    pytrack sample code
    pytrack
    32 Posts 5 Posters 4.5k Views 5 Watching
      abhishek2101
      can somebody post sample code to get the LAT and LONG from the pytrack module and post to TTN ?
      danD 1 Reply Last reply Reply Quote 0
      • danD Offline
        dan @abhishek2101
        @abhishek2101 Hi, you can find LoRaWAN example here with OTAA (and ABP) which includes sending data. You can get the coordinates from the Pytrack example. If you merge these 2 examples, it would solve your question. Let me know if you have any other questions!
          abhishek2101 @dan
          @dan
          I am able to use above code and print the data, but out of all the data where can I find LAT, LONG and timestamp ?
          • danD Offline
            dan @abhishek2101
            @abhishek2101 Line 37, it prints coordinates (LAT, LONG) coord and the time rtc.now()
              abhishek2101 @dan
              @dan
              below is the output i am getting
              (None, None) - (1970, 1, 1, 0, 2, 13, 827831, None) - 2547456
              • danD Offline
                dan @abhishek2101
                @abhishek2101 for the time, you either have to set it yourself, or sync it with a NTP server (via WiFi or cellular). Are you inside a building? It might take a while (or even fail) to get a location, so I'd recommend trying it outside or near windows
                  abhishek2101 @dan
                  @dan
                  i am outside on a terrace.
                  • danD Offline
                    dan @abhishek2101
                    @abhishek2101 it might take some time to find a GPS satellite? If the issue persists, let me know and we'll look into it in detail.
                    • catalinC Offline
                      catalin
                      hi @abhishek2101, it seems you have a GPS problem. I would recommend:
                      • leave the pytrack for 30 mins outside, to pick-up the satellites data, as this is a cold-start, could take a while
                      • check, with a mobile app, how many satellites are visible on your exact position, it could be a glitch
                      Catalin,
                        abhishek2101 @dan
                        @dan
                        can you let me know what are below lines doing in the code
                        l76 = L76GNSS(py, timeout=180)
                        chrono = Timer.Chrono()
                        chrono.start()
                        while (True):
                            coord = l76.coordinates()
                            print(coord)
                        • danD Offline
                          dan @abhishek2101
                          @abhishek2101
                          • Set up GPS module
                          • Start measuring timespan (docs) (but I'm not sure why it's there... It was probably left there by mistake, I'll look into that)
                          • Always get coordinates
                            abhishek2101 @dan
                            @dan
                            timeout=180
                            does this mean that chip will spend 180 sec before locking onto satellites ?
                            • danD Offline
                              dan @abhishek2101
                              @abhishek2101
                              Set the timeout to a time period (in seconds) for the GPS to search for a lock. If a lock is not found by the time the timeout has expired, the coordinates method will return (None, None).
                              docs
                                abhishek2101 @dan
                                @dan
                                mine is set for 180 seconds, that should be enough time to lock onto satellites, right ?
                                if this time is less, what do you think is the ideal time ?
                                does this mean that every update happens after 180 seconds, or it the first one only ?
                                • danD Offline
                                  dan @abhishek2101
                                  @abhishek2101 It's just the timeout for locking onto a satellite, so if after 180 seconds it doesn't find one, it returns None. In the example, we have 30.
                                  It's just for the initialisation. After that, if you have it in a while(True) loop for example, it'll update around every second.
                                    abhishek2101 @dan
                                    @dan
                                    Mine always return none even after initialising for 300 seconds.
                                    Can you help please ?
                                    • danD Offline
                                      dan @abhishek2101
                                      @abhishek2101 have you tried what @catalin recommended?
                                      @catalin said in pytrack sample code:
                                        abhishek2101 @dan
                                        @dan
                                        I will try and report back.
                                        But taking 30 min to lock onto satellites is simply not acceptable. It makes pytrack unusable.
                                        • danD Offline
                                          dan @abhishek2101
                                          @abhishek2101 could you check the GPS coverage at your location? I have tested it here at the office and got the coordinates within a few seconds. I don't think it's a software or hardware issue.
                                          A 3 Replies Last reply Reply Quote 1
                                            abhishek2101 @dan
                                            @dan
                                            Google maps on my iPhone shows my location at the same place within few seconds.
                                            • 1
                                            • 2
                                            • 1 / 2
