Cant connect Sipy to Sigfox Backend[Argentina][RCZ4]
  • Hello. I have now been trying to connect to Sigfox Backend for over a week without any success. I successfully went through the whole setup project, following the web page tutorial and this one:
    https://jankrupa.com/blog/2017/04/getting-started-with-sigfox-using-pycom-sipy/
    On every step, i changed RCZ1 to RCZ4 given that is my sigfox zone.
    At the end, this is what i get in my device data on the sigfox backend:
    This is what i see on the back end:
    I am now trying to post something to sigfox public network from the device telnet commandline using the following code:
    from network import Sigfox
    sigfox = Sigfox(mode=Sigfox.SIGFOX, rcz=Sigfox.RCZ4)
    s.setblocking(True)
    s.setsockopt(socket.SOL_SIGFOX, socket.SO_RX, False)
    s.send(bytes([1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12]))
    12
    I tried downgrading the firmware from 1.15 to 1.12, also without success.
    Please help! Thanks a lot!
  • Banned
  • Hello both,
    To receive help is preferable to you share your current location (Country, city) to find out if Sigfox is available, pycom device (They are 3 devices that can use Sigfox) and current framework you are using.
    First verify the coverage for your location https://www.sigfox.com/en/coverage
    Please verify:
    1- THE ANTENNA IS CONNECTED TO THE DEVICE
    2- Try sending a message outside of building
    3- Try to send short message
    4- Follow this tutorial https://docs.pycom.io/tutorials-and-examples/sigfox for disengage sequence number
  • @pepo hola
    tengo el mismo problema, lograste conectarte?
    podrias darme una mano, muchas gracias por responder
