<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Connecting to multiple LTE carriers]]></title><description><![CDATA[<p dir="auto">I'm using Things Mobile, which uses multiple roaming carriers. In the US that includes AT&amp;T (Cingular), T-Mobile, Sprint, and Verizon. I'm not specifying any particular band or carrier in my connection. But so far I've only seen connections to AT&amp;T and (possibly 1 or 2 times out of hundreds) Sprint, when I know Verizon has a signal (as reported by the GPy with AT+COPS=?) sometimes twice as strong. Things Mobile does not use steering, so it will use the best available carrier. It's also interesting that AT+COPS=? fails most of the time, and occasionally I will see it return results, and when it does I see that at least Verizon and AT&amp;T are available, usually with Verizon having a much higher signal strength. When AT+COPS=? succeeds and the GPy tries to connect (showing again signal strength I'd expect from Verizon and not AT&amp;T) the modem never attaches. The watchdog timer eventually resets the device and it will connect on the next boot, always to AT&amp;T.</p>
<p dir="auto">I have several questions:</p>
<ul>
<li>
<p dir="auto">Are any others seeing similar behavior, or have a way to automatically connect using multiple possible carriers?</p>
</li>
<li>
<p dir="auto">What LTE initialization and connection code do you use? I'm using a combination of AT commands and LTE.attach(). i do not call LTE.init(). I found code snippets on this forum and used what seemed to work. Regardless of whether you're using multiple carriers, I'd like to see some &quot;correct&quot; code people are actually using in the field.</p>
</li>
<li>
<p dir="auto">Are there special requirements for connecting to Verizon?</p>
</li>
<li>
<p dir="auto">If automatic carrier selection like this is not possible out of the box, how would I go about accomplishing this?</p>
</li>
</ul>
<p dir="auto">My connection code, shortened to just the AT commands and attach():</p>
<pre><code>    lte.send_at_cmd('AT+CGDCONT=1,&quot;IP&quot;,&quot;TM&quot;')
    lte.send_at_cmd('AT+CEMODE=0')
    lte.send_at_cmd('AT+CEREG=2')
    lte.send_at_cmd('AT+CFUN=1')
    lte.attach()
</code></pre>
<p dir="auto">Then in a while loop I show the result of AT+CSQ and wait for LTE.isattached() to return True.</p>
]]></description><link>https://forum.pycom.io/topic/4189/connecting-to-multiple-lte-carriers</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 11:55:30 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4189.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 07 Jan 2019 04:16:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Connecting to multiple LTE carriers on Mon, 07 Jan 2019 05:30:03 GMT]]></title><description><![CDATA[<p dir="auto">I'm using Things Mobile, which uses multiple roaming carriers. In the US that includes AT&amp;T (Cingular), T-Mobile, Sprint, and Verizon. I'm not specifying any particular band or carrier in my connection. But so far I've only seen connections to AT&amp;T and (possibly 1 or 2 times out of hundreds) Sprint, when I know Verizon has a signal (as reported by the GPy with AT+COPS=?) sometimes twice as strong. Things Mobile does not use steering, so it will use the best available carrier. It's also interesting that AT+COPS=? fails most of the time, and occasionally I will see it return results, and when it does I see that at least Verizon and AT&amp;T are available, usually with Verizon having a much higher signal strength. When AT+COPS=? succeeds and the GPy tries to connect (showing again signal strength I'd expect from Verizon and not AT&amp;T) the modem never attaches. The watchdog timer eventually resets the device and it will connect on the next boot, always to AT&amp;T.</p>
<ul>
<li>
</li>
<li>
</li>
<li>
</li>
<li>
</li>
</ul>
    lte.attach()
</code></pre>
]]></description><link>https://forum.pycom.io/post/24683</link><guid isPermaLink="true">https://forum.pycom.io/post/24683</guid><dc:creator><![CDATA[reidfo]]></dc:creator><pubDate>Mon, 07 Jan 2019 05:30:03 GMT</pubDate></item><item><title><![CDATA[Reply to Connecting to multiple LTE carriers on Mon, 07 Jan 2019 06:21:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3152">@reidfo</a> Have you got the SEQUANS Monarch Platform LR5.1.1.0 AT Commands Reference Manual? I found it invaluable when sorting out LTE AT command set for  here in OZ. You might find a solution in there? With a lot of trial and error, I found connection to be much more stable and consistent if I reset the modem before trying the connect sequence. I also found that the CGDCONT register survives resets but other configuration info doesn't, so my code now sets the full config up every time a connection is made for reliable connections but that could be just an OZ issue..</p>
