<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LoPy orientation]]></title><description><![CDATA[<p dir="auto">Will either the LoPy or the expansion board be damaged is the LoPy is connected the wrong way?  I've noticed the sticker is on upside down compared to the images and I had to match up the components to make sure it was plugged in the correct way.</p>
]]></description><link>https://forum.pycom.io/topic/38/lopy-orientation</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Jul 2026 15:57:13 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/38.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 13 Oct 2016 11:52:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LoPy orientation on Thu, 13 Oct 2016 11:52:58 GMT]]></title><description><![CDATA[<p dir="auto">Will either the LoPy or the expansion board be damaged is the LoPy is connected the wrong way?  I've noticed the sticker is on upside down compared to the images and I had to match up the components to make sure it was plugged in the correct way.</p>
]]></description><link>https://forum.pycom.io/post/51</link><guid isPermaLink="true">https://forum.pycom.io/post/51</guid><dc:creator><![CDATA[n0ahg]]></dc:creator><pubDate>Thu, 13 Oct 2016 11:52:58 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy orientation on Wed, 19 Oct 2016 12:15:07 GMT]]></title><description><![CDATA[<p dir="auto">The led and push button end of the LoPy should be at the micros usb connector end of the expansion board.</p>
]]></description><link>https://forum.pycom.io/post/166</link><guid isPermaLink="true">https://forum.pycom.io/post/166</guid><dc:creator><![CDATA[digsatman]]></dc:creator><pubDate>Wed, 19 Oct 2016 12:15:07 GMT</pubDate></item><item><title><![CDATA[Reply to LoPy orientation on Tue, 25 Oct 2016 07:07:45 GMT]]></title><description><![CDATA[<p dir="auto">Yes, the sticker is upside down on my LoPy as well. As a consequence I did mount it the wrong way first time but it survived. If in doubt, match the pins on your LoPy with the pins on the extension board. PIN layouts for the extension board can be found here: <a href="https://github.com/wipy/wipy/blob/master/docs/User_manual_exp_board.pdf" target="_blank" rel="noopener noreferrer nofollow">https://github.com/wipy/wipy/blob/master/docs/User_manual_exp_board.pdf</a></p>
]]></description><link>https://forum.pycom.io/post/391</link><guid isPermaLink="true">https://forum.pycom.io/post/391</guid><dc:creator><![CDATA[arneme]]></dc:creator><pubDate>Tue, 25 Oct 2016 07:07:45 GMT</pubDate></item></channel></rss>
