Issues for connecting lora application model to lorawan nano gateway
  • I have tried connecting this lora application node to lorawan nano gateway but its showing Not joined yet . what should I do ? Is there any more lib required on lora application module to make it send data to gateway .
    • list item
  • If you look at the TTN account the gateway is registered under at the devices gateway page.
    Do you see any join requests from the node. or any traffic at all?
    Does the output from the gateway suggest anything is happening?
    if you could share the code your using it would help understand what's going on :)
  • @fiskeminal123 At least at the nanogateway you should see messages arriving from the node. If not, most likely the Channel/SF/LoRa mode settings for node and gateway do not match.
