<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update LTE-M issues Australia]]></title><description><![CDATA[<p dir="auto">Using release 1.18.1.r1 and sequans firmware provided by CATM1-38638.zip. Have reviewed many of the other topics regarding this issue but now seem a little stale regarding SW revisions and supposed work being undertaken by Telstra in particular. What is the current status of this issue, and how do you use the required commands to access the network? There also appears to be no response when issuing an AT command. In reply to a command a ' ' response is only ever received .</p>
]]></description><link>https://forum.pycom.io/topic/3855/update-lte-m-issues-australia</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 18:29:13 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/3855.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Oct 2018 05:48:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update LTE-M issues Australia on Tue, 09 Oct 2018 05:48:13 GMT]]></title><description><![CDATA[<p dir="auto">Using release 1.18.1.r1 and sequans firmware provided by CATM1-38638.zip. Have reviewed many of the other topics regarding this issue but now seem a little stale regarding SW revisions and supposed work being undertaken by Telstra in particular. What is the current status of this issue, and how do you use the required commands to access the network? There also appears to be no response when issuing an AT command. In reply to a command a ' ' response is only ever received .</p>
]]></description><link>https://forum.pycom.io/post/22781</link><guid isPermaLink="true">https://forum.pycom.io/post/22781</guid><dc:creator><![CDATA[davidchallender]]></dc:creator><pubDate>Tue, 09 Oct 2018 05:48:13 GMT</pubDate></item><item><title><![CDATA[Reply to Update LTE-M issues Australia on Tue, 09 Oct 2018 10:50:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3183">@davidchallender</a> Hi, if Telstra is using band 8, please check <a href="https://forum.pycom.io/topic/3843/important-news-regarding-cat-m1-and-nb-iot-cellular-range">this</a> post. When sending AT commands, you never get anything back, or it returns <code>''</code> for specific commands?</p>
]]></description><link>https://forum.pycom.io/post/22784</link><guid isPermaLink="true">https://forum.pycom.io/post/22784</guid><dc:creator><![CDATA[dan]]></dc:creator><pubDate>Tue, 09 Oct 2018 10:50:52 GMT</pubDate></item><item><title><![CDATA[Reply to Update LTE-M issues Australia on Tue, 09 Oct 2018 12:09:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/2032">@dan</a> An empty string is returned in cases, when the LTE modem takes longer than 10 seconds to respond. Sending an empty AT command (lte.send_at_command('')) may show such a late resonse.</p>
]]></description><link>https://forum.pycom.io/post/22787</link><guid isPermaLink="true">https://forum.pycom.io/post/22787</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Tue, 09 Oct 2018 12:09:47 GMT</pubDate></item></channel></rss>
