    boot.py reliability
    gpyboot.pydeepsleep
    30 Posts 7 Posters 3.9k Views 7 Watching
    • K Offline
      kjm
      If I run my user deepsleep code as boot.py in a battery powered gpy its reliable. But if I try to run it as m2m.py from a different folder in flash with boot.py as
      import machine, time, pycom
      hook='client/m2m.py'
      print('trying for', hook)
      pycom.rgbled(0xffffff)
      machine.main(hook)
      it eventually stops working with the white light on so I know boot.py failed to run it. I know I've introduced an extra step but this should work consistently shouldn't it?
        robert-hh @kjm
        @kjm Since the RGB LED get's white, boot.py is executed. What does not seem to get executed is m2m.py, which is called instead of main.py. Could you try to specify the full path name '/flash/client/m2m.py' ?
        • K Offline
          kjm
          Already tried that plus a few other path combos Rob, always stops working eventually. I've got a suspicion it's temperature related. Always happens in the heat of the day, gets up to 55 celsius in the little solar enclosure that keeps the battery charged. But 50 celsius should be OK shouldn't it? And it doesn't fall at that temperature if I make my program boot.py
            jcaron @kjm
            @kjm Maybe the LED is adding a few extra degrees, or adding a bit to the power consumption, and your battery doesn't like the combination of heat and extra power requirements?
            Batteries can behave quite differently when deviating significantly from "usual" room temperatures.
            • K Offline
              kjm @jcaron
              @jcaron This was crashing before I added the led to see where it was happening. I'm logging the LiPo cell voltage, it shows the same upward trend regardless of the days temperature. If this happened when I tried to use the lte I'd suspect the battery but simply loading a program from a different folder shouldn't change the current demand. The gpy is specd to work from 3.5-5.5v supply on Vin so as long as the battery stays above 3v5 I figure it should work.
              C robert-hhR J 3 Replies Last reply Reply Quote 0
                crumble @kjm
                @kjm said in boot.py reliability:
                There are multiple ways how your program may fail during startup. If you have only a small RAM device you may run into out of memories during compile or init time. Memory fragmentation may vary for eexample with loops waiting for network or other resources.
                Importing faulty modules may halt the system without useful error messages. Test your imports. I ran into this by typing into the wrong window and noticed it only when it ran into the right path on startup.
                The pytrack needs some time time for a clean i2c access. My device needs up to 5 seconds. Be sure that you are testing the device with nearly the same timings. So don't use print statements only when *Py is connected to your development machine.
                At best you cahnge the LED color at the first line of your m2m.py
                Additionaly after a few imports, so you can do a binary search for a failing import.
                Add a try-except statements aournd your main parts and write the exception into flash.
                  robert-hh @kjm
                  @kjm does it work when you put m2m.py at the same place as main.py?
                    jcaron @kjm
                    @kjm Are you sure it completely fails to load/run m2m.py? Or could it start and just crash a bit further during execution?
                    Are you also sure it never fails with the script directly in boot.py?
                    • K Offline
                      kjm @robert-hh
                      @robert-hh I haven't tried that. boot.py seems bullet proof. If I load my code into flash as boot.py it always runs after deepsleep.
                      main.py I'm less impressed with, it mostly runs if there is no boot.py or nothing in boot.py other than the default 29bytes, but not always. Mean time to not loading is around 300 x 6min deepsleep cycles
                      When I try to run my code from boot.py via machine.main I'm sure the eventual failure is due to not loading because the code uses the rgb led a lot for diagnosis & the colour I see when it stops working indicates the only thing that has run is boot.py, albeit unsuccessful in it's attempt to run my code.
                      I'm not sure if this is relevant but the gpy has this strange behaviour with new code after a power cycle that troubles me. If I load a new regimen into flash, say a change from my code called by boot.py to my code as boot.py, I see led patterns in the first few seconds of the first run that indicate it is trying the previous scheme briefly. It's like there is an area in flash, invisible to us users, that the gpy goes to first, like an echo of the previous setup, before it switches to the new one.
