<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[WiPy 2.0 and DHT22]]></title><description><![CDATA[<p dir="auto">Hi folks,</p>
<p dir="auto">i have to connect a DHT22 to the WiPy 2.0.<br />
The WiPy is mounted on the Expansion Board v2.1A.</p>
<p dir="auto">I'm no hardware guy, just software.<br />
So i need help with the wiring of the sensor to the board. VDD and GND are a no-brainer,<br />
but which pin shall i use for the DATA signal?<br />
And which settings are required for the pin?</p>
<p dir="auto">I have seen that in some sketches a pullup resistor of 10k is used between VDD and DATA.<br />
Is this as well necessary for the WiPy 2.0?</p>
<p dir="auto">In addition: Has anybody already a working driver for the sensor?<br />
I know that there is some code for the pyboard but my latest news is that this does not<br />
work on the WiPy.<br />
With some help from a hardware guy i can support a port of the DHT11/22 module.</p>
<p dir="auto">Many thanks in advance,<br />
Marc</p>
]]></description><link>https://forum.pycom.io/topic/369/wipy-2-0-and-dht22</link><generator>RSS for Node</generator><lastBuildDate>Tue, 13 Oct 2026 18:29:29 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/369.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 15 Dec 2016 09:55:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to WiPy 2.0 and DHT22 on Thu, 15 Dec 2016 09:55:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi folks,</p>
Marc</p>
]]></description><link>https://forum.pycom.io/post/2180</link><guid isPermaLink="true">https://forum.pycom.io/post/2180</guid><dc:creator><![CDATA[MaSePreetz]]></dc:creator><pubDate>Thu, 15 Dec 2016 09:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to WiPy 2.0 and DHT22 on Thu, 15 Dec 2016 10:14:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I don't have this sensor, but it seems like there is a micropython lib available <a href="https://github.com/kurik/uPython-DHT22" target="_blank" rel="noopener noreferrer nofollow">here</a>.</p>
<p dir="auto">For info about the pins, check the pinouts in the <a href="https://docs.pycom.io/pycom_esp32/pycom_esp32/wipy2.html" target="_blank" rel="noopener noreferrer nofollow">documentation</a>. I think in this case you need to use pins without a pullup resistor. Also look at the expansionboard pinout over at the docs, and check which pins are in use for things like the button and led on the board.</p>
<p dir="auto">Does that get you any further?</p>
<p dir="auto">Regards, Ralph</p>
]]></description><link>https://forum.pycom.io/post/2183</link><guid isPermaLink="true">https://forum.pycom.io/post/2183</guid><dc:creator><![CDATA[Ralph]]></dc:creator><pubDate>Thu, 15 Dec 2016 10:14:25 GMT</pubDate></item><item><title><![CDATA[Reply to WiPy 2.0 and DHT22 on Thu, 15 Dec 2016 13:47:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi Ralph,</p>
<p dir="auto">thanks for your fast answer.</p>
<p dir="auto">I already found the library you mentioned. But it is written for the pyboard and not for the WiPy.<br />
There i am in the need for help on the hardware side...</p>
<p dir="auto">For the pins i am no step further. Hardware is a sealed book for me, i have absolutely no knowledge<br />
and can't read schematics well. That why i asked for an explicit pin to use.<br />
I develop software for my living but the hardware side is not developed at all at the basic level.</p>
<p dir="auto">But thanks anyway,<br />
Marc</p>
]]></description><link>https://forum.pycom.io/post/2185</link><guid isPermaLink="true">https://forum.pycom.io/post/2185</guid><dc:creator><![CDATA[MaSePreetz]]></dc:creator><pubDate>Thu, 15 Dec 2016 13:47:51 GMT</pubDate></item><item><title><![CDATA[Reply to WiPy 2.0 and DHT22 on Fri, 16 Dec 2016 06:58:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/76">@Ralph</a><br />
especially this not exists in WiPy<br />
<code>from pyb import ExtInt</code></p>
<p dir="auto">and</p>
<pre><code>ExtInt(data, ExtInt.IRQ_FALLING, Pin.PULL_UP, None)
ExtInt(data, ExtInt.IRQ_FALLING, Pin.PULL_UP, edge)
</code></pre>
<p dir="auto">It is good startup but someone must have knowledge how to port.<br />
Maybe i will port this <strong>(or meybe someone done it already?</strong>) - i have DHT11(less accurate but the principle is the same)<br />
but i wait for new firmware and timers support</p>
]]></description><link>https://forum.pycom.io/post/2192</link><guid isPermaLink="true">https://forum.pycom.io/post/2192</guid><dc:creator><![CDATA[livius]]></dc:creator><pubDate>Fri, 16 Dec 2016 06:58:59 GMT</pubDate></item></channel></rss>
