<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Serial Sensor - 5V]]></title><description><![CDATA[<p dir="auto">I have a serial sensor which needs 5 volts.  I plan to power it from Vin and GND of the Expansion Board (3.0).</p>
<p dir="auto">My question is will this damage the RX and TX pins being that the WiPy pins are not 5V tolerant?</p>
<p dir="auto">If it has to be 3.3V, what is the solution?</p>
]]></description><link>https://forum.pycom.io/topic/3884/serial-sensor-5v</link><generator>RSS for Node</generator><lastBuildDate>Mon, 14 Sep 2026 05:09:19 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/3884.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 17 Oct 2018 13:46:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Serial Sensor - 5V on Wed, 17 Oct 2018 13:48:26 GMT]]></title><description><![CDATA[<p dir="auto">I have a serial sensor which needs 5 volts.  I plan to power it from Vin and GND of the Expansion Board (3.0).</p>
]]></description><link>https://forum.pycom.io/post/22947</link><guid isPermaLink="true">https://forum.pycom.io/post/22947</guid><dc:creator><![CDATA[jimmie]]></dc:creator><pubDate>Wed, 17 Oct 2018 13:48:26 GMT</pubDate></item><item><title><![CDATA[Reply to Serial Sensor - 5V on Wed, 17 Oct 2018 13:58:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3387">@jimmie</a> A technical sound solution would be to insert a lelev converter.<br />
A hot fix would be to insert a voltage divider (10k/22k) or at least a resistor of 10k in the wire between Tx(sensor) -&gt; RX(WiPy) to limit the inrush current and connect RX(sensor) -&gt; TX(WiPy) directly or trough a resistor of about 1kOhm. That should protect the WiPy and it should also work.</p>
]]></description><link>https://forum.pycom.io/post/22949</link><guid isPermaLink="true">https://forum.pycom.io/post/22949</guid><dc:creator><![CDATA[robert-hh]]></dc:creator><pubDate>Wed, 17 Oct 2018 13:58:54 GMT</pubDate></item><item><title><![CDATA[Reply to Serial Sensor - 5V on Wed, 17 Oct 2018 14:16:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/98">@robert-hh</a></p>
<p dir="auto">Thank you, much appreciated.</p>
]]></description><link>https://forum.pycom.io/post/22951</link><guid isPermaLink="true">https://forum.pycom.io/post/22951</guid><dc:creator><![CDATA[jimmie]]></dc:creator><pubDate>Wed, 17 Oct 2018 14:16:52 GMT</pubDate></item></channel></rss>
