQGv+PwAAAADQVJU/IwAGAAAAAAAEAAAA////fwAAAAAAAAAA
AAAAAAAAAAAAAAAA0Gv+P9BUlT8AAAAAbbIPgIBe/D+AXvw/QGr+P6Br/j8AEAAA
0FSVPwAAAAAAAAAAAAAAANBUlT8AAAAABAAAAP///38AAAAA8Gv+PwAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEAAAAAAPxr/j8AAAAA
gAAAAAAAAAAAAAC/AAAAAPoAAEsAAADAAACANwAAAF8AwJ9fAAD6OwAAAAAAAAAA
xBz9PzAb/T+8HP0/
MBv9P1Ac/T+B72BXYNj7P3DW/T/EHP0/pE78PwMAAAAkU/0/JFP9P8Qc/T8cU/0/
FgAAAMAQ/T9lc3BfdGltZXIAMD2R988AAAAAALwc/T8AAAAAIQAGABYAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPo+rQ==
xDIIQCSlCEAwDAYATSMNgPAb/T/4Uv0/AAAAAERT/T8AAAAA+FL9PwAAAAAkpQiA
0Bv9PwAAAAD/////HFH8PwAAAAAEGfw/IAAGAAAAAAD//z+zAAAAADSZCUBimQlA
/////700CEAAAAAASMAIQMR2+j8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAABxR/D8AAAAABBn8PyAABgAAAAAAMBz9P6xN/D+0Tfw/
AAAAAE+FAABVAQAAIAAGAP////8wHP0/yFj7P7RN/D9EU/0/AAAAAPhS/T8AAAAA
AAAAAFAc/T8AAAAAAAAAAAAAAAAAAAAAtE38PwAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAABcHP0/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAA
WNj7P7DW+z9Q2Ps/
sNb7P/DX+z9eBa2RrE78P8wc/T9Y2Ps/pE78PwIAAADowfs/6MH7P1jY+z/gwfs/
FwAAAFTI+z93aWZpAMvclt/NXcFlaoQAAAAAAFDY+z8AAAAAIQAGABcAAAABAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANnEeQ==
xDIIQCSlCEAwCgYAnGkSgHDX+z+8wfs/wNf7PwjC+z8AAAAAEML7PwAAAAAkpQiA
UNf7PwAAAAD/////HFH8PwAAAAAEGfw/ZQAAABcAAACONrw/AAAAANmZCUANmglA
/////700CEAAAAAASMAIQGQy+T8AAAAAAAAAAAAAAAD//z+zAAAAAAAAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAIAAADwrPw/gAG8PwAAAAAAAAAAsNf7P8C3/D+Ad/w/
AAAAAIaFAAABAAAAHAcAAP////98Frw/wLf8P4B3/D/Et/w/aDa8PwAAACAEAAAA
AAAAAPDX+z8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHAAAAAQAAAAAAAAAAAAAA
GgAAANhVEUB8e/w/AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPzX+z8AAAAA
TLP9P6DK/T+4zP0/
oMr9P1DM/T+lpaWleCL9P6xO/D9Ms/0/pE78Pw4AAAB8rf0/fK39P0yz/T90rf0/
CwAAALy0/T9JUlFzAKWlpaWlpaWlpaUAAQAAALjM/T8AAAAAIQAGAAsAAAAAAAAA
AAAAAOzL/T8AAAAAAAAAAAAAAABUUf0/vFH9PyRS/T8AAAAAAAAAAAEAAAAAAAAA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqWlpQ==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Rebooting...
</code></pre>
]]></description><link>https://forum.pycom.io/post/18313</link><guid isPermaLink="true">https://forum.pycom.io/post/18313</guid><dc:creator><![CDATA[fsergeys]]></dc:creator><pubDate>Wed, 11 Apr 2018 10:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Wed, 11 Apr 2018 12:31:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2222">@fsergeys</a> How do you use FTP. Are you useing the server on the device, which is connected by a remote client,  or do you use a (python coded) ftp client, which connects to a sever,?</p>
]]></description><link>https://forum.pycom.io/post/18325</link><guid isPermaLink="true">https://forum.pycom.io/post/18325</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Wed, 11 Apr 2018 12:31:55 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Wed, 11 Apr 2018 13:42:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a><br />
Filezilla cliënt or FTP cliënt in a cron scheduled Task Connecting to the FTP server on the device.</p>
]]></description><link>https://forum.pycom.io/post/18328</link><guid isPermaLink="true">https://forum.pycom.io/post/18328</guid><dc:creator><![CDATA[fsergeys]]></dc:creator><pubDate>Wed, 11 Apr 2018 13:42:37 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Wed, 11 Apr 2018 19:26:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2222">@fsergeys</a> Could it  be that there a problem with the concurrent access of writing and reading? Does the core dump also happen when you do no FTP access? You tell that it does not. Then you may consider another method for data transfer, which is initiated by the WiPy. I used a ftplib once for a ftp client, but that may be too bulky, unless you embed it as frozen bytecode. that will give you better control on the times of data exchange. As far as I recall, it was the esp8266 version of this variant: <a href="https://github.com/SpotlightKid/micropython-ftplib" target="_blank" rel="noopener noreferrer nofollow">https://github.com/SpotlightKid/micropython-ftplib</a></p>
]]></description><link>https://forum.pycom.io/post/18347</link><guid isPermaLink="true">https://forum.pycom.io/post/18347</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Wed, 11 Apr 2018 19:26:15 GMT</pubDate></item><item><title><![CDATA[Reply to Crash: PCB must be deallocated outside this function on Wed, 18 Apr 2018 12:34:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a><br />
Concurrent access was my first idea too.<br />
To test it: I erased the flash to standard boot and main. Then I preloaded the SD with data.  Re-ran the FTP test and it still had the same crashes.<br />
Using the FTP server on the device is for me is the easiest way.<br />
Otherwise I would need to create a Timer to upload data at regular intervals. To keep data transfer low I would need keep the intervals long avoiding me to have the flexibility of choosing which data I want to download and when.<br />
To be honest, I'm a bit disappointed by the eagerness of pycom to attack this problem.<br />
The same with my other crash report.</p>
]]></description><link>https://forum.pycom.io/post/18727</link><guid isPermaLink="true">https://forum.pycom.io/post/18727</guid><dc:creator><![CDATA[fsergeys]]></dc:creator><pubDate>Wed, 18 Apr 2018 12:34:13 GMT</pubDate></item></channel></rss>