<p dir="auto">I keep my AT commands as a function in a config file (same with WLAN info), then call that function to return (as a tuple/list) the relevant carrier/WLAN info I want to use. I don't have the luxury of multiple carriers to choose from with LTE really, but for your situation I would try to get the list of available services returned as a tuple or list, then loop through all the services and find the best RSSI and try to connect to that - the AT commands for each carrier could then be looked up. Hope that makes sense.</p>
]]></description><link>https://forum.pycom.io/post/24684</link><guid isPermaLink="true">https://forum.pycom.io/post/24684</guid><dc:creator><![CDATA[Stevo52]]></dc:creator><pubDate>Mon, 07 Jan 2019 06:21:16 GMT</pubDate></item><item><title><![CDATA[Reply to Connecting to multiple LTE carriers on Mon, 07 Jan 2019 06:43:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3193">@stevo52</a> Thank you. I didn't show it, but I do a modem reset if lte.isattached() returns true on boot. I do have the Sequans manual and have been poring over it, but unfortunately I don't have the background to understand all of it. That's helped answer some of my questions.</p>
<p dir="auto">Can anyone post the connection commands they've used with Verizon, T-Mobile, and others? <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3525">@Paul-Thornton</a> I believe it's been suggested here before that there be a wiki-like repository of connection notes for various carriers. This would be very helpful.</p>
]]></description><link>https://forum.pycom.io/post/24687</link><guid isPermaLink="true">https://forum.pycom.io/post/24687</guid><dc:creator><![CDATA[reidfo]]></dc:creator><pubDate>Mon, 07 Jan 2019 06:43:23 GMT</pubDate></item><item><title><![CDATA[Reply to Connecting to multiple LTE carriers on Mon, 07 Jan 2019 07:22:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3152">@reidfo</a> It took me more time than I ever expected to get my prototype with GPY, set up with all the correct AT commands for LTE-M here in Oz so it will run consistently and repeatedly..  :-(</p>
]]></description><link>https://forum.pycom.io/post/24690</link><guid isPermaLink="true">https://forum.pycom.io/post/24690</guid><dc:creator><![CDATA[Stevo52]]></dc:creator><pubDate>Mon, 07 Jan 2019 07:22:23 GMT</pubDate></item><item><title><![CDATA[Reply to Connecting to multiple LTE carriers on Mon, 07 Jan 2019 10:28:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3152">@reidfo</a> A &quot;Known Config&quot; list of working carrier setup details is already on my todo list as I agree Its a very good idea.</p>
<p dir="auto">Happy to take community vetted configs to as I sadly cant travel to every country with every available networks simcard despite my wishes :(</p>
<p dir="auto">pm them over if you have configs you'd like to share.</p>
]]></description><link>https://forum.pycom.io/post/24699</link><guid isPermaLink="true">https://forum.pycom.io/post/24699</guid><dc:creator><![CDATA[Paul Thornton]]></dc:creator><pubDate>Mon, 07 Jan 2019 10:28:39 GMT</pubDate></item><item><title><![CDATA[Reply to Connecting to multiple LTE carriers on Sat, 17 Apr 2021 19:47:44 GMT]]></title><description><![CDATA[<p dir="auto">Per ThingsMobile site, in the US they only provide service with T-Mobile, Sprint and AT&amp;T.  Verizon is noticeably missing.  I am in the same situation, where Verizon is only service available in the area I need to run the gateway.</p>
]]></description><link>https://forum.pycom.io/post/37933</link><guid isPermaLink="true">https://forum.pycom.io/post/37933</guid><dc:creator><![CDATA[aimeeraymond]]></dc:creator><pubDate>Sat, 17 Apr 2021 19:47:44 GMT</pubDate></item><item><title><![CDATA[Reply to Connecting to multiple LTE carriers on Sun, 18 Apr 2021 03:16:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.pycom.io/uid/3152">@reidfo</a> I've put more time than I would like into the lte here in oz too Steve. Stumbled across some bizarre current draws after modem reset in my battery powered application. On the upside I can now finish an lte connection &amp; get into micropower deepsleep in 3s whereas the disconnect/detach sequence used to take more like 7s. These gems are hard won by those of us who go down these rabbit holes &amp; I'd be happy to share on a wiki. I also think pycom HQ could post some material too, like exactly what lte.init() does for instance.</p>
]]></description><link>https://forum.pycom.io/post/37936</link><guid isPermaLink="true">https://forum.pycom.io/post/37936</guid><dc:creator><![CDATA[kjm]]></dc:creator><pubDate>Sun, 18 Apr 2021 03:16:12 GMT</pubDate></item></channel></rss>
