<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Workable editor for Windows virtual machine]]></title><description><![CDATA[<p dir="auto">I have both a WiPy and a LoPy here and I need to setup a workable editor environment. I also need to have the editor working within a Windows 7 or 8 VM, I am using VM Workstation 14.</p>
<p dir="auto">Whilst Ampy and a serial terminal do work, its not so easy to swap between the two. I have the LoPy connected via a FTDI USB to serial adapter. The repl is fine on this setup with a proper serial terminal such as Teraterm.</p>
<p dir="auto">Atom just kills Windows 7 and 8, even when I give it 8GB of RAM, it constanly runs at 99% CPU, and the repl can take 30 seconds and more to acknowledge a keypress, its unuseable.</p>
<p dir="auto">Visual studio code is not such a processor hog, still a little slow however, but it it wont connect at all.</p>
<p dir="auto">What does work with very little effort and automatically connects to the LoPy, is the earlier Pymakr IDE. Very lightweight on the CPU and a normal response in the repl.</p>
<p dir="auto">Whilst I appreciate that the Pymakr IDE may no longer be supported, it does have the benefit of working here, problem is I cannot seem to find the instructions, are they still available ?</p>
]]></description><link>https://forum.pycom.io/topic/3322/workable-editor-for-windows-virtual-machine</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 20:53:04 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/3322.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 31 May 2018 15:58:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Fri, 01 Jun 2018 09:56:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/charly86" aria-label="Profile: charly86">@<bdi>charly86</bdi></a> No idea. I ran it once, and it worked. Now that I tried it again, it fails. I can get the file listing, but cannot download files.<br />
Normally, I use FireFTP, since I have anyhow Firefox running most of the time.</p>
]]></description><link>https://forum.pycom.io/post/20088</link><guid isPermaLink="true">https://forum.pycom.io/post/20088</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Jun 2018 09:56:01 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Fri, 01 Jun 2018 09:33:37 GMT]]></title><description><![CDATA[<p dir="auto">How did you succeed with notepad++, since we need to set FTP to only one simultaneous connexion (option available on filezilla) I never found this one one notepad++ and never get it working, so if you have a trick, you'll save my day</p>
]]></description><link>https://forum.pycom.io/post/20087</link><guid isPermaLink="true">https://forum.pycom.io/post/20087</guid><dc:creator><![CDATA[Charly86]]></dc:creator><pubDate>Fri, 01 Jun 2018 09:33:37 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Fri, 01 Jun 2018 08:35:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loratracker" aria-label="Profile: loratracker">@<bdi>loratracker</bdi></a> I personally use a mix of FireFTP/PC Editor (gedit on Linux, Notepad++ on Windows), and as well an editor script (<a href="http://pye.py" target="_blank" rel="noopener noreferrer nofollow ugc">pye.py</a>), which runs on the xxPy device itself for fast fixes. It requires a VT100 compatible terminal emulator, like Putty/Teraterm/picocom/screen ... Together with the <a href="http://upysh.py" target="_blank" rel="noopener noreferrer nofollow ugc">upysh.py</a> set of tools I have a "micro OS" on the device itself.</p>
]]></description><link>https://forum.pycom.io/post/20085</link><guid isPermaLink="true">https://forum.pycom.io/post/20085</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Fri, 01 Jun 2018 08:35:48 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Fri, 01 Jun 2018 07:49:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/robert-hh" aria-label="Profile: robert-hh">@<bdi>robert-hh</bdi></a><br />
I can connect by WiFi, and then change the WiPy\LoPy settings to connect to my own WiFi.</p>
<p dir="auto">And to be fair it does work well with filezilla, but the WiFi in my workshop is not so good for portable devices. The PC has a decent antenna mounted high up to link into the domestic WiFi.</p>
<p dir="auto">Using the WiFi also creates a setup that is not portable, without a deal of re-configuration, that is something I would like to avoid.</p>
