    Send a file from one Lopy to another Lopy
    lopy to lopywlanwifi lopy
    27 Posts 2 Posters 8.5k Views 2 Watching
    • Z Offline
      zceld @seb
      @seb said in Send a file from one Lopy to another Lopy:
      Did you create a test.txt file on your device too? the server reads the file test.txt and client writes to a file called test.txt
      I had not realized that it was the other way around, that is, as my idea was to send the client to the server, I had not noticed sorry. Anyway now I have changed it to a file that is in the Lopy but now it tells me this error:
      0_1524148256070_d4c119a9-7b2b-4f3f-adb3-340e720e3c95-image.png Captura de pantalla 2018-04-19 16.30.23
      sebS Z 2 Replies Last reply Reply Quote 0
      • sebS Offline
        seb @zceld
        @zceld
        How big of a file are you trying to copy?
        • Z Offline
          zceld @zceld
          @zceld
          I still do not know what that error means but it must be related to the socket and the listener method.
          But I have reset the plates and it has worked :) I still do not believe it ...
          hehe thank you very much at least I know that something works now I need many things to know but already with the base is much.
          By the way when you put the socket = cl.setblocking (True)
          Is there a way to cancel or interrupt this?
          another question. this 's.listen (1)' which means you will be listening once?
          I have more questions ... If I use for example Wi-Fi or Lora with _threads, can I send and listen to the same chip at the same time?
          • sebS Offline
            seb @zceld
            @zceld
            1. You can cancel it by using setblocking(False)
            2. you can find out what s.listen(1) means here: https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html#socketlistenbacklog its basically how many unaccepted connections you can queue up
            3. Yeah that should be fine, the underlying drivers for wifi/lora will handle multiplexing access to them
            Z 1 Reply Last reply Reply Quote 0
            • Z Offline
              zceld @seb
              Would you know to tell me that I failed in all the previous examples??
              On the other hand I already ask you in your day for the same thing of s.setblocking (True / False) you know where I could find an exhaustive explanation about that?
              Finally on the _treads, to confirm. It would be possible to put in a Lopy a _tread that established the wifi in WLAN.AP mode and in turn in the same Lopy through another _tread the wifi was put in WLAN.STA mode at the same time?
              • sebS Offline
                seb @zceld
                @zceld
                The docs are the best place to look at what these functions do: https://docs.pycom.io/chapter/firmwareapi/micropython/usocket.html
                Here is a basic run down, s.setblocking(True) will make any sending or recieving functions block, this means the lopy will get stuck at that line of code until it receives the amount of bytes asked for (or it timesout, if a timeout is set) or until all data is send. When it is False calls to any sending or receiving functions will return immediately. In the case of a send, it will place the data in a queue and it will be send in the background in a different thread. In the case of a recieve, if there is less data than expected available it simply returns that and doesnt wait for the full expected amount.
                You can change the WLAN modes but this will become messy because you will need to make sure the threads have proper locks and that they are aware of what state the WLAN is in before trying to use it. You might be better off just using the WLAN.STA_AP mode which is both modes at once.
                • Z Offline
                  zceld
                  Good again.
                  I return to post, because I would need the LoPy that receives the txt file is the one that starts the wifi as
                  wlan = WLAN (mode = WLAN.AP,
                  ssid = 'Gateway1',
                  auth = (WLAN.WPA2, 'password'),
                  antenna = WLAN.INT_ANT)
                  I have tried to modify the code as I have the partner that works so that it is but I get error everywhere.
                  Once trying once more, if I do not restart the board and try to execute the code, I always get the error:
                  File "<stdin>", line 17, in <module>
                  OSError: [Errno 12] ENOMEM
                  Because it is ? If someone can give me a hand code please!
                  Capture Errors:
                  used code:
                  Server And Wifi AP:
                  from network import WLAN
                  import select
                  #Setup WiFi AP
                  wlan = WLAN(mode=WLAN.AP,
                              ssid='Gateway1',
                              auth=(WLAN.WPA2,'password'),
                              antenna=WLAN.INT_ANT)
                  port = 12345
                  s = socket.socket()
                  s.bind(socket.getaddrinfo("0.0.0.0", port)[0][4])
                  s.listen(1)
                  print("Running server")
                      cl, remote_addr = s.accept()
                      cl.setblocking(True)
                      print("Client connection from:", remote_addr)
                      file = "/flash/registro2.txt"
                      with open(file, 'wb') as f:
                          try:
                              data = s.recv(1024)
                              print(data)
                              f.write(data)
                          except TimeoutError:
                              break
                  Client and Lopy and in charge to send file:
                  import select
                  # Abrimos wifi
                  wlan = WLAN(mode=WLAN.STA)
                  nets = wlan.scan()
                  for net in nets:
                      if net.ssid == 'Gateway1':
                          print('Network found!')
                          wlan.connect(net.ssid, auth=(net.sec, 'password'), timeout=5000)
                          while not wlan.isconnected():
                          break
                      raise Exception("WiFi network not found")
                  # sleep just to make sure the wifi is connected
                  ip, subnet, gateway, dns = wlan.ifconfig()
                  # Connect to server
                  # Bind to the port
                  port = 12345
                  s = socket.socket()
                  s.connect((gateway, port))
                  s.setblocking(True)
                  s.settimeout(2)
                      readable, writable, errored = select.select([s], [], [])
                      for s in readable:
                          file = "/flash/registro.txt"
                          print("Sending: ", file)
                          with open(file, 'rb') as f:
                              data = f.read(1024)
                              while(data):
                                  print("sending", data)
                                  cl.sendall(data)
                                  data = f.read(1024)
                          print("Done Sending")
                          cl.close()
                  • 1
                  • 2
                  • 2 / 2
