ImportError: no module named 'operator'
  • Trying to use python's "operator" module in version 3.7.2 on the pycom and I'm getting below:
    Initializing filesystem as FatFS!
      File "main.py", line 10, in <module>
    Pycom MicroPython 1.20.0.rc0 [v1.9.4-9f0896a] on 2018-12-08; GPy with ESP32
    I've tried manually putting in the operator module but I get the following error:
      File "/flash/lib/operator.py", line 110
    SyntaxError: invalid syntax
    The offending line in the operator.py is:
    def matmul(a, b):
        "Same as a @ b."
        return a @ b
    Is there a firmware update or something I need to do to get it working for python version 3.5 and higher?
  • @randomrnti That works :) glad you got it sorted.
  • @paul-thornton No worries, I ended up copying across the mainline's operator.py and removing the lines of code implementing the matmul. Luckily for me I didn't need to use the matrix multiplication.
  • Hey,
    as you've discovered the micropython implementation is seperate to that of "mainline" python and thus lags behind in features and support.
    @ support is currently missing. Your going to need to implement your own Matrix multiply function without using the @ Operator.