]]></description><link>https://forum.pycom.io/post/20084</link><guid isPermaLink="true">https://forum.pycom.io/post/20084</guid><dc:creator><![CDATA[LoRaTracker]]></dc:creator><pubDate>Fri, 01 Jun 2018 07:49:37 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Thu, 31 May 2018 19:12:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loratracker" aria-label="Profile: loratracker">@<bdi>loratracker</bdi></a> If you cann connect the devices by WiFi, you have a few options. You could use either a FTP client like Filezilla or FireFTP to exchange files with the  xxPy. Both allow to integrate your favorite editor, and load the file as requested if you double-click the file name. You can also use Notepad++ and the ftp extension.<br />
In parallel, you can have the terminal window with Putty or TeraTerm.<br />
That's a little bit less convenient than the Atom/VSC+Pymakr  combo, but at least you have full control and visibility about what happens. Lack of that is one of the common problems with Pymakr.</p>
]]></description><link>https://forum.pycom.io/post/20076</link><guid isPermaLink="true">https://forum.pycom.io/post/20076</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Thu, 31 May 2018 19:12:13 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Thu, 31 May 2018 17:31:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/charly86" aria-label="Profile: charly86">@<bdi>charly86</bdi></a> said in <a href="/post/20074">Workable editor for Windows virtual machine</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loratracker" aria-label="Profile: loratracker">@<bdi>loratracker</bdi></a> said in <a href="/post/20073">Workable editor for Windows virtual machine</a>:</p>
<blockquote>
<p dir="auto">Ampy</p>
</blockquote>
<p dir="auto">Nice, need to try this one, can it put Lopy board into safe mode before upload and then reset board after ?</p>
</blockquote>
<p dir="auto">I would not consider myself an advanced enough Ampy user to give a good answer .......</p>
]]></description><link>https://forum.pycom.io/post/20075</link><guid isPermaLink="true">https://forum.pycom.io/post/20075</guid><dc:creator><![CDATA[LoRaTracker]]></dc:creator><pubDate>Thu, 31 May 2018 17:31:07 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Thu, 31 May 2018 17:16:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loratracker" aria-label="Profile: loratracker">@<bdi>loratracker</bdi></a> said in <a href="/post/20073">Workable editor for Windows virtual machine</a>:</p>
<blockquote>
</blockquote>
]]></description><link>https://forum.pycom.io/post/20074</link><guid isPermaLink="true">https://forum.pycom.io/post/20074</guid><dc:creator><![CDATA[Charly86]]></dc:creator><pubDate>Thu, 31 May 2018 17:16:32 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Thu, 31 May 2018 17:10:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/charly86" aria-label="Profile: charly86">@<bdi>charly86</bdi></a> My host PC is a core i7, 3.4Ghz, 16GB RAM, so it ought to have enough power.</p>
<blockquote>
<p dir="auto">Anyway, like you I would like a standalone Pymakr we can run on command line because installing ATOM just for upload on customer computers is not a good option ;-)</p>
</blockquote>
<p dir="auto">Ampy does work, but with Windows at least you have to exit your serial terminal application, run ampy and then restart the terminal application.</p>
]]></description><link>https://forum.pycom.io/post/20073</link><guid isPermaLink="true">https://forum.pycom.io/post/20073</guid><dc:creator><![CDATA[LoRaTracker]]></dc:creator><pubDate>Thu, 31 May 2018 17:10:21 GMT</pubDate></item><item><title><![CDATA[Reply to Workable editor for Windows virtual machine on Thu, 31 May 2018 16:38:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/loratracker" aria-label="Profile: LoRaTracker">@<bdi>LoRaTracker</bdi></a><br />
I'm using ATOM + Pymark in old Windows Computer (5 years) core i3 3Ghz  with 8Gb of RAM and it's working fine (but not tried in VM) and with Chrome + Arduino IDE + Sublime Text in the same session and my cpu is about 10%. Upload from pymakr takes 5s so that's strange.</p>
]]></description><link>https://forum.pycom.io/post/20072</link><guid isPermaLink="true">https://forum.pycom.io/post/20072</guid><dc:creator><![CDATA[Charly86]]></dc:creator><pubDate>Thu, 31 May 2018 16:38:42 GMT</pubDate></item></channel></rss>
