<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LoPy buried in Compost!]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I've been trying to measure the internal temperature <em>inside</em> a wet heap of compost (don't ask!). I used a LoPy enclosed inside of a small <a href="http://www.pelican.com/us/en/product/cases/micro/1020" target="_blank" rel="noopener noreferrer nofollow">Pelican box</a>, connected to an <a href="http://www.taoglas.com/product/fxp280-868mhz-flex-pcb-antenna/" target="_blank" rel="noopener noreferrer nofollow">internal antenna</a> with a one-wire sensor connected to it, poking out of the enclosure.</p>
<p dir="auto">The gateway is a <a href="https://www.lairdtech.com/products/rg1xx-lora-gateway" target="_blank" rel="noopener noreferrer nofollow">Lard RG186</a>, in turn connected to a <a href="http://www.taoglas.com/product/barracuda-omb-868-b12f21/" target="_blank" rel="noopener noreferrer nofollow">large antenna</a>, which is only about 2m away from the compost heap.</p>
<p dir="auto">I can successfully receive messages via TTN when the compost box is outside of the compost heap, however when buried within the compost, I get nothing.</p>
<p dir="auto">I'm guessing this is down to the wet compost essentially acting as a Faraday cage around my LoPy, feeding all of the signal into ground. Has anyone got any good ideas of how I could improve on this?</p>
<p dir="auto">I thought about using a directional antenna on the gateway and pointing it at the compost heap, however it's not really the TX that's the issue, it's the RX (to the gateway).</p>
<p dir="auto">Any helpful/silly suggstions always welcome!</p>
<p dir="auto">Thanks,<br />
Joe</p>
]]></description><link>https://forum.pycom.io/topic/2975/lopy-buried-in-compost</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 04:56:22 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/2975.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Apr 2018 13:35:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 13:35:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
Joe</p>
]]></description><link>https://forum.pycom.io/post/18073</link><guid isPermaLink="true">https://forum.pycom.io/post/18073</guid><dc:creator><![CDATA[joearkay]]></dc:creator><pubDate>Thu, 05 Apr 2018 13:35:59 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 13:46:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a>  - finally, I'm using the forums ;)</p>
]]></description><link>https://forum.pycom.io/post/18074</link><guid isPermaLink="true">https://forum.pycom.io/post/18074</guid><dc:creator><![CDATA[joearkay]]></dc:creator><pubDate>Thu, 05 Apr 2018 13:46:31 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 13:59:43 GMT]]></title><description><![CDATA[<p dir="auto">I have seen this done before where the one wire temp sensor is in the compost and the microcontroller is outside.</p>
]]></description><link>https://forum.pycom.io/post/18075</link><guid isPermaLink="true">https://forum.pycom.io/post/18075</guid><dc:creator><![CDATA[gregcope]]></dc:creator><pubDate>Thu, 05 Apr 2018 13:59:43 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 14:02:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2408">@gregcope</a> thanks for the comment - I had thought of this previously. However,  the enclosure and temperature sensor have to be a single unit.</p>
<p dir="auto">I won't bore you with the technicalities, but I'm developing this for a site where they use plant machinery to move the compost heap around, so the boxes need to withstand this.</p>
]]></description><link>https://forum.pycom.io/post/18076</link><guid isPermaLink="true">https://forum.pycom.io/post/18076</guid><dc:creator><![CDATA[joearkay]]></dc:creator><pubDate>Thu, 05 Apr 2018 14:02:53 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 14:05:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi! You can check for papers on underground IoT (or WSN). For example: <a href="https://www.researchgate.net/publication/309397324_MoleNet_A_New_Sensor_Node_for_Underground_Monitoring" target="_blank" rel="noopener noreferrer nofollow">https://www.researchgate.net/publication/309397324_MoleNet_A_New_Sensor_Node_for_Underground_Monitoring</a></p>
<p dir="auto">Cheers,<br />
Marco</p>
]]></description><link>https://forum.pycom.io/post/18077</link><guid isPermaLink="true">https://forum.pycom.io/post/18077</guid><dc:creator><![CDATA[marcozennaro]]></dc:creator><pubDate>Thu, 05 Apr 2018 14:05:58 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 14:17:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/1390">@marcozennaro</a> Hi Marco, I'll certainly give this a read - thank you.</p>
