<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[export data from pybytes]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">i've send a lot of data to pybytes which i would further look into. as for now this is only possible on pybytes itself(or i am not seeing the export function), i would like to export the entire data table to throw some calculations to it.</p>
<p dir="auto">as i couldn't see an export function i tried to select the data from the data table. i thought i paste in a file an throw some code to it to remove the number of bytes field and go calculate. this didn't work because it only possible to select the visible data fields and i'm not really in the mood  to select 10 lines copy - paste scroll down and repeat.</p>
<p dir="auto">TLDR: is there an easy option to export data from pybytes</p>
]]></description><link>https://forum.pycom.io/topic/4197/export-data-from-pybytes</link><generator>RSS for Node</generator><lastBuildDate>Mon, 18 May 2026 21:55:21 GMT</lastBuildDate><atom:link href="https://forum.pycom.io/topic/4197.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Jan 2019 13:23:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to export data from pybytes on Tue, 08 Jan 2019 13:23:42 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
]]></description><link>https://forum.pycom.io/post/24756</link><guid isPermaLink="true">https://forum.pycom.io/post/24756</guid><dc:creator><![CDATA[Eric Waai]]></dc:creator><pubDate>Tue, 08 Jan 2019 13:23:42 GMT</pubDate></item><item><title><![CDATA[Reply to export data from pybytes on Wed, 09 Jan 2019 10:24:13 GMT]]></title><description><![CDATA[<p dir="auto">Heya,</p>
<p dir="auto">There is currently no system in place to export data. but one should be ready soon.</p>
<p dir="auto">Paul</p>
]]></description><link>https://forum.pycom.io/post/24773</link><guid isPermaLink="true">https://forum.pycom.io/post/24773</guid><dc:creator><![CDATA[Paul Thornton]]></dc:creator><pubDate>Wed, 09 Jan 2019 10:24:13 GMT</pubDate></item></channel></rss>