                        robert-hh @kjm
                        @kjm There are both _boot.py and _main.py in frozen bytecode, which are executed before boot.py. _boot.py contains:
                        # _boot.py -- always run on boot-up, even during safe boot
                        import os
                        from machine import UART
                        os.dupterm(UART(0, 115200))
                        _main.py is empty.
                        About your setup with boot.py and m2m.py: That way you actually use the mechanism of boot.py and main.py, only than you tell the firmware to use client/m2m.py instead of main.py. You could try to copy the code from client/m2m.py into main.py and drop the reassignung of main.py. That way, you can isolate the problems, whther it is a problem in your code or a problem with assignuing the name of a file, which is executed instead of main.py.
                        • K Offline
                          kjm @robert-hh
                          @robert-hh So you're saying make my code main.py & leave boot.py empty? I don't see the point of this? I've already established that boot.py runs before main.py & is more reliable than main.py
                            robert-hh @kjm
                            @kjm No. boot.py always runs before main.py or what you define in boot.py to run instead of main.py. My suggestion was to skip that re-pointing of main.py in boot.py and copy the code from m2m.py into main.py, such that the sequence of execution is:
                            boot.py
                            main.py
                            and not, as you tried to define it:
                            boot.py
                            client/m2m.py
                            • K Offline
                              kjm @robert-hh
                              @robert-hh So what code should I have in boot.py in this instance?
                                robert-hh @kjm
                                @kjm The same as now, except for the last statement, which tells to call client/m2m.py instead of main.py.
                                • K Offline
                                  kjm @robert-hh
                                  @robert-hh I used
                                  import pycom; pycom.wdt_on_boot(True); pycom.wdt_on_boot_timeout(10000)
                                  from the cmd line to setup a 10s reboot if our code is not feeding the dog. I figured if the gpy booted into the 4s flash default mode after a deepsleep, the device would reboot after 10s. This doesn't happen even though the flag is still set
                                  >>> import pycom
                                  >>> pycom.wdt_on_boot()
                                  True
                                  Why is the default 4s blue flash mode immune to wdt_on_boot?
                                    robert-hh @kjm
                                    I do not know. I would have to search if the wdt is maybe re-fed in REPL mode. That seems reasonable. But could'nt you just re-enable the WDT with the line above in boot.py? Then at least you know that it is enabled. Still that would not affect re-feeding by REPL.
                                    R K 2 Replies Last reply Reply Quote 0
                                    • R Offline
                                      reidfo @robert-hh
                                      @robert-hh REPL does not seem to feed the WDT in my experience. When in REPL mode my FiPy and GPy units will still reset themselves when the timer has elapsed if I haven't manually fed it.
                                      • K Offline
                                        kjm @robert-hh
                                        @robert-hh I still can't get to the bottom of this. A couple of observations about the 4s blue flash mode the gpy drops into:
                                        1. It looks like regular blue flash mode (4s blue flashes) except it isn't. Can't log in on USB or the gpy ad hoc wifi.
                                        2. In regular blue flash mode I have to connect P12 to 3v3 then press the rest button to get safe boot. In this mode connecting P12 to 3v3 starts the orange safe boot light flashing, no need to press the reset button.
                                          Does this tell us anything about what might be happening to stop it running our code after a deepsleep & dropping into this zombie state instead?
                                          robert-hh @kjm
                                          @kjm The respective code should be in esp32/mktask.c. Looking at it, that may happen if there is a problem in executing boot.py or main.py. which causes a FORCED_EXIT, whatever causes this (lines 278 and 300 of mptask.c). More anaylsis to be done.
                                          • K Offline
                                            kjm @robert-hh
                                            @robert-hh Sure would be nice if zombie heartbeat didn't kill pycom.wdt_on_boot(True), makes it a real cul-de-sac!
                                            • 1
                                            • 2
                                            • 1 / 2