]]></description><link>https://forum.pycom.io/post/18078</link><guid isPermaLink="true">https://forum.pycom.io/post/18078</guid><dc:creator><![CDATA[joearkay]]></dc:creator><pubDate>Thu, 05 Apr 2018 14:17:32 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 14:18:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2580">@joearkay</a> Polarization and placement of antenna is important. You have to ensure, that sending and receivung antenna have the same orientation and are in the best receive position. If the receiver is upright, the sender must be too. And you should consider, that the gateway antenna you use has a rather flat receiption characteristic. For better gain, the optimal volume looks like disk. The vertical beam width is +/- 18 degrees. So if your unit is close, but below the antenna, this &quot;good&quot; antenna might behave worse than a 4$ piece.</p>
]]></description><link>https://forum.pycom.io/post/18079</link><guid isPermaLink="true">https://forum.pycom.io/post/18079</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 05 Apr 2018 14:18:12 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 14:46:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2580">@joearkay</a> In the box you might need a dipole antenna like this one: <a href="https://www.ead-ltd.com/products/169-433-868-915-antennas/morava-868-mhz-pcb-internal-antenna" target="_blank" rel="noopener noreferrer nofollow">https://www.ead-ltd.com/products/169-433-868-915-antennas/morava-868-mhz-pcb-internal-antenna</a></p>
]]></description><link>https://forum.pycom.io/post/18080</link><guid isPermaLink="true">https://forum.pycom.io/post/18080</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 05 Apr 2018 14:46:56 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Thu, 05 Apr 2018 15:40:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2580">@joearkay</a><br />
I find those flexible internal antennas are really sensitive to their surroundings. I'd suggest either an external antenna (could be IP67 well sealed to the enclosure) or if it must be internal try the ProAnt evaluation one, <a href="https://www.digikey.co.uk/products/en?keywords=Proant%20PRO-EB-472" target="_blank" rel="noopener noreferrer nofollow">https://www.digikey.co.uk/products/en?keywords=Proant PRO-EB-472</a></p>
]]></description><link>https://forum.pycom.io/post/18084</link><guid isPermaLink="true">https://forum.pycom.io/post/18084</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Thu, 05 Apr 2018 15:40:18 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Fri, 06 Apr 2018 16:50:55 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the suggestions everyone. I'm looking at evaluating the <a href="http://www.taoglas.com/product/pc81-868mhz-ism-mini-pcb-antenna/" target="_blank" rel="noopener noreferrer nofollow">PC81 868MHz</a> from Taoglas as well as the one suggested by <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a> (<a href="https://www.ead-ltd.com/products/169-433-868-915-antennas/morava-868-mhz-pcb-internal-antenna" target="_blank" rel="noopener noreferrer nofollow">this one</a>)</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/212">@jmarcelino</a> I couldn't seem to see the connector type <a href="https://www.digikey.co.uk/products/en?keywords=Proant%20PRO-EB-472" target="_blank" rel="noopener noreferrer nofollow">on eval. unit you suggested</a> - have you used one of these before? Could you provide some insight?</p>
<p dir="auto">Thanks again all.</p>
]]></description><link>https://forum.pycom.io/post/18132</link><guid isPermaLink="true">https://forum.pycom.io/post/18132</guid><dc:creator><![CDATA[joearkay]]></dc:creator><pubDate>Fri, 06 Apr 2018 16:50:55 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Fri, 06 Apr 2018 21:56:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2580">@joearkay</a><br />
The Proant eval kit comes with a standard male SMA connector (so you'll need a uFL to SMA pigtail for it, as the Pycom antenna kit comes with RP-SMA instead)</p>
]]></description><link>https://forum.pycom.io/post/18144</link><guid isPermaLink="true">https://forum.pycom.io/post/18144</guid><dc:creator><![CDATA[jmarcelino]]></dc:creator><pubDate>Fri, 06 Apr 2018 21:56:29 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy buried in Compost! on Fri, 06 Apr 2018 23:29:14 GMT]]></title><description><![CDATA[<p dir="auto">For lower attenuation it would better to go with 433 MHz, even better to 169 MHz that is also an ISM band.<br />
The big problem with compost, if I remember well how is processed, it is its high water content.<br />
There are several studies that can be found about &quot;soil&quot; and wireless sensors networks, search for WUSN (wirelss underground sensor network) and UG2AG (underground 2 aboveground).<br />
Usually are studies made for agriculture, forestry, soil, pipelines, ... sensors deployment.</p>
]]></description><link>https://forum.pycom.io/post/18145</link><guid isPermaLink="true">https://forum.pycom.io/post/18145</guid><dc:creator><![CDATA[MarcoBenini]]></dc:creator><pubDate>Fri, 06 Apr 2018 23:29:14 GMT</pubDate></item></channel></rss>
