<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Pybytes dashboard not accepting data]]></title><description><![CDATA[<p dir="auto">I have a WiPY 3 and it was pushing 6 virtual pins to my Pybytes dashboard for several weeks.  Now only the first virtual pin gets updated.  I experimented with my code and found that if I wait 3 seconds between virtual pin messages, they all make it.  If I remove the 3 second pause (or drop it down to 1 second) only the first value makes it.  Any ideas why this would happen?  It worked fine for several weeks.<br />
-Jason</p>
<pre><code>def main_control():
    global  data_file_name
    sensor_read=measure.sensor_measurement()
    write_dict(sensor_read,data_file_name)
    pybytes.send_virtual_pin_value(False, 1, sensor_read['1'][1]) # send data to pybytes
    sleep_ms(3000)
    pybytes.send_virtual_pin_value(False, 2, sensor_read['1'][2])
    sleep_ms(3000)
    pybytes.send_virtual_pin_value(False, 3, sensor_read['0'][1])
    sleep_ms(3000)
    pybytes.send_virtual_pin_value(False, 4, sensor_read['0'][2])
    sleep_ms(3000)
    pybytes.send_virtual_pin_value(False, 5, sensor_read['0'][3])
    sleep_ms(3000)
    pybytes.send_virtual_pin_value(False, 6, sensor_read['0'][4])```</code></pre>
]]></description><link>https://forum.pycom.io/topic/4160/pybytes-dashboard-not-accepting-data</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 20:09:33 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4160.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Dec 2018 03:06:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Pybytes dashboard not accepting data on Thu, 27 Dec 2018 03:07:47 GMT]]></title><description><![CDATA[<p dir="auto">I have a WiPY 3 and it was pushing 6 virtual pins to my Pybytes dashboard for several weeks.  Now only the first virtual pin gets updated.  I experimented with my code and found that if I wait 3 seconds between virtual pin messages, they all make it.  If I remove the 3 second pause (or drop it down to 1 second) only the first value makes it.  Any ideas why this would happen?  It worked fine for several weeks.<br />
-Jason</p>
    sleep_ms(3000)
    sleep_ms(3000)
    sleep_ms(3000)
    sleep_ms(3000)
    sleep_ms(3000)
]]></description><link>https://forum.pycom.io/post/24505</link><guid isPermaLink="true">https://forum.pycom.io/post/24505</guid><dc:creator><![CDATA[jmpratt]]></dc:creator><pubDate>Thu, 27 Dec 2018 03:07:47 GMT</pubDate></item><item><title><![CDATA[Reply to Pybytes dashboard not accepting data on Thu, 27 Dec 2018 03:21:30 GMT]]></title><description><![CDATA[<p dir="auto">Never mind.  I just saw in another post that the update rate has been limited to 1/sec.</p>
]]></description><link>https://forum.pycom.io/post/24506</link><guid isPermaLink="true">https://forum.pycom.io/post/24506</guid><dc:creator><![CDATA[jmpratt]]></dc:creator><pubDate>Thu, 27 Dec 2018 03:21:30 GMT</pubDate></item><item><title><![CDATA[Reply to Pybytes dashboard not accepting data on Thu, 27 Dec 2018 16:54:27 GMT]]></title><description><![CDATA[<p dir="auto">Glad you worked it out :) Ill try and get a note added to the documentation so this is more clear.</p>
]]></description><link>https://forum.pycom.io/post/24510</link><guid isPermaLink="true">https://forum.pycom.io/post/24510</guid><dc:creator><![CDATA[Paul Thornton]]></dc:creator><pubDate>Thu, 27 Dec 2018 16:54:27 GMT</pubDate></item></channel></rss>
