BLE Second characteristic showing up NULL
I have the following code, the first characteristics works, the second show up as NULL. I can read the second characteristic using chr2.read(), but oever the air the characteristic shows null.
chr1 is operating properly.
srv1 = bluetooth.service(uuid=b'1234567890123456', nbr_chars=2, isprimary=True,) chr1 = srv1.characteristic(uuid=b'ab34567890123456', value=5) chr2 = srv1.characteristic(uuid=b'ab34567890123457', value=6) def char1_cb_handler(chr): events = chr.events() if events & Bluetooth.CHAR_WRITE_EVENT: print("Char 1 write request with value = {}".format(chr.value())) else: print('Read request on char 1') def char2_cb_handler(chr): events = chr.events() if events & Bluetooth.CHAR_WRITE_EVENT: print("Char 2 write request with value = {}".format(chr.value())) else: print('Read request on char 2') char1_cb = chr1.callback(trigger=Bluetooth.CHAR_WRITE_EVENT | Bluetooth.CHAR_READ_EVENT, handler=char1_cb_handler) char2_cb = chr2.callback(trigger=Bluetooth.CHAR_WRITE_EVENT | Bluetooth.CHAR_READ_EVENT, handler=char2_cb_handler)
After updating to the newest revision and resetting everything, the above code is functional. SOLVED
