<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MQTT Connection Failed]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
I'm supposed to code a model house with BME680 sensors. I have the scripts of the previous team but the programm always fails in <a href="http://main.py" target="_blank" rel="noopener noreferrer nofollow">main.py</a> when it comes to the connection part to the <a href="http://mqtt.py" target="_blank" rel="noopener noreferrer nofollow">mqtt.py</a>. I don't understand the Error and cannot find anything about it. So maybe you guys can help me. In the following ist the <a href="http://mqtt.py" target="_blank" rel="noopener noreferrer nofollow">mqtt.py</a> code:</p>
<pre><code>import usocket as socket
import ustruct as struct
from ubinascii import hexlify
class MQTTException(Exception):
pass
class MQTTClient:
def __init__(self, client_id, server, port=0, user=None, password=None, keepalive=0,
             ssl=False, ssl_params={}):
    if port == 0:
        port = 8883 if ssl else 1883
    self.client_id = client_id
    self.sock = None
    self.addr = socket.getaddrinfo(server, port)[0][-1]
    self.ssl = ssl
    self.ssl_params = ssl_params
    self.pid = 0
    self.cb = None
    self.user = user
    self.pswd = password
    self.keepalive = keepalive
    self.lw_topic = None
    self.lw_msg = None
    self.lw_qos = 0
    self.lw_retain = False
def _send_str(self, s):
    self.sock.write(struct.pack(&quot;!H&quot;, len(s)))
    self.sock.write(s)
def _recv_len(self):
    n = 0
    sh = 0
    while 1:
        b = self.sock.read(1)[0]
        n |= (b &amp; 0x7f) &lt;&lt; sh
        if not b &amp; 0x80:
            return n
        sh += 7
def set_callback(self, f):
    self.cb = f
def set_last_will(self, topic, msg, retain=False, qos=0):
    assert 0 &lt;= qos &lt;= 2
    assert topic
    self.lw_topic = topic
    self.lw_msg = msg
    self.lw_qos = qos
    self.lw_retain = retain
def connect(self, clean_session=True):
    sock = socket.socket()
    self.sock_connect(self.addr)
    if self.ssl:
        import ussl
        self.sock_connect = ussl.wrap_socket(self.sock, **self.ssl_params)
    msg = bytearray(b&quot;\x10\0\0\x04MQTT\x04\x02\0\0&quot;)
    msg[1] = 10 + 2 + len(self.client_id)
    msg[9] = clean_session &lt;&lt; 1
    if self.user is not None:
        msg[1] += 2 + len(self.user) + 2 + len(self.pswd)
        msg[9] |= 0xC0
    if self.keepalive:
        assert self.keepalive &lt; 65536
        msg[10] |= self.keepalive &gt;&gt; 8
        msg[11] |= self.keepalive &amp; 0x00FF
    if self.lw_topic:
        msg[1] += 2 + len(self.lw_topic) + 2 + len(self.lw_msg)
        msg[9] |= 0x4 | (self.lw_qos &amp; 0x1) &lt;&lt; 3 | (self.lw_qos &amp; 0x2) &lt;&lt; 3
        msg[9] |= self.lw_retain &lt;&lt; 5
    self.sock.write(msg)
    #print(hex(len(msg)), hexlify(msg, &quot;:&quot;))
    self._send_str(self.client_id)
    if self.lw_topic:
        self._send_str(self.lw_topic)
        self._send_str(self.lw_msg)
        self._send_str(self.user)
        self._send_str(self.pswd)
    resp = self.sock.read(4)
    assert resp[0] == 0x20 and resp[1] == 0x02
    if resp[3] != 0:
        raise MQTTException(resp[3])
    return resp[2] &amp; 1
def disconnect(self):
    self.sock.write(b&quot;\xe0\0&quot;)
    self.sock.close()
def ping(self):
    self.sock.write(b&quot;\xc0\0&quot;)
def publish(self, topic, msg, retain=False, qos=0):
    pkt = bytearray(b&quot;\x30\0\0\0&quot;)
    pkt[0] |= qos &lt;&lt; 1 | retain
    sz = 2 + len(topic) + len(msg)
    if qos &gt; 0:
        sz += 2
    assert sz &lt; 2097152
    i = 1
    while sz &gt; 0x7f:
        pkt[i] = (sz &amp; 0x7f) | 0x80
        sz &gt;&gt;= 7
        i += 1
    pkt[i] = sz
    #print(hex(len(pkt)), hexlify(pkt, &quot;:&quot;))
    self.sock.write(pkt, i + 1)
    self._send_str(topic)
    if qos &gt; 0:
        self.pid += 1
        pid = self.pid
        struct.pack_into(&quot;!H&quot;, pkt, 0, pid)
        self.sock.write(pkt, 2)
    if qos == 1:
        while 1:
            op = self.wait_msg()
            if op == 0x40:
                sz = self.sock.read(1)
                assert sz == b&quot;\x02&quot;
                rcv_pid = self.sock.read(2)
                rcv_pid = rcv_pid[0] &lt;&lt; 8 | rcv_pid[1]
                if pid == rcv_pid:
                    return
    elif qos == 2:
        assert 0
def subscribe(self, topic, qos=0):
    assert self.cb is not None, &quot;Subscribe callback is not set&quot;
    pkt = bytearray(b&quot;\x82\0\0\0&quot;)
    self.pid += 1
    struct.pack_into(&quot;!BH&quot;, pkt, 1, 2 + 2 + len(topic) + 1, self.pid)
    self.sock.write(pkt)
    self.sock.write(qos.to_bytes(1, 'little'))
    while 1:
        if op == 0x90:
            #print(resp)
            assert resp[1] == pkt[2] and resp[2] == pkt[3]
            if resp[3] == 0x80:
