<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LO1 OEM struggles to upload data via Pymakr or ampy.]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">I recently created a custom board for my project that contains an OEM LO1 module. I use FTDI FT230R Basic UART to communicate with it. I am able to connect to REPL very reliably, however when I try to upload files I get different errors such as</p>
<pre><code>Failed to write file, trying again...
</code></pre>
<p dir="auto">It works maybe once in 5 times,  especially if I turn off and on the UART cable.<br />
I tried couple different firmwares, no difference. Once in a while I also receive</p>
<pre><code>Guru Meditation Error: Core  1 panic'ed (IllegalInstruction)
</code></pre>
<p dir="auto">error. Could this mean there's something wrong with the ESP32 itself?</p>
<p dir="auto">Is there anything such as a certain pin not being pulled up that could cause that? I have a LoPy with the expansion board to use as a reference but I can't seem to find anything that is out of place on my board.</p>
<p dir="auto"><img src="/assets/uploads/files/1543145653280-cd663bce-2c7d-4794-853d-68b7358a21d3-image.png" alt="0_1543145653083_cd663bce-2c7d-4794-853d-68b7358a21d3-image.png" class="img-responsive img-markdown" /></p>
<p dir="auto">Above is the circuitry around the LO1 module, hope that helps.</p>
<p dir="auto">Many thanks,<br />
Miro</p>
]]></description><link>https://forum.pycom.io/topic/4033/lo1-oem-struggles-to-upload-data-via-pymakr-or-ampy</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 14:04:31 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4033.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Nov 2018 11:39:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LO1 OEM struggles to upload data via Pymakr or ampy. on Sun, 25 Nov 2018 11:40:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
</code></pre>
</code></pre>
Miro</p>
]]></description><link>https://forum.pycom.io/post/23745</link><guid isPermaLink="true">https://forum.pycom.io/post/23745</guid><dc:creator><![CDATA[miro_bli]]></dc:creator><pubDate>Sun, 25 Nov 2018 11:40:16 GMT</pubDate></item><item><title><![CDATA[Reply to LO1 OEM struggles to upload data via Pymakr or ampy. on Sun, 25 Nov 2018 13:15:21 GMT]]></title><description><![CDATA[<p dir="auto">In my opinion RESET pin should not be left floating. Try to connect pull-up resistor to 3.3V in 10k-20k range.<br />
Check L01 OEM Baseboard schematic:<br />
<a href="https://docs.pycom.io/product-info-datasheets/oem/l01_reference" target="_blank" rel="noopener noreferrer nofollow">https://docs.pycom.io/product-info-datasheets/oem/l01_reference</a></p>
<p dir="auto">Edit: Sorry, now I noticed the reset pull-up already being in your schematic. Anyway try to use FTP client for script uploading.</p>
]]></description><link>https://forum.pycom.io/post/23751</link><guid isPermaLink="true">https://forum.pycom.io/post/23751</guid><dc:creator><![CDATA[danielm]]></dc:creator><pubDate>Sun, 25 Nov 2018 13:15:21 GMT</pubDate></item></channel></rss>