            return
# Wait for a single incoming MQTT message and process it.
# Subscribed messages are delivered to a callback previously
# set by .set_callback() method. Other (internal) MQTT
# messages processed internally.
def wait_msg(self):
    res = self.sock.read(1)
    self.sock.setblocking(True)
    if res is None:
        return None
    if res == b&quot;&quot;:
        raise OSError(-1)
    if res == b&quot;\xd0&quot;:  # PINGRESP
        sz = self.sock.read(1)[0]
        assert sz == 0
        return None
    op = res[0]
    if op &amp; 0xf0 != 0x30:
        return op
    sz = self._recv_len()
    topic_len = self.sock.read(2)
    topic_len = (topic_len[0] &lt;&lt; 8) | topic_len[1]
    topic = self.sock.read(topic_len)
    sz -= topic_len + 2
    if op &amp; 6:
        pid = pid[0] &lt;&lt; 8 | pid[1]
        sz -= 2
    msg = self.sock.read(sz)
    self.cb(topic, msg)
    if op &amp; 6 == 2:
        pkt = bytearray(b&quot;\x40\x02\0\0&quot;)
        struct.pack_into(&quot;!H&quot;, pkt, 2, pid)
    elif op &amp; 6 == 4:
        assert 0
# Checks whether a pending message from server is available.
# If not, returns immediately with None. Otherwise, does
# the same processing as wait_msg.
def check_msg(self):
    self.sock.setblocking(False)
    return self.wait_msg()
</code></pre>
]]></description><link>https://forum.pycom.io/topic/3955/mqtt-connection-failed</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 23:13:33 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/3955.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Nov 2018 14:27:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MQTT Connection Failed on Tue, 06 Nov 2018 12:41:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
pass
class MQTTClient:
    if port == 0:
    self.sock = None
    self.ssl = ssl
    self.pid = 0
    self.cb = None
    self.user = user
    self.lw_msg = None
    self.lw_qos = 0
    self.sock.write(s)
    n = 0
    sh = 0
    while 1:
            return n
        sh += 7
    self.cb = f
    assert topic
    self.lw_msg = msg
    self.lw_qos = qos
    if self.ssl:
        import ussl
        msg[9] |= 0xC0
    if self.keepalive:
    if self.lw_topic:
    if self.lw_topic:
    if resp[3] != 0:
    self.sock.close()
def ping(self):
    if qos &gt; 0:
        sz += 2
    i = 1
    while sz &gt; 0x7f:
        sz &gt;&gt;= 7
        i += 1
    pkt[i] = sz
    if qos &gt; 0:
        self.pid += 1
        pid = self.pid
    if qos == 1:
        while 1:
            if op == 0x40:
                if pid == rcv_pid:
                    return
    elif qos == 2:
        assert 0
    self.pid += 1
    while 1:
        if op == 0x90:
            #print(resp)
            if resp[3] == 0x80:
            return
def wait_msg(self):
    if res is None:
        return None
        raise OSError(-1)
        assert sz == 0
        return None
    op = res[0]
        return op
    sz -= topic_len + 2
    if op &amp; 6:
        sz -= 2
    self.cb(topic, msg)
    if op &amp; 6 == 2:
        assert 0
</code></pre>
]]></description><link>https://forum.pycom.io/post/23295</link><guid isPermaLink="true">https://forum.pycom.io/post/23295</guid><dc:creator><![CDATA[Modellhaus]]></dc:creator><pubDate>Tue, 06 Nov 2018 12:41:33 GMT</pubDate></item><item><title><![CDATA[Reply to MQTT Connection Failed on Mon, 05 Nov 2018 19:49:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3475">@modellhaus</a> I suggest you two things for help, the first is to modify your post and please enclose your code in correct code balise  ( &lt;/&gt; tool in line above )to help reading .<br />
The second thing is to post the error message and line number where it happen to help analysis.</p>
]]></description><link>https://forum.pycom.io/post/23305</link><guid isPermaLink="true">https://forum.pycom.io/post/23305</guid><dc:creator><![CDATA[Eric73]]></dc:creator><pubDate>Mon, 05 Nov 2018 19:49:05 GMT</pubDate></item></channel></rss>
